Anyway when removing the vacuum pump I noticed that there was only a flat PLASTIC (about 1/8 wide) seal in place. There was no additional rubber seal - just the hard plastic one. I removed it and only replaced it with a new vacuum pump RUBBER o-ring that I got from ECS Tunning. Was I suppose to put on the flat plastic washer and then the new round rubber vacuum pump o-ring on top of that OR only utilize the hard plastic washer? I did notice that my pump didn’t have a groove for a rubber o-ring but I thought that maybe it just got flat once I installed it.
Here’s a pic of the hard plastic o-ring. Also, stupid question. I noticed that there’s only TWO bolts that actually bolt the vacuum pump on to the back of the timing chain cover. There’s one bolt almost right next to the vacuum pump line (drivers side) but it doesn’t look like it goes to anything. Am I missing a bracket or something? Note that the only two bolts that hold the vacuum pump on are the one on top and the one slightly below and towards the passenger side (it’s the one that also has the ground wire attached to a piece of metal, which the bolt goes through).
Anyway your help is greatly appreciated as I can’t seem to find any exploded diagram right now which shows me which seals are needed for the vacuum pump.
Thanks
