Results 1 to 17 of 17
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    Coolant reservoir overflowing
    My coolant reservoir overflowing sometime, just repalced the reservoir and still overflowing. New OEM radiator & hose installed 10K miles ago(3 years), just repalce new reservior, cap and clamp. Didnt see any leak, only find white powder under the reservior.
    What cause the overflow? thanks
    B6 Noggy Avant, B8.5 Allroad
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Quote Originally Posted by hkdolphins View Post
    My guess would be either a stuck-closed thermostat, clogged radiator (unlikely since you recently replaced it), or sadly, the head gasket. The coolant is probably boiling off, rather than simply leaking. Does your car overheat?
    Nov 12 2015
    Oregon
    I can second that. Either you have way too much coolant in the system, or the coolant level is rising due to overheating or air infiltration into the cooling system. I would buy a cheap noncontact laser temperature gage and when this happens, check the temperature of the upper and lower radiator hoses and see how far apart the readings are. Another possibility would be a failing water pump that the impeller is spinning on the shaft. Our water pumps are driven off the oil pump gear assembly so I am not sure how that would come into play with the impeller blade.
    My build log
    Veteran Member Three Rings luvsspeed's Avatar
    May 13 2007
    04 S4
    North Carolina
    Check the cap. I had a new cap not hold pressure and it allowed the tank to boil over.
    Dec 03 2014
    SF/CA
    Quote Originally Posted by Zolli View Post
    never overheat, the coolant is clean. its obviously coolant going out from the reservoir escape around the cap and went to the bottom.
    Dec 03 2014
    SF/CA
    Quote Originally Posted by luvsspeed View Post
    how can i know the cap is bad?
    Dec 03 2014
    SF/CA
    Quote Originally Posted by VinnysS4 View Post
    Vinny, thanks for your suggestion. I really don't know when it happened. Replaced the reservoir 30 miles ago, shop fill 3/4 beween min and max (about 1/2 over the middle and high), cleaned the valve cover. Found coolant only at the center line. and white powder on top of valve cover. Really hate to keep checking and add coolant.
    Established Member Two Rings ShootingBrakeS4's Avatar
    Aug 17 2018
    NY/LI
    Happens to mine too, done trying to figure out this engine. All of the problems are intermittent too which makes them even harder to diagnose. I’m driving it till it explodes, f%$k it
    2005 S4 Avant 6spd, engine swapped, down pipes, custom intake, TB heater bypass, 15mm spacers, custom body styling.
    Dec 03 2014
    SF/CA
    Quote Originally Posted by ShootingBrakeS4 View Post
    I totall agree its "intermittent", that's why the shop advise me keep driving until related issue came up to diagnose it.
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Vinny is never wrong, I’m glad he chimed in. Definitely follow his suggestion.
    If it’s pretty obvious that the coolant is coming out from the cap, being pushed out when it reaches boiling (but car isn’t over heating), then it probably IS the cap like luvsspeed said. Did you get a genuine Audi cap?
    I got non-Audi PVC valve and vacuum pumps once. They were OEM suppliers, but they still failed after a couple of months. I paid extra for the genuine Audi ones, and I haven’t had a problem since. That was nearly two years ago, now.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    hahahaha I am getting closer and closer to this every day with my sedan. I've had it 6 years and its at 217k miles now. it is tired and moody
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    May 13 2007
    04 S4
    North Carolina
    The o-ring on it could be damaged. I had an aftermarket cap on for about a month and I got a boil over one day, once I changed back to a OEM cap it never happened again.
    Nov 12 2015
    Oregon
    Well thank you for the kind words. Wish the lady said the same thing. Haha
    I can second the non OEM parts. Lots are crap and fail quickly.
    My build log
    Dec 03 2014
    SF/CA
    I total agree Vinny is very knowledgeable and thanks all his input. nearly all my replacement parts are Audi one or OE (not OEM) one. Acutally i wasn't happy about this cap which i ordered from europaparts.com. It's an OE one (not Audi) one and i guess may be i just order a new Audi to see. thanks
    Veteran Member Four Rings Jdsb6s4's Avatar
    Aug 27 2016
    GL450, GLA250
    I received a coolant refresh package from ecs. I wanted to go OEM but my buddy said l save $100. Never again! The viaco cap doesn’t even screw onto the viaco reservoir so I threw that away and the coolant temp sensor wouldn’t even clip in cause it wouldn’t go in far enough. I forgot the name of the off brand piece. At least the thermostat and housing were OEM.
    Dec 03 2014
    SF/CA
    I replaced the o-ring with Audi one on the OE cap year ago and still the same.
    Nov 12 2015
    Oregon
    Do you have access to a bulb style “block tester “? First things first. Let’s eliminate the possibility of combustion gasses making their way into the cylinders causing problems. Autozone around me loans them out. I think you need the fluid. It’s cheap . I can’t imagine the old cap/Reservoir and a new cap and reservoir all going bad.
    Do you have a scanner or vcds? You should check the coolant temperature temps regularly when it’s hot and see you what you were actually running as opposed to what the gauge tells you. The gauge is basically a dummy gauge and will report the center of the cage between x and y temp. (i’m not quite sure on our car what the temperature is. ) I have seen the gauge stay in the center and watched the reading jump 20° through VCDS. They make a radiator cap tester that you should be able to screw your cap on and check to see if that is the culprit. I would also poke around engine to see if there are any possible leaks anywhere. Any type of depressurization of the cooling system while it is hot will cause the temperature to rise and can cause too much expansion, Which would put the system above the radiator caps pressure level and would cause it to dump some coolant. The coolant tank leaking may very well be in effect and not the cause of your problem.
    My build log
