I'm looking at a Q5 of SQ5 and it looks like getting brakes is going to be a PITA for the SQ5 fronts, they seem much more expensive and much less options with pricing being 2-7x as much. I'm wondering if I'm missing something here and I wonder if the Q5's front brakes can perform as well as the larger SQ5's with better rotors and pads?
SQ5 Front rotors - 380mm or about 15"
Q5 Front Rotors - 345mm 13.6" (though many replacements list 330mm as replacements)
Rear rotors both models - 330mm or 13"
I was looking at different options for replacement rotors for the front brakes of SQ5's & Q5's and I've seen many places list the 13.6" rotors as fitting the SQ5 and there seem to be a lot of options in the 320-330mm range from $30 - 500 a piece with a lot of nice performance rotors in the $150-200 range.
From what I've found the SQ5 has 380mm or ~15" front rotors and there seem to be much less options for these and many sites don't even show pics of the rotors, they just like "OE" or "direct replacement" or something. Many are $500+ per rotor on many sites. The problem is I can't tell why these are so much more expensive b/c they aren't even as light as many of the much cheaper 320mm rotors.
The weight of some of the performance 320 rotors were 6-8lbs (even saw one at 4lbs, but it was an Amazon listing so it may have been wrong - they weren't even that expensive ~$140 IIRC so IDK, sounds too good to be true). Now these rotors for lower price range from 14-25lbs which is a huge difference in weight on the suspension compared to the 4-8lb rotors. IDK how much difference it would make in driving but I suspect it would be noticeable.
There was very little info on weight on many of the 380mm and 345mm rotors (front rotors) but the price for the 380mm were basically all really high.
Has anyone found good replacement rotors for the SQ5 in 380mm size? Would it make any sense going to 345 rotors up front and even swapping calipers and just buying better 345mm rotors?
