Hey hey guys,
Trying to tackle another problem on my 2002 A4 quattro 1.8t. After finding and fixing a great handful of problems with this car, another problem has arose that has put me in a pickle. After taking my car on decent drive, about 100 miles or so, and parking it for a few hours, it seems to have lost spark and will no longer start. I started by pulling the fuel line and injectors to verify I was getting fuel, which I was. After running a vagcom test, I had a couple of codes that were never found before.
16712 - Knock Sensor 1 (G61): Signal too high P0328 - 001 - Upper limit exceeded - Intermittent
16395 - Bank 1: Camshaft A (intake): Retarded Setpoint not reached (Over-advanced) P0011 - 002 - Lower Limit Exceeded
16727 - Camshaft Position Sensor (G40): Signal Too High P0343 - 001 - Upper Limit Exceeded
So with this information at hand, I found some information saying that it could be a Cam position sensor gone bad. Since I have a complete head sitting in the garage, I pulled the sensor from that head and installed it on mine to no change. I pulled the valve cover to check the condition of the cam adjuster feet to find both were complete and doing their job properly. Doing more research, I found that the crank position sensor might be the cause of the no-spark and replaced it with a used one from a passat 1.8t I had laying around. No change at all. Is there any information these codes might be telling me that I am missing? I am currently looking at the injector wiring harness as some of that wiring have small cracks and I figure the cam sensor wiring might be grounding on some of those, but have only found damage on the injector wiring and not the cam sensor wiring. After checking voltage at the three cam sensor wires I am getting zero on the ground, 4.98v on the next wire and 10.3v on the last green wire. Could the ECU be at fault for the lower voltage on the last wire or am I in the right direction looking for a short? Even with the cracks, all of the injectors fire properly and very strong.
I turned the key on and was checking power to the coil pack wires. I do get 12v on each connector end but when I try to ground out a spark plug to check spark I get nothing. I swapped out the coilpacks to no change. Are the fuse terminals that run the ECU powered with the key? I haven't checked power to the fuses that control engine management yet. What is the voltage I should expect from these?
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 518 AF
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 63251
3 Faults Found:
16727 - Camshaft Position Sensor (G40): Signal too High
P0343 - 001 - Upper Limit Exceeded - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
19537 - Engine Temperature too Low
P3081 - 008 - Implausible Signal
Readiness: 0110 1101
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63251
6 Faults Found:
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
30-10 - Open or Short to B+ - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
00819 - High Pressure Sensor (G65)
07-10 - Signal to Low - Intermittent
01206 - Signal for Duration of Ignition: OFF
27-00 - Implausible Signal
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 63251
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-10 - No Communications - Intermittent
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63251
2 Faults Found:
01333 - Door Control Module: Rear Left (J388)
49-00 - No Communications
01317 - Control Module in Instrument Cluster (J285)
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03200
Shop #: WSC 00223
WAULC68E53A111162 AUZ6Z0B0197969
1 Fault Found:
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
No fault code found.
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63251
4 Faults Found:
01134 - Alarm Horn (H12)
00955 - Key 1
35-10 - - - Intermittent
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63251
2 Faults Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
00774 - Level Control System Sensor: Left Rear (G76)
28-10 - Short to B+ - Intermittent
Address 56 -------------------------------------------------------
Controller: 8E0 035 195 F
Component: symphony II NP2 0051
Coding: 01201
Shop #: WSC 08376
End -------------------------------------------------------
The power and immobilizer codes are still around from some key issues I had a month or so ago, same with the power (unplugging battery while the car sits). Is there anything else here that would clue somebody in? Should I invest in another set of Crank and Cam sensors in case the two each I have are bad?
Maybe this will give somebody some ideas - back on December 10th (When this actually happened) these were the first engine codes given, after clearing them, none have returned, (only the P0343 Cam signal too high comes back)
Coding: 0016701
Shop #: WSC 63251
5 Faults Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 002 - Lower Limit Exceeded - Intermittent
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 001 - Upper Limit Exceeded - Intermittent
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
Readiness: 0000 1100
Again, the car ran great for a nice long drive, it was only upon trying to start it hours later is when it didn't want to start. Any direction you guys might point me? I've been fighting this for over a month now, with a lot of things tried and no change what-so-ever.
