Results 1 to 40 of 42
    Jan 05 2019
    '01 B5 S4, '10 A4 Avant, '05 Ram Cummins
    New Port Richey, FL
    Noob BBS CH-R wheel fitment questions
    Hi guys. I'm looking at a set of 18x8.5" BBS CH-R's locally, et35 for my '01 S4 with a Stoptech ST40 BBK, H&R sport springs, front fenders lightly pulled. I was hoping to figure out if they'll fit over the ST40's before I buy them, and also anyone's BTDT on fitment, and also if I'll need spacers (10mm, 12mm, front/rear?) and hub centric rings.
    I've been reading through the wheel/tire thread on here, just so many variables I'm not sure. I was planning on going with either 225/40/18's or 235/40/18's.
    Thanks in advance!
    1986 4000CS Quattro - sold
    1987 5000CS Turbo Quattro - sold
    1991 200 20V Turbo Quattro Avant - sold
    2001 B5 S4 sedan
    2010 A4 Avant
    Jan 05 2010
    burnaby british columbia
    You should be good with no spacers. If you do need them 3mm will do. Both tire sizes will fit.
    Quote Originally Posted by 199120020v View Post
    Thanks in advance!
    Sent from my SM-G960W using Audizine mobile app
    Aug 24 2014
    Newport Beach, CA
    Go with the 235 width tires, it'll fit and fill out the 8.5" wide wheels better.
    2024 M3 Comp xDrive
    Veteran Member Four Rings DolphinV8's Avatar
    Feb 18 2004
    18x8.5 ET35 CHs clear 4-pot Brembo GT & Stoptech ST40
    If you opt to go with 235's, go with skinny ones like Conti DWS.
    Veteran Member Three Rings avant1987's Avatar
    Jun 06 2016
    PA
    Quote Originally Posted by DolphinV8 View Post
    Seconded skinnier 235s include tires from falken, conti and Toyo.
    Projects
    2001 Nogaro S4 Avant 6-speed - RS4 Widebody Conversion
    1995 Audi 90 Sport Quattro 6-speed
    Junior Member Two Rings
    Jun 01 2004
    San Jose, CA
    Can you get the CH-R's in ET35 for 5x112?
    My 18x8.5 5x112 are ET38 and required front spacers to clear the stock brakes. Thought the only options for 5x112 CH-R's was ET47 or ET38.
    Regular CH wheels are available in ET35, you sure you are not looking at those?
    2001.5 Nogaro S4 Avant
    Jan 05 2019
    New Port Richey, FL
    I could be wrong on the "R" part. I attached an image of the wheels, if you zoom in you can see ET35 I believe, but I haven't seen the wheels in person yet. Feel free to correct me.
    2001 B5 S4 sedan
    2010 A4 Avant
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Yep those are regular old CHs. Great wheel - not super light but a nice and strong.
    Make sure to get a set of taper seat lugs. Looks from the photo that the current owner might be using ball seats with them (eek!)
    225s work well with these but do give a tiny bit of stretch. I have tried running 235s on these (Toyo Proxes) but get some minor rubbing up front.
    Jan 05 2019
    New Port Richey, FL
    Ok. So the ET35 should clear the ST40's then is what it sounds like? I'm kind of on the fence about the tire size. I'm always a fan of putting a wider tire on, but not a fan of them rubbing too much also... Tirerack has a smoking deal on some Cooper's for $100ea. In 235/40/18 that I was going to go with, tread width is 8.2".
    I think I've read on AZ that you can get lugs directly from BBS USA, so I might just call them.
    On that note, for lug length, it sounds like the general consensus is that spacers will not be required front or rear with ET35? Does anyone have a shot of their CH's on the front end with or without spacers?
    Thanks for all the help 👍
    2001 B5 S4 sedan
    2010 A4 Avant
    Feb 18 2004
    CH012 w/ Brembo GT F&R. Stoptech calipers are skinnier than the Brembo ones.
    Jan 05 2019
    New Port Richey, FL
    Man that's a good looking car! What offset are your wheels? Any spacers?
    2001 B5 S4 sedan
    2010 A4 Avant
    Feb 18 2004
    CH012 is 18x8.5 ET35. No spacers.
    Jan 05 2010
    Bbs ch et 35 with 5mm spacer 225 40 18
    Those wheels cleared 8 piston brembo caliper from b7 rs4 with no spacers, but it was very close. IMG-20110222-00039%20(2).jpg
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    Quote Originally Posted by avant1987 View Post
    Another narrower 235/40r18 is the firestone firehawk indy 500. Have on several cars and one of best bang for buck summer tire going...
    Jan 05 2019
    New Port Richey, FL
    happy2B5; I had those tires on my Challenger R/T and loved them. I don't think you can beat them for the price. I'm either going to get them in 235/40/18 or the Coopers that Tirerack has right now for $100 each also in 235/40/18. The Cooper (8.1") is a bit wider than the Firestone (7.8") for listed tread width.
    2001 B5 S4 sedan
    2010 A4 Avant
    Jan 05 2019
    New Port Richey, FL
    replica_rs4; very nice car! Mine is also silver. The CH's look great on there! Do you get any rubbing?
    2001 B5 S4 sedan
    2010 A4 Avant
    Aug 20 2018
    Las Vegas
    Ch 012 with 245/35/18 no running at all and no stretch 5mm spacer in the rear
    Jul 18 2009
    I have them on current s4 on 18x8.5 et35 wheels. No rubbing no spacers and the car is quite low at sub 25 ftg...
    Jan 05 2019
    New Port Richey, FL
    Happy2b5 - do you have a picture of your car/wheels?
    2001 B5 S4 sedan
    2010 A4 Avant
    Jul 18 2009
    I can take one...quick cell phone quality. Sorry
    Jul 18 2009
    And to parrot off_set post above, I have run 245/35r18 on 9" wide wheels on previous S4 and liked them a lot. 245/35 has an ever so slightly smaller overall rolling diam than even a 225/40 in like for like tire brand/model. And obviously even less than 235/40...the 35 profile is livable with the 245 width. Not too harsh.
    For reference...
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    Take some time to look through the wheel and tire thread, lots of good examples in there too!
    // 2001.5 Pearl White B5 S4 Sedan 6MT
    Jul 18 2009
    I think he has. It can be overwhelming but agree lots of answers to most wheel/tire combos ?'s in that thread...
    Jan 05 2019
    New Port Richey, FL
    Thanks guys!! Lots of great info and thanks for the pictures! It's one thing to talk about how something but seeing it is a whole different ballgame. I'll hopefully have them fairly soon and will post up with pictures on the car 👍
    2001 B5 S4 sedan
    2010 A4 Avant
    Jun 06 2016
    PA
    Not to go off topic but I love the advan rs2s on the imola yellow sedan. Awesome wheel choice
    Projects
    Jul 18 2009
    Miss that one
    Jul 18 2009
    Please do post up final decision. Hate unfinished threads. We all like to see the end results...
    And to add to discussion, we had bbs ch 012 on an avant. I was running 225/40's on those. I was using spacers, just for personal aesthetics and not to clear brakes. Honestly, stock hp2 calipers can be more of a clearance issue than a lot of reasonably sized bbk like st40's.
    Aug 20 2018
    Las Vegas
    I went 245 for the extra contact patch and to fill out the 8.5” width. The car actually had 245/40 that it came with on some advans and it was too tall of a sidewall for my taste
    Veteran Member Four Rings Gujuhammer's Avatar
    Oct 07 2010
    02' Avant
    Florida
    I have a set of Ch012's and was waiting for the spring before purchasing tires. This thread was very helpful and I think I'm going to the 245-35-18 route, thank you.
    Jan 05 2019
    New Port Richey, FL
    Hey guys! Finally got my wheels on! No fitment issues. Ended up going with the Firestone Indy 500's in 235/40/18. Thanks again for all the help and pics!
    2001 B5 S4 sedan
    2010 A4 Avant
    Apr 07 2011
    Home of the mighty beaver
    watch for cuts on the outside of the rubber up front. Especially if fenders are not rolled.
    Jan 05 2019
    New Port Richey, FL
    Ok, will do. The front fenders are rolled, back ones are not.
    2001 B5 S4 sedan
    2010 A4 Avant
    Apr 07 2011
    you probably will be fine.
    Jun 13 2009
    Colorado
    Rears are rolled/flat from the factory. You should be fine with rolled fronts. The car looks fantastic! CH's are one of the best wheels for the B5.
    Jul 18 2009
    Looks awesome man. Classic, classic, classic!
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    My favorite wheel model, CH's are classic.
    Jan 05 2019
    New Port Richey, FL
    Also, the CH's clear the Stoptechs much better than the 17" Avus wheels. I probably have 1/4" between the caliper and rear face of the wheel spokes. There was hardly any clearance at all on the Avus.
    2001 B5 S4 sedan
    2010 A4 Avant
    Junior Member One Ring
    Feb 16 2015
    BG
    Quote Originally Posted by off_set View Post
    Im considering getting same size of tyres. Were 5mm spacers needed to clear the rear uprights? And are your fenders rolled? Thx
    Sent from my LM-G710 using Tapatalk
    Aug 20 2018
    Las Vegas
    No I just ran spacers for the look in the rear , I’ve recently switched to bbs rsii’s and no longer run spacers on the rear
    Feb 16 2015
    BG
    Thanx for the info. Do you remember what make were the tyres and your front fenders rolled?
    Sent from my LG-V500 using Tapatalk
