Results 1 to 7 of 7
    Senior Member Three Rings Marlon177's Avatar
    Nov 04 2010
    2016 CLA250 4Matic
    NY/South Jersey
    Need Supercharger belt tensioner and idler torque spec
    Will be replacing both supercharger belt tensioner and idler, but I can’t find the torque spec. Does anyone know? Thank you in advance.
    Senior Member Two Rings ellwood's Avatar
    Feb 12 2015
    16 SQ5, 21 M340i
    PA
    idler is 42 N-m (31 ft-lbs) and tensioner is 40 N-m (30 ft-lbs)
    2021 M340i xDrive, 2016 Sepang SQ5, (sold) 2012 Glacier White S4 6MT - APR Stage II
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by ellwood View Post
    Above is correct, but, honestly, when I replaced the s/c tensioner, I just put a little blue Loctite on the threads and tightened it up nice and snug. This is not critical like cylinder head to block studs or main and rod bearing caps.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Nov 04 2010
    2016 CLA250 4Matic
    NY/South Jersey
    Quote Originally Posted by MSq5 View Post
    Thank you so much for the info
    Senior Member Three Rings viperbenz1's Avatar
    Mar 11 2012
    boston ma
    I just replaced it
    Nov 04 2010
    2016 CLA250 4Matic
    NY/South Jersey
    Quote Originally Posted by viperbenz1 View Post
    I just replaced it
    How long did it take u?
    Mar 11 2012
    boston ma
    Quote Originally Posted by Marlon177 View Post
    It took about 90minutes , most of it was taking the bumper cover and putting it back on
