Originally Posted by
Waffles_s4
That’s an easy one to lose, too. I dropped it when changing spark plugs (you have to move the reservoir to get to the coil packs and plugs on that side. Fortunately, I was able to locate it.
I think that may be a dealer item. It ought not cost much. That is needed to lock the hard line into the reservoir overflow nipple. I don’t think a zip tie would work there.
When you get one, the two little right angle feet at the bottom face toward you when you install it. You have to press that hard line as deep into the nipple as possible and then push the clip down. Pull back to make sure it locked.
