Originally Posted by
CarsandChicken
Hey Guys,
I'm in the process of wiring my blackvue dashcam right now and am wondering if anyone knows how to remove the driver's side A pillar. I know that you usually remove the torx first behind the airbag stamp, but there is none when you have the B&O stereo. Does anyone know how to access the A-pillar screws with the B&O system? Not a fan of just tucking them under the pillar.
Exactly like @JWreck said. You should be able to tuck it under the trim for the room lining across the line for the pillar separation then under the rubber weatherproofing. Way easier process than full removal.
Update: Added pics. I used a trim removal tool to gap the trim and push the cords through. Had to use the tools to pull the cords out so you could see how I routed them, it's super easy and works for both driver or passenger side if you want to go the obd powered route.
