Originally Posted by
ToastyTT
Are you sure that's correct? On my 2019 TTRS, it was 5w30 LL03, but ETKA now says 0W30 LL03, which is the same as MY2020.
And the Castrol oil they use is just as good as any other. I wouldn't fret too much about it. My 2008 TT was modified with a K04 upgrade and is at 120K miles and still going strong. Little oil use, and it's only ever used the Castrol from the dealer.
Yup I’m sure and work for VW
VW and Audi have switched to 0w30 on all vehicles that use 504/507 spec
I have a 2019 TTRS myself and use the 0w30, but you can without question use the 5w30 504 as well.
Any 504/507 oil will hold the LL3 label. Our TDIs now call for 0w30 when they have been the 5w30 for over 10years now. His engine is pre 2019 which still uses 5w40 in the TTS and TT versions (same as golf r gti s3 ect)
Like the above poster mention, as long as you use the vw/audi specified oil approval (the 50x numbers) you can use what ever brand or viscousity index that suits your needs wants. Just like mentioned before, the intervals in which they are changed at makes the biggest sifference if anything.
Also VW/Audi have now switched there supplier oil from Castrol to now Mobil1
So dealers are now using Mobil1 for your services
