Hello! I'm in a bit of trouble about this and unable to find an answer on the forums.... My car is 1997 B5 Quattro sedan 2.8L SOHC 12V
I had destroyed my old seized in rear ABS wheel speed sensors while trying to remove them and bought 2 very expensive OEM sensors to replace them. When I pushed them in, they would not go in all of the way to the "fully seated" position. Still a fraction of on inch left of the shiny barrel exposed. I pushed and twisted for awhile and then after measuring discovered that the sensor is not able to go in further because its hitting the reluctor ring! When I spin the axle I can feel the pulses.
I bought the correct part number for my car but the sensor seems to be too long? has anyone come across this problem? I am very confused about this. I could pull the sensor back a little so that it isn't touching but how to know when it's the correct distance from the ring?
Advice to anyone else.... If you need to remove your wheel bearing housing, unplug the ABS sensor from under the back seat and leave the sensor installed, taking the wire with it.
Any thoughts are so welcome!
