Results 1 to 40 of 60
    Veteran Member Four Rings audi_s5's Avatar
    Jan 04 2009
    WI, USA
    Which Carbon Fiber Intake System - AWE, IE, or APR
    Please help me choose and why? Car will remain relatively stock for first year or so.
    Leaning towards APR cast inlet with AWE closed system.
    ECU and TCU will most likely get APR stage 2 down the road.
    Thanks for your feedback
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    The main restriction in this system is the turbo inlet pipe. Fix that, and get the power. So, go with the APR Inlet and rear inlet tube attached to the factory airbox (if you want to keep it quiet on a budget). If you want more sound and more flow, pick up the front filter too.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Jan 04 2009
    WI, USA
    Arin -
    Thanks - placed order for inlet system at this time
    On back order - any ETA?
    Veteran Member Three Rings signde's Avatar
    Apr 07 2019
    nashville, tn
    you could always order it from another vendor if the backorder takes a long time.
    https://www.uspmotorsports.com/APR-2...-and-TTRS.html
    Audi 8V RS3 | Porsche 997.1 Turbo | VW MK4 R32 | Porsche Macan Turbo
    Dec 05 2019
    MONTREAL
    UNITRONIC!!!
    Nov 14 2018
    Denver%2C%20CO
    I am selling an Integrated Engineering intake with less than 500 miles on it if you are interested shoot me a text at 561-789-9493
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    We all know these $1000 intakes make like no power right?
    Stage 2 Banner Advertiser Three Rings Brian@Unitronic's Avatar
    Jan 11 2019
    PA
    Quote Originally Posted by o1turbo30v View Post
    Disagree 1000%
    Uni 4" inlet and intake would be my suggestion
    All the flow figures are posted and Dyno figures by end users to back it up
    Brian
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by audi_s5 View Post
    Arin -
    In stock I believe. All orders list as "backordered" until the order is entered in our system.
    Oct 02 2017
    Unless you have at least 1 dyno to back up your statement you’re wrong as proven by independent customer dynos already posted. Stock turbo cars absolutely benefit from an upgraded intake.
    Veteran Member Three Rings Jeff_Jeske's Avatar
    Nov 24 2018
    Madison WI
    To the OP.... congrats on the order. Where in Wisconsin are you located? There are Lots of WI people in here if you need help or advice just reach out.
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by Brian@Unitronic View Post
    Disagree 1000%
    Brian
    Quote Originally Posted by OE2 View Post
    Sorry guys, i guess we all have different opinions of "improvement", spending `$1000 for 6-10hp and 10-12ftlbs gains on a stock tuned car i guess technically is an improvement i stand corrected, one could argue you'll see that much change just in switching gas stations but i digress
    Stage 1 more than you RS3
    Oct 04 2017
    SFLA
    funny how one of the best intake that makes more power than most mentioned was not on the list lol rookies.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I am not going to say that I disagree with you but beside the ECU tune what makes more power after that? the downpipes are as expensive and they are a PITA to install plus you have to go to stage 2 at that point. The inlets are proven to make power but don't cost as much as the air filter. The complete air intakes are also proven to make power.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Established Member Two Rings OCTA1NE's Avatar
    Oct 16 2018
    E46 M3 CSL race car, E70 BMW X5 40D.
    Sydney/Australia
    Quote Originally Posted by speeddemon69 View Post
    Which one are you referring to?
    Oct 04 2017
    SFLA
    Quote Originally Posted by OCTA1NE View Post
    Jul 13 2018
    Winnipeg, MB, Canada
    $1000? Try $1500+
    Unfortunately everything has to be blinged-out with CF these days (even when you drive around with your interior removed)
    Dec 30 2016
    Keller, TX
    Quote Originally Posted by S3DUDE View Post
    I went from a 3" inlet and 3.5" HG Motorsports inlet tube / stock airbox to a UNI 4" inlet and AWE intake system. Picked up a real 2 mph in the eighth mile and a solid 3mph in the quarter on all passes.
    That is way over 6-10hp gain...
    Just my results - these where on E85
    Aug 07 2019
    Toronto, ON
    Quote Originally Posted by TheContrarian View Post
    $1000? Try $1500+
    Lol exactly. Would like to see a comparison between these $1000+ full CF intake systems w/ inlet and just buying the forgeline inlet and hardpipe for <$500 and leaving the stock airbox in place
    Dec 30 2016
    Keller, TX
    I had a 3" Unitronic Inlet and a bigger inlet pipe and stock airbox. Mine is a pretty good example is it not? It picked up a real 30+ whp to trap 3mph higher...
    Jul 12 2018
    UK
    The intakes will make those small gains on an 'OTS' tune at Stage 1, for many people. They are not calibrated with an intake in mind.
    Go stage 2, and you need it to get the most out of the tune. Or fine a stage 1 tune that takes advantage of the extra headroom, or go custom, you'll see a fair increase. If you gain 90-100mbar at the inlet with a PR of 2.5-3.0 that's 3-4psi in theory at the outlet
    If you want best bang for the buck, spend out and stay at stage 1 with an intercooler. Or go stage 2 and fit the lot and gain about +60% of the stage 1 increases, but with 2k+ more hardware (in my opinion it's well worth it). Personally I'd go Uni full set or AWE.
    The IE intake with stock turbo inlet gave me most of the measured gain, I did fit a turbo inlet but not much in it, at some point I want to explore that a little more as most claim the inlet should give a big gain but at least at stage1 it didn't. Quite possible at stg2 it's alot more restrictive, but i didn't care to refit and measure stock again.
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    My thoughts exactly lol
    I just picked up the Unitronic 4” inlet/intake myself, can’t wait to install it. It’s the best setup on the market in my opinion. Although, I think it still remains to be seen if the stage 3 Eventuri intake is best for 1000+ hp applications. The original kit was a flop from what I’ve read.
    Nov 13 2018
    WI
    Hello fellow Halverson. Would sell you my IE intake, too :)
    Jan 04 2009
    WI, USA
    Quote Originally Posted by Jeff_Jeske View Post
    In Appleton area
    I have 3 other Audi’s with stage 2 or 3 APR setups
    Just learning on 8v 2.5 platform
    I had opportunity to purchase new AWE cf intake setup for $1100 - retail $1400
    Also have ability to order iPe full exhaust for 1/2 off - also new
    Promised wife this one would remain relatively stock for a bit
    Ordered APR inlet system and shipped today
    Glad to see some good discussion across the board
    My car doesn’t even have 500 miles on it yet ;)
    Senior Member Two Rings usaf655's Avatar
    Mar 12 2014
    Florida
    Does anyone have any argument against AWE? Because from looking into these options as well, I saw AWE as:
    -Cheapest option
    -The largest diameter (even if it wont necessarily be fully utilized on OEM turbo, but why limit oneself?)
    -Granted new, no issues reported
    The first item alone was realistically enough to drive me to this intake, I purchased mine for $1100 as well. If competitors are able to beat this, I would have considered an alternative to AWE.
    2018 Florett Silver RS3
    2019 Florett Silver Q5
    Sold 2007 Brilliant Red A4 2013 Estoril Blue Crystal S4
    Jun 11 2012
    Corona, CA
    Quote Originally Posted by usaf655 View Post
    -Cheapest option
    I don’t know if I have an argument against AWE, but I’ll share my logic in going with Unitronic over AWE as those were my 2 options. The price of the Unitronic is actually cheaper:
    Uni $1299 + $69
    Vs
    AWE $1395 + $100
    And that’s actually a sale price as well. Looks like the normal price is $1468.
    If you look at the Unitronic site vs the AWE site, it goes into a lot of detail into the research and development and also the testing. Both of the these intakes dropped at more or less the same time I think, but the Unitronic intake is sold out while the AWE intake was released with a sale price and is easily attainable. Larger doesn’t necessarily mean better and their intake could potentially be less efficient. I’ve seen proof the Unitronic intake improved performance from the IE intake which has been used in setting plenty of records by Iroz Motorsport. So if I had to guess, the bigger intake isn’t necessary until you’re north of 1000hp.
    It is pretty, though. Maybe it’ll outdo the competition, until we get somebody on the dyno/to the track with one, we won’t know. A lot of the more active guys out there are done testing intakes too, so hopefully somebody steps up eventually.
    Either way, I think you’re definitely getting a great intake. None of them are going to be that much better than the rest. And it also mainly depends on your end goals that’ll decide what’s best for you. I know somebody that drilled a giant hole into the side of their IE intake box to allow more air into the motor because it became a restriction. But that was over 900whp.
    Jun 01 2007
    NOVA
    Quote Originally Posted by xliv View Post
    I'l let you know half of that comparison. I went 11.4 @123 on the APR Stage 1 91 tune. Just went to 1+ after adding the Forge inlet & hard pipe..pretty confident the car will go 11.0. I'm not in the camp willing to pay another $1200 for a 10.9 instead.
    Sold // 2018 RS3 - Unitronic TTE700 / BoostLogic / 034 everything / BBS RI-A / etc
    2023 SQ5 - stock + BBS CI-R
    2024 Wrangler 392 - BC Forged LE81 + 37" KO2
    2009 Corvette Z06 - HCI / BC Forged MLE215
    Mar 12 2014
    Florida
    Quote Originally Posted by mtwallace85 View Post
    Uni $1299 + $69
    Vs
    AWE $1395 + $100
    When I bought my AWE, it was $1185 on sale from HS Tuning. So I would just wait to compare sale prices IMO. AWE is also on backorder, I put this order in shortly after black friday and just delivered a few days ago. AWE is build the intakes in batches and of course allocations to vendors is limited. At the end of the day, I doubt anyone will notice a difference except how much their wallet weighs.
    Established Member Two Rings Dubonfire's Avatar
    May 21 2014
    I don't see the point of a carbon fiber intake personally. My hood is always closed.
    Assuming you have a 4-inch turbo inlet
    My choice would be if I had to do it again:
    CTS Turbo 4 inch intake
    034 Heat Shield
    CTS turbo or SRM Throttle inlet
    Cost-wise it's pretty much the same and i think you would get better results than a carbon fiber intake on its own.
    If you are going stage 2 you are gonna buy an intercooler which is probably the most important component to keep IAT down. (I'm no engineer so don't kill me).
    MK7R Sold
    2018 Audi RS3 IMS 710H Sold
    2022 S3 8Y Project: FBO Racingline Stage 2, tons of Racingline & Superpro suspension/handing mods
    Oct 17 2018
    Carlsbad CA
    Stay away from apr the turbo inlets are coming loose and their 4” carbon pipe is collapsing. They may replace the pipe when it cracks free or charge but you’re stuck with an Inlet system that will continuously come loose even with their “updated nordlock washers and using loctite“
    Oct 02 2017
    Quote Originally Posted by V8Bait View Post
    I haven't heard about the pipe issue, any pics of where it collapses?
    Aug 23 2008
    Auburn, AL
    The inlets are not coming loose, and the pipes are not collapsing.
    Oct 17 2018
    Carlsbad CA
    Right where all the heat is. That’s where it connects at the turbo inlet on the bottom side where it sits above the turbo manifold. You can see how discolored it is in that area. Not sure why they act like there isn’t an issue I know of a few that this has happened to.
    - - - Updated - - -
    Quote Originally Posted by Arin@APR View Post
    Hm see above. The poll says otherwise bud, 10 of 26 people have issues.
    Oct 02 2017
    thanks, that's scary to see.
    May 01 2018
    Virginia
    Yeah my APR intake cracked with VERY little pressure on the clamp. I have an AWE now, i love it, but slight hairline crack around where intake pipe connects to the box after a few runs.
    2014 SQ5 DP/104 Octane 11.001 @124.55
    2019 TTE RS3 FBO
    2021 GLC63 S AMG
    Junior Member Two Rings speeedfrk's Avatar
    Jan 30 2019
    Milwaukee, WI
    Just found a crack in my APR intake above the turbo also. I was very careful to not overtighten the clamps but it seems that it did not make a difference. Nothing loose on the inner portion of the intake so I'm not too worried about it...more just disappointed in the structure.
    Sent from my Pixel 3 XL using Tapatalk
    Aug 04 2018
    2017 Audi Q7, 2022 Silverado 2500HD
    Sacramento, CA
    UNI uses an embedded metal (SS?) sleeve in the ends of their CF tubing to prevent this collapse cracking
    2018 Nardo Blk Optic RS-3, DA, RS Design, Dynamic Package
    UNI Stg 1+ (E85) ECU, Stg 2 TCU, UNI 3"Turbo Inlet, IE Intake, 034 St.Stl Intake HTshld, Eurocode FMIC, IROZ Eng Oil Catchcan, 3D Prntd DSG Vent, OEM Euro Catless MidPI, CTE Exhst Valve Cont., 034 Upr/Lwr DgBne Insrts/Billet Arm, MSS Springs Fnt Track/Rear Sport, Eurocode SWB E.Links/Rear Strut Brc, 034 Rear SbFrm Mnt Insrts, ECS Rear Diff Mnt Insrts, Signature SV303S/Gloss Blk Barrels/Flat Blk Spokes/Slvr Hdwr, F 19x9.5+41, R 19x9.0+43
    Dec 05 2010
    Los Angeles, CA
    Quote Originally Posted by NelsDMAX View Post
    That’s good to know. Do they also use anything different than APR to keep their inlet from coming loose?
    2019 Nardo with all OEM options
    Jun 11 2012
    Corona, CA
    It’s actually just one end, not all of them. The intake tube end that mates up with the turbo inlet has it, presumably because of the increased heat? The other ends do no have this. Was a little disappointed when I noticed this with my kit, but it’s still a very solid kit and I’ve yet to hear of people having any issues with the turbo inlet coming loose, or anything else for that matter.
    Sep 22 2005
    Somewhere Within
    The other ends are double beaded which adds structural rigidity.
