According to wheel-size.com, this is the difference:
So the width of the rim and offset of the 1999 A4 Avant's wheels is less my OEM 17" spec, by an inch and 5 mm respectively.
1. Do these differences matter at all, and are the b5 wheels ok to use on my b8.5? Will my steering geometry be messed up because of these differences?
2. Do I need to do anything about the ET42 offset vs my car's ET47, in conjunction with the narrower wheels (7j vs 8j)?
Reading this, it sounds as if the combination of lower positive offset and reduced tire width will result a negative backspacing of 30.4 mm for these smaller wheels, as compared to spec for 17s on my car. The 30.4 mm comes from the 5 mm offset difference plus 25.4 mm for the one-inch narrower tires.
So do I need 5 mm wheel spacers, 30 mm wheel spacers, or am I making this too complicated?
