Results 1 to 40 of 46
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    Northern Virginia
    Short Drives Procedure?
    Before my B5 S4, I had a C5 A6 2.7t with the 6 speed that I sold with just over 100k on it. Only drove it on short drives and it ended up being a very reliable car.
    However, my B5 S4 has more miles on it and a lot of my drives are very short. Temp gauge goes to the middle and oil temp goes up to 200 ish.
    My question is, what can I do to ensure I'm not causing any excessive wear? I stay out of the boost whenever I drive short distances. It's all stock for the time being.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Jul 04 2012
    Woodbridge, VA
    Most wear is going to come from cold start. So good oil. And don’t go into boost until it’s warmed up. That’s al you can do
    Mar 04 2014
    Northern Virginia
    Quote Originally Posted by vavJETTAw36 View Post
    I've run 0w-40 on both 2.7t's I've had. I might switch to Rotella though, this shits expensive. Oil changes ever 5,000 miles or 6 months usually.
    Also, see you're in Woodbridge. I'm in Fairfax, know of anywhere that can change my RMS for a decent price? I've used Eurowerks VA for smaller stuff, but I don't want to spend a whole lot.
    2003 Audi S6 Avant
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by R490 View Post
    I usually just do fcp euro exchanges on liquimoly. The shipping is usually about 20 bucks.
    What would a decent price be for you?
    Mar 04 2014
    Northern Virginia
    I'd like to keep it under $700. I'd do it myself, but that's above my pay grade considering my garage doesn't have a lift.
    2003 Audi S6 Avant
    Jul 04 2012
    Woodbridge, VA
    You really don’t need a lift. And unfortunately it’s an engine pull. You’ll never find anyone to do it under 1000 bucks.
    Mar 04 2014
    Northern Virginia
    Really? I was told it could be done with the engine in.
    2003 Audi S6 Avant
    Jul 04 2012
    Woodbridge, VA
    It CAN be done with just a trans drop. But most prefer to pull all of it together
    Mar 04 2014
    Northern Virginia
    I might as well just swap in an 01E for that price.... Found a guy with a complete swap from an Allroad for that same price.
    2003 Audi S6 Avant
    Jul 04 2012
    Woodbridge, VA
    Completely agree.
    I’ll swap your trans and rms for $1000 labor. I would need it for two weeks
    Mar 04 2014
    Northern Virginia
    Completely agree.
    That's a tempting offer. I'm going to try and figure out what else I'd need, since the 01E is out of an Allroad.
    2003 Audi S6 Avant
    Mar 04 2014
    Northern Virginia
    I also have to figure out if it's the rear main seal, or something else. The oil is dripping down onto the RMS and running down the sides, so I just assumed it was.
    2003 Audi S6 Avant
    Aug 24 2014
    Newport Beach, CA
    It could be a few things besides the RMS. Could be the a valve cover gasket leak, cam plugs are easy to check, or the oil supply T junction which I've circled in red (thank you XLR8 for the clear picture).
    2024 M3 Comp xDrive
    Mar 04 2014
    Northern Virginia
    That's what I'm hoping! I'm resealing the valve covers and everything around them.
    2003 Audi S6 Avant
    Dec 10 2013
    Borden, Ontario, Canada
    Can't use the Allroad trans in a B5, since there is no applicable rear diff that will bolt to a B5 rear subframe.
    4.375 final drive in the Allroad vs 4.11 in a manual A6/S4 or 3.511 in auto variations
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Should be pretty easy to tell if its RMS....at least mine was and I had tons of other leaks. Clean the area up well and while under the car in the upper oil pan there’s 2 holes that oil from the RMS can come through and if you see oil coming out it’s definitely RMS or the input shaft seal on trans....either way its same amount of work. If I didn’t explain it well enough lmk and Ill snap a picture
    Mar 04 2014
    Northern Virginia
    Quote Originally Posted by Bordom View Post
    Shit! You're a lifesaver, I was about to seal the deal...
    Same guy selling the swap is offering a full APB 170k on it that's "blown" for $200 USD. Is that worth buying, just to pull parts off and get more familiar with it?
    2003 Audi S6 Avant
    Mar 04 2014
    Northern Virginia
    Quote Originally Posted by Silverex View Post
    Ah, gotcha. These are the areas I've noticed the most oil collecting. Last picture is right at the end of the skid. Oil lines? I think were soaked pretty good.
    2003 Audi S6 Avant
    Dec 10 2013
    See of he'll take $100 for it. Lol
    Sent from my SM-G9600 using Tapatalk
    IG: 24_et
    Sold:
    RIP:
    Nov 13 2018
    Ocean city NJ
    that hole all the way to left dead center. If oil is coming out of there then you know it’s RMS
    Mar 04 2014
    Northern Virginia
    The one with the rust in the middle? Looks pretty dry to me. Fingers crossed regardless.
    2003 Audi S6 Avant
    Nov 13 2018
    Ocean city NJ
    No the one that’s all the way to left and is half way cut off in picture. Clean everything up and then stick a finger up there after running car and see if it’s wet.
    Nov 13 2018
    Ocean city NJ
    Could have drawn a better circle around just the one but it’s the one on far left that circled
    Mar 04 2014
    Northern Virginia
    It leaks the most when the car is just sitting, does that sound right? I've been down there before and I don't recall seeing anything.
    2003 Audi S6 Avant
    Mar 04 2014
    Northern Virginia
    Slightly better picture of it,
    2003 Audi S6 Avant
    Nov 13 2018
    Ocean city NJ
    Stick a finger in there and see if it’s wet, highly doubt oil would go up in there unless the RMS is leaking.
    When I had issues with RMS it did seem to leak more sitting.....then after I really cleaned it up well and got under it while running I noticed exactly where it was coming from.
    Sucks but what I’ve learned is instead of wasting time dicking around with motor in car it’s way easier to just pull the motor off the rip and fix everything. The amount of time I’d waste looking everything over and trying to fix problems with motor in the car I could have had it out and sitting on a stand. Definitely looks like you have a few issues to fix which will probably require a engine pull for at least one of them anyway.
    Mar 04 2014
    Northern Virginia
    Ah, gotcha. I'll have to take another look next time it's nice enough out.
    Fortunately, the only real issue I have with the motor itself is this leak and a coolant hose. I'm doing a ton of preventative stuff and once the 5HP lets go, I'll probably just get an 01E going and yank it out.
    2003 Audi S6 Avant
    Nov 13 2018
    Ocean city NJ
    Those “only” issues can require a pull unfortunately..... where is your coolant leak? Hope it’s not a turbo
    What other maintenance are you going do? FYI doing anything with motor in car takes about 2x as long regardless of how accessible it is....at least for me it is
    Mar 04 2014
    Northern Virginia
    Rear coolant heater core hose. It's a very, very minor leak. I already have the part.
    I'm doing plugs, accessory belt, valve cover gaskets, cam seals, plugs, thermostat, possibly the timing belt (Depending on how it looks), possibly coil packs as well. Any other suggestions for while I'm down there?
    And yeah for sure on the time thing. When I had to do the ABS module on my A6, it had me ready to off myself.
    2003 Audi S6 Avant
    Nov 13 2018
    Ocean city NJ
    That hose is kinda a pain but definitely doable I had to replace mine a few months back. Get ready to have a bunch of cuts on your hands. Lol
    If your doing all that work including timing belt I’d definitely pull the engine, sorry if I sound like a broken record. I feel like removing the front end is at least half the work anyway and in long run it will save ya time plus you can get a great look at everything and replace whatever looks bad. When I pulled my engine to do RMS it snow balled pretty bad from there and ended up building the motor but at the very least I was going replace every gasket/o ring/ bunch of hoses etc. Check out my build thread and if you have any questions just lmk
    Mar 04 2014
    Northern Virginia
    Fun, hah.
    In a perfect world, I'd just go ahead and pull it. But for the time being, I just want to get it in decent enough shape until I have the cash to get upgraded turbos and the like. I've also got to make my garage a little more comfortable. I do appreciate the input though and I totally get what you're saying about just going for it.
    Luckily, I somehow happened upon the previous owner of my cars build thread and he seems to have replaced pretty much every soft hose in there.
    Do you have a link for your build?
    2003 Audi S6 Avant
    Nov 13 2018
    Ocean city NJ
    Well my PO replaced everything also unfortunately he didn’t do a very good job and once I had it apart I wasn’t chancing it or planned on pulling motor again so I redid everything. Plus ordering from FCP for lifetime warranty had me buying more stuff then I planned.
    Here’s my build thread.
    https://www.audizine.com/forum/showt...J’s-Stg3-Avant
    Mar 04 2014
    Northern Virginia
    That's true. I ordered all of my parts, except for the axle from FCP.
    Awesome build! I've got to read through the whole thing.
    2003 Audi S6 Avant
    Mar 04 2014
    Northern Virginia
    Silverex, I did what you suggested.
    Both of those holes look pretty dry to me. Any thoughts? I had absolutely convinced myself it was the rear main seal, but I'm resealing as much as I can regardless.
    2003 Audi S6 Avant
    Nov 13 2018
    Ocean city NJ
    Cam plugs in the back, cam chain tensioner, VC, or turbo oil lines are the only spots I could see oil coming from back there
    Mar 04 2014
    Northern Virginia
    Ya know, that's actually a huge relief. Luckily, I've got all of these gaskets and whatnot to install. Hopefully that'll take care of these leaks.
    Fingers crossed it's not turbo oil lines. I'm guessing that warrants an engine pull. What's also really odd is that my oil leak has actually slowed down in the past week, not quite sure how that's possible.
    2003 Audi S6 Avant
    Nov 13 2018
    Ocean city NJ
    I’m pretty sure the turbo oil lines can be done with motor in the car it’s the coolant ones that are a PITA
    Mar 04 2014
    Northern Virginia
    Well that's a positive, hah.
    2003 Audi S6 Avant
    Mar 04 2014
    Northern Virginia
    So it turns out the oil leak doesn't happen at all when the car is jacked up from the front. Not one drop in 24 hours.....
    Hopefully even more evidence it ISN'T a rear main seal.
    2003 Audi S6 Avant
    Dec 10 2013
    Jack the rear up. Probably a front crank seal
    IG: 24_et
    Sold:
    RIP:
