Results 1 to 18 of 18
    Jan 23 2020
    Uusimaa
    Setting cams in time VVT
    Hello all, great to join into this forum.
    I am currently installing cams back into my a4 2.0 fsi. The VVT-technology is new to me, and now I am wondering how to install the intake cam with the cam adjuster correctly to be in time.
    The cam adjuster is now in locked position, so the cam is in its most retarded position.
    The intake cam's timing mark, and cam adjuster gear's timing mark are now seperated from each other. Intake cam can move clockwise, and when these marks line up, cam is in its most advanced position.
    So when installing, is it correct that the adjuster is locked, and cam is in its most retarded position, and then lining cams's timing marks with cylinder head.
    Or does it need to be unlocked, so the adjuster gear's mark and cam's timing mark line up, and then lining them up with cylinder head?
    Don't know how clear my explanation was, but would appreciate it truly, if someone has greater knowledge to this :)
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    You require the cam locking tool to properly set timing.
    Dec 11 2019
    Staten Island
    https://youtu.be/Ob_zr9y1prE
    This looked like an informative video. Gotta get the link count right and you meet to turn the intake cam to get the adjuster to seat right.
    Jan 23 2020
    Uusimaa
    Thanks for reply. I have watched that video already, but it was not telling if the adjuster is locked or unlocked..
    Here is how it looks now, when adjuster is locked:
    https://imgur.com/a/B4YJFYH
    Established Member Two Rings A_Karl's Avatar
    Apr 12 2015
    B7 A4 stage 3
    Buffalo, NY
    I am dealing with a similar issue. I have two VVT units from the 2.0. One moves freely and one is locked. I’m wondering if one is broken.
    When I say move freely. I mean I can hold the camshaft by hand and spin the vvt a couple degrees. Moving the gear relative to the cam lobes.
    Jan 23 2020
    Uusimaa
    Hi A_Karl
    I had the same problem, my adjuster could move quite a lot, like 10-15 degrees. Opened up the adjuster (vvt unit) and found out that the locking pin wasn't locking at all. The pin was slipping from its hole, so i drilled a straight hole for it and now it works and locks.
    Apr 12 2015
    B7 A4 stage 3
    Buffalo, NY
    Thanks for the info! Ill have to take mine apart and check it out. It probably explains the terrible start up noise.
    In regards to the OP, the cam adjuster should be in locked position to set timing?
    Jun 27 2011
    Yea the adjuster should be locked in one position when there is no oil pressure.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Quote Originally Posted by Jubs View Post
    What engine is this photo of?? 3 intake cam lobes.
    Jun 27 2011
    It’s got to be an NA, port injection motor since its 5V and the cams are really pointy rather than round. But, yea no idea...
    -CP
    2017 Q7 3.0t
    Feb 15 2016
    Cambridge,Ontario
    Check out " that's all she wrote thread.
    Adjuster is full detent until.oil pressure pushes it.
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jan 23 2020
    Uusimaa
    But do you install it in locked position and time it in that position?
    Quote Originally Posted by Brillo View Post
    It is from 2.0 FSI 20v ALT engine
    Jun 27 2011
    The cam-to-cam timing is determined by the chain and the number of links between the sprockets, and that isn’t changed by the cam adjuster. So really it shouldn’t matter unless you’re relying on the cam holder tool AND your adjuster is broken, in which case you’re going to have a bitch if a time getting it right.
    If you’re replacing a chain that is already installed mark the chain and the sprockets, take the chain off, transfer (very carefully to ensure they’re correct) the marks to the new chain, then line them up with the sprockets when reinstalling.
    -CP
    2017 Q7 3.0t
    Feb 15 2016
    Cambridge,Ontario
    I don't think we can help you as that is not the same is our 2.0T fsi 16v engines
    1976 Yamaha XS 360
    Jun 27 2011
    I’m sure it operates the same way, with the same spacing between cams and all that.
    That being said that engine was never offered in the US where the majority of us are based so very few here have firsthand experience with the engine. And given how crucial it is to time these engines properly, I’d not operate on assumptions here...
    -CP
    2017 Q7 3.0t
    Jan 23 2020
    Uusimaa
    Oh okay, so that engine is mainly seen in Europe then. Good to know.
    But thank you all for your help, I will figure this out someway.
    Jun 27 2011
    Yea we only got the BPG/BPY/BWT 2.0t engines here in North America. Evidently Audi felt we couldn’t handle any less than 200hp?
    This guide refers to ALT engine code, maybe it will help:
    https://workshop-manuals.com/audi/a4...ain_tensioner/
    In any event, good luck!
    -CP
    2017 Q7 3.0t
    Jan 23 2020
    Uusimaa
    That manual has very useful information of installation. I already had that info, but thanks anyway!
