Anyone tested various pressure PRV with software that the tuner claims will adapt for an upgraded PRV of 150 bar or higher? RS4 PRV is out...rated pressure is too low, and the rest on the market are 155 (APR) or higher in the 165/175 bar range. If the software adapts...would a higher breaking point for the valve always mean more fuel in the motor and thus more power? Software already requires S3 injectors and HPFP upgrade.
If the pressure supported by the PRV largely doesn't matter, than going for the lowest cost unit above the software threshold would make the most sense whereas if each pressure increase the PRV supports will output a bit more power than buying largest would be better.
thoughts?
