Results 1 to 6 of 6
    Oct 27 2019
    PNW
    Budget stereo upgrade - amp and subwoofer install (PIC HEAVY)
    First post, so sorry if I screw this up, but I figured it may help someone out. I purchased my 2017 A4 at the end of 2019 - loved the performance, but the stereo was absolutely gutless. The stock sub on the rear tray just doesn't cut it.
    I went to a couple of car stereo shops locally to have them price out building a custom enclosure in the back right cargo pocket in the trunk. For all of the gear, custom box and install the first shop quoted me $1850. The second shop quoted me $1050 and had pics of one they had done before. I will preface this post by saying that I used to sell car stereos back in the day and install some on the side, but it's been 20 years so I'm not the most skilled. This is a simple install if you have the patience to route wires - routing the RCA/speaker wires from the stock sub location to the spare tire well was by far the longest, so hopefully this post helps someone potentially speed up that process.
    My car doesn't have the B&O upgrade, but the steps below will work for that system as well - I believe you'll just have 4 wires going into your subwoofer instead of 2 - which will save you from having to do one of the steps I did (splitting the wires going into the sub to give me 2 RCA outputs. Below is a list of the items I purchased and their cost at the time I purchased them (I paid more for some items so I could have them sooner rather than waiting for lower priced sellers). Everything was purchased from Amazon. My goal was to get the largest sub possible, but still be able to fit my golf clubs in the trunk and have access to the middle seat pass-through. I initially thought I was going to be limited to a 10" sub, but this 12" works (just barely)!
    - Subwoofer: Pioneer TS-SWX3002 12" subwoofer in low profile enclosure ($125) -- this sub can be mounted DOWNFIRING, which is perfect for my needs.
    - Amp: Cerwin-Vega B52 Stealth Bomber Class D ($113)
    - Amp Wiring Kit: Rockville RWK4CU ($52) -- In hindsight, I really wish I had gone with an 8 AWG OFC (oxygen free copper) wiring kit. The run for the power wire is ~3ft so the 8AWG would have been so much easier to work with. The kit I purchased did come with flat speaker wire which was awesome when running from the amp to the sub.
    - MUYI 16 AWG waterproof connectors ($7)
    - AV to RCA screw terminal adapters ($8) -- Don't buy these - just follow my advice underlined in one of the steps below instead.
    - Tesa tape ($10) -- this was for 3 rolls and I used maybe half of one, but it was more economical to have add'l rolls on hand.
    - Double sided 2" foam tape ($9) -- This is for mounting the amp and 4awg fuse. In hindsight I should have gotten industrial strength double sided velcro instead.
    TOTAL COST: $314 ($306 if you don't waste your money on the AV to RCA connectors)
    Other items I had on hand already:
    - Cutter for cutting 4awg wire (I used PVC pipe cutters and they worked well)
    - Wire cutters and crimpers
    - Crimp connectors
    - Heat shrink tubing
    - zip ties
    - Allen wrenches
    Pic of the amp and sub. This amp is made for ATV's, motorcycles, etc. It is a 2 channel amp that puts out 500W RMS when bridged (which I did and you should if powering a subwoofer) and measures only about 4"x6"x1.5". The super compact size of this amp is perfect for the install I was trying to accomplish. It also turns on automatically when using high level speaker inputs (which we are), so there is no need to run a remote turn-on wire to switched power. It powers itself off within ~30 seconds of sensing no signal. I have tested this and it works as it should.
    Hooked up my 3' of ground wire to the amp and test fit it. Perfect!
    Remove the driver's side grill on the rear shelf by lifting the front (helpful to push on the tab from the underside in the trunk). Once the front has been lifted the back slides out. I then removed most of the cutout, but left some fabric still connected. This gives you easy access to the stock subwoofer wiring harness. If you have B&O, I'm not sure if there is a speaker installed there instead of just a blank cutout.
    Unclip the wiring harness from the subwoofer. You will be clipping this off soon.
    Running the speaker wire from the spare tire well to the sub. This step took me the longest, but I achieved it using a coat hanger with a curving bend to it. I crimped a crimp connector cap on the end of the coat hanger so I didn't inadvertently puncture any of the wires running in this section. I tried feeding it up through the channel the other wires are running, but the bend was too extreme to make so i went just behind them (closer to cabin) where there was a gap.
    I zip tied the speaker wire and fished it up to the cutout hole next to the stock sub. It is a short run of just a foot or two.
    I wanted to be able to revert to stock if I ever want to, so I cut the harness from the stock subwoofer close to the plug. You have to do it close to the plug otherwise it would be a PITA to strip the speaker wires leading from your stock amp to your stock sub. You can work on the unplugged harness outside of the vehicle so make your life easy. I used butt connectors because I don't trust myself soldering in this tight space. Once butt connected I heat shrinked and Tesa taped all of the connections. The plugs/connectors used were the ones from MUYI in my parts list.
    Add a female connector to both the newly cut off wiring harness that clips into the stock sub and another one to the speaker wires that we just ran in the last step. Add a male plug to the wires that come from the stock amplifier that you just cut off of the harness. The pic below shows when I tested it back to the stock connection to make sure I was still getting a signal.
    Once confirmed, I then swapped it over to our new speaker wires which will lead to our new amp.
    In this pic you can see the speaker wire on the left leading from the stock sub location (this will send signal to the new amp) and the speaker wire leading to the new sub on the right (in the process of Tesa taping).
    Just about finished Tesa taping the speaker wire to the new sub and routed it under the battery cage (you'll have to remove the cage later, but I wanted to figure out where I was going to route it to avoid pinching).
    This is where the flat speaker wire that came in my kit came in really handy - as I routed it in the small channel in the molded plastic that runs under the trunk liner. The fit is perfect.
    Remove the battery cage (4 12mm screws/nuts) and disconnect the negative battery terminal. You can see in the pic I am using a leather work glove to isolate the negative battery terminal connector. Then install your positive lead for the amplifier. You can see where I chose to install mine (it is the blue wire with the mesh covering that came in my wiring kit).
    Ran the ground wire from the amplifier around the backside of the battery and used the grounding screw that already exists in the spare tire well. You can also see the routing of the speaker wire (wrapped in Tesa tape) that goes from the amp to the new sub zip tied to the factory positive wire.
    Bridged the 2 channel amp to 1 channel (MORE POWER) by following the directions for this amp (printed on the side of the amp and also in the manual). I think this next step may have been unnecessary and you won't have to do it if you have 4 wires leading into your stock subwoofer (B&O maybe?) since you'll already have two sets of leads coming from that connection, but I split the speaker wire from the factory subwoofer (back from pics 6-9) and put two positive wires coming off the positive side and two negative wires coming off the negative side using a butt connector to make the Y connection. I then attached the AV to RCA screw connectors so we had two RCAs each with their own + and - connections. I didn't get good pics of this, but that's the big mess the plugs in to the left side of the amp via the red and brown RCAs the come included in the amp's wiring harness. Why in the world I didn't just clip those RCAs off of the amps wiring harness and connect directly to that harness I may never know, but I suggest you do just that. It will save you from having to buy those crappy AV to RCA connectors. I cleaned this rat's nest up later, but didn't get a good pic before reinstalling the spare.
    Now it's time to reconnect the negative battery terminal and reinstall the battery cage. Once you have done that you can tune your new amp. These are the settings I wound up using. VOX worked better than DC because on DC the amp wanted to turn on whenever the car recognized the key (think opening your doors). It shut off fine, but was coming on/off too frequently. VOX will turn it on when the stereo comes on and it recognizes a high input signal. Sensitivity is your gain adjustment - you can watch videos on how to set that, but once I dialed it in it basically pointed right at that line above the VOX label. Turn your crossover to LP (low pass filter) for driving your new subwoofer. Set the frequency - should be ~80Hz, but unfortunately there are no incremental labels. I played with it a bunch and landed where you can see in this pic. The remote port is for a bass knob which comes included with the amp. I didn't care to run any more wires and haven't added it yet - I probably never will.
    Cleaned up the wires and added the double sided foam tape to the back of the amp (I actually did that before I started) and pressed it on the metal about as far to the rear of the compartment as I could - ensuring that the spare tire wouldn't rest on the amp or the new wires. In hindsight, I wish I had used industrial double sided velcro here so it would be easier to remove to adjust settings if i ever need to. I may go back and do that and also clean up that RCA mess that irks me.
    Throughout the process I had the rear deck supported using a strap so I didn't have to remove it.
    Sub box in and still have access to the center pass-through.
    Clubs still fit.
    And my tool bag sits nicely on top of the sub (since it is downfiring).
    Not sure if this is going to come across when viewing as I can't even hear the bass when I watch this video on my cell phone. When I put on headphones it is a different story though (hopefully it still comes through after uploading). I wish I had taken a before video, but I didn't. This is streaming from spotify with the bass and treble both set to neutral on the factory settings. If I turn the bass up on the factory settings I can vibrate the rear view mirror. It has made a HUGE difference. BTW, my screen does not look that dusty in person. Maybe time for a detail now...?
    https://streamable.com/01yoj
    Pic album is here: https://imgur.com/a/ZErfx9M
    Veteran Member Three Rings volcomic's Avatar
    May 10 2008
    B9 A4
    Kirkland, WA
    Excellent write-up man I'm sure a lot of people will find this very useful.
    ◊ 20x10 Avant Garde M590's - Brushed Clear ◊ 255/30-20 Hankook V12's ◊ H&R VTF Suspension ◊ APR Tune ◊ ECS Luft-Technik Intake ◊ ECS Carbon Fiber Front Lip Spoiler ◊ ECS Carbon Fiber Grille Accents ◊ Color Matched Reflectors ◊ 15% Tint ◊ 2 JL Audio 12w6V2's ◊ JL Audio 1000/1 Amp ◊
    Senior Member Two Rings Mr. Three's Avatar
    Nov 27 2012
    Aptos, California
    So overall, does the stereo now sound passable? I know the non B and O in all the B9s is pretty super duper weak...
    - - - Updated - - -
    And agree, great job on this write up!
    2023 S3 Daytona PP, S Sport, EMD Springs, EMD 10mm, 034 insert
    Cars of the past: 83 A1 GTI / 83 Callaway stage 2 A1 GTI / 86 951 Turbo Porsche Autothority K-27 / 98 Dinan M3 / 95 3.2 OBD1 M3 / 02 E39 M5 / 88 E28 528i / 08 RS4 / 13 S5 / 14 S5 / 15 S5 GIAC Stage 2 / 16 APR tuned S6 /
    01 996 911 Turbo ByDesign Stage 4 / 2018 S4 DT Tuning and EMD suspension / 2019 Etron Quattro / 21 S4 DT Tuning EMD susp /
    Oct 27 2019
    PNW
    Quote Originally Posted by Mr. Three View Post
    Yeah, totally passable. I had moderate expectations for the new subwoofer given it's a low profile in a small sealed box, but it absolutely hits - I wish the video would have come across better. It will give you the "body feel" you associate with deep bass. Getting the amp dialed was key because I can crank the volume to 100 and get nothing but pure bass with no distortion. It will shake the rear view mirror. The stock system never struggled with highs or mids in my opinion, but now that I've installed the sub I feel like the mids are lacking. I think the stock subwoofer may have been producing a fair amount of the midrange I was hearing pre-installed.
    Jan 23 2020
    UK, Sunderland
    Hey dude this is awesome exactly what I want to, the stock audio in my S4 sucks pretty bad compared to my previous car!
    I've just a few questions as I'm not clues up on audio stuff, I was following you up untill this point, can you clue me up in what you meant, I have the non b&o system as well
    Oct 27 2019
    PNW
    Your amp is looking for 2 channels (2 sets of rcas/speaker wires). Since you'll only have 1 set of speaker wires coming from your factory amp (from the factory sub location) you'll need to split that signal into 2. All you'll need to do is clip the female RCA plugs from the aftermarket amp harness and tie the negative wires and positive wires together with the negative & positive wire that you ran from the factory amp/sub location. Let me know if that makes sense.
