Results 1 to 27 of 27
    Feb 07 2018
    PDX ish
    Seeking techs that really understand component protection
    So I did a b8 2011 s4 swap into my 2011 a4 Avant. Swapped most of the modules and it all went relatively well. There is a thread in the avant section with a lot of details and pics.
    Got her up and running but had a few issues;
    Component protection on driver memory seat, airbag error (switched main airbag module but not individual airbags). Airbag error also resulted in parking brake error.
    Lost keyless entry as the s4 bcm didnt have it.
    Rear liftgate didnt function (also likely due to bcm)
    So I took the car to Audi. They removed cp on the driver seat. Removed the error for airbag and parking brake. I asked them to try and use the a4 bcm and reprogram it so I could regain keyless entry and push to start.
    So they tried to reconfigure car with a4 bcm but it refused to start. When they switched back to the s4 bcm a lot of the modules were flagged with "component protection" tags even though they were th s4 modules (in a nut shell we transfered like 85% of the s4 modules into the a4 body so the car thinks it's an s4 and sees the right modules).
    So now the car is in safe mode and though it (amazingly) runs there are no guages, no hvac, no stereo. Airbags flagged but obviously dont want to find out if they are deactivated too. All of this worked and was error free a few hours prior so to see cp was unexpected.
    I know there are a lot of smart educated people on here. Does anyone have an idea of what went wrong or what needs to be done to remove the cp flags? Typically those pop up when you switch modules but ours are the s4 ones. It will be going back to audi for them to continue to work through this. From the outside it seems like it should be easy to just remove the flag but OTIS doesent work that way apperently.
    The guys at Audi have been great and I asked them to try and reprogram/use the a4 bcm so this is kinda my doing but they weren't super confident they could get it all back. They said typically they would try and reset the car back to the default config but my car obviously isnt the stock config so they're worried about what may happen.
    Anyone have any insider knowledge or tips. Anything would help.
    Pics of build for reference and current codes. All are now related to component protection.20191219_103402.jpeg20191219_180834.jpeg20191221_215009.jpeg20191228_102647.jpeg20191230_223504.jpegIMG_20200107_180320_01.jpeg20200107_200501.jpeg20200107_161312.jpeg
    Sent from my SM-G973U1 using Audizine mobile app
    2011 S line Prestige A4 Avant - 3.0t swapped
    EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
    Oct 20 2015
    Southern%20Hemisphere
    Buy a clone VAS5054a cable and then find a guy on skype called Jack Kirry -he’ll fix all this for you no problems.
    Mar 17 2008
    There is an 8 pin chip on the circuit board of the module that you can re-solder from A4 module to S4 module. The chip holds information that is used by the component protection funciton.
    I am not going to share any links here but search "8 pin audi component protection" and you might find more information on the internet.
    Had to do this on a water flooded A5 at some point in the past. I am not sure if it works on all modules/cars but its worth looking into.
    Thanks
    Established Member Two Rings zgastin's Avatar
    Mar 13 2016
    1986 F250 (barn find full restoration), 2015 F56 4 door Mini Cooper S
    Rochester NY
    Now you are making me nervous about my swap.
    What modules did you swap?
    I did everything I could find. BCM and parking brake, sports diff, amplifier in the trunk, both front seat modules, bcm under driver dash, key receptical, can gateway under glove box, air bag under center console. Going to try to swap the modules in the steering column so I retain the avant wiper stalk. Every mmi/hvac unit in center console, and the instrument cluster.
    Hopefully you can get this figured out.
    Sent from my SM-G960U1 using Audizine mobile app
    Feb 07 2018
    PDX ish
    Quote Originally Posted by byront8 View Post
    I reached out to him yesterday after searching online and seeing his name a few places. Chatted this morning and gonna buy the cable and see what happens. Thanks for the recommendation.
    Quote Originally Posted by Antekaudi View Post
    Thanks
    OK. I'll look into it but gonna keep it as a plan B if Kirry doesent work out.
    Quote Originally Posted by zgastin View Post
    We swapped all the accessible modules. I have a list at home. Definitely swapped all the ones that show up as CP on my list (except memory seats as the seats were sold prior). The car ran fine prior to trying to adapt the a4 BCM2 to the s4, that really shit the bed. Audi had just removed CP from the seat and fixed the airbags so I was literally left with a liftgate that didn't want to close via the button (likely a bcm2 issue) and I lost my keyless entry and push to start (also BCM2 issues). Car was almost done otherwise, so its just an fyi, to be very careful if for some reason you see a need to try and reprogram your a4 BCM2. Tread lightly.
    Unless your car has active steering, your car has the valeo coilspring. The s4 uses the Kostal coil spring and it is required for the sports differential. They are physically incompatible. To use the s4 coilspring you'll need to use the s4 stalk which doesn't have the rear wiper selector. I reached out to 300zx and he said he ordered the correct b8 s4 stalk from Germany. Looking up the part number it looks like q5 from 2009 through 2016 used the same kostal clockspring and also have the correct stalk with the rear wiper option. I ordered one from ebay that arrives Friday to see if it will work. There are pins on the stalk that vary and I haven't been able to find a pin out so Im not sure how the pins effect anything. I got both the q5 stalk and q5 Kostal clockspring so I can check s4 clock with q5 stalk, and q5 clock and stalk to see if either combination works.
    Oct 20 2015
    To be fair - any UK, Aus or NZ S4 Avant will have the right clock spring and stalks
    Feb 07 2018
    PDX ish
    Yup. Just a matter of tracking one down. My q5 attempt cost 43 dollars total going with the dirt cheap readily available option first. If it doesent work it's still good info for the next guy.
    Feb 07 2018
    PDX ish
    Got my hands on a VAS 5054a to use with Jack Kirry. I'll report back on how it goes.
    Feb 07 2018
    PDX ish
    So... didnt have a lot of luck today. Jack kirry couldnt even get the car to respond...
    Maybe my 5054 was bad. So I ordered another. If the cable wasent bad then I'm really not sure why the car wouldnt communicate.
    When I went to audi they removed cp from my driver seat memory no issue and cleared the srs and abs errors that the car had no issue. It was only when they tried to program my bcm2 from my a4 avant that it pitched a fit.
    Anyone have any other ideas? Like I said I ordered another 5054 so hopefully that solves it but otherwise I don't know what to do.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    In audi server you have now which vin number, old or s4 one?(as you swapped most of modules)
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Feb 07 2018
    PDX ish
    Quote Originally Posted by Gunnark100 View Post
    S4. Vin in car and audi understood that was the vin to use.
    I think maybe when they hooked up the a4 bcm2 it triggered cp and maybe those flags persisted even when they switched back to s4 bcm2. Pure speculation.
    Mar 17 2008
    Can you clarify on what your current setup is ?
    Which modules were replaced and what car they came from ?
    Also, do you have a log from VAGCOM that lists all the devices under the Gateway ?
    Feb 07 2018
    PDX ish
    My car has the engine/trans/most of the modules from a single wrecked s4. Everything came from that s4 so all the modules are matched. All were working without issue until Audi tried to re-use my a4's BCM2 so I could get my keyless entry back which triggered the component protection.
    I have a scan from right after my trip to Audi, so I can upload that tonight.
    Mar 17 2008
    Send logs of before the dealer visit and after.
    So the car was fine before the dealer visit ? And the only problem was keyless entry ?
    What is the part number between the BCM modules A4 and S4 ?
    Feb 07 2018
    PDX ish
    Ill post both before and after logs tonight
    Problems when I went to Audi
    1. ABS error - changed abs controller to s4 - Audi cleared the error no problem
    2. SRS error - Changed the central airbag module to s4 module - Audi cleared the error no problem
    3. Parking brake malfunction - because of the ABS or SRS change - worked fine but Audi cleared the error no problem
    4. Rear liftgate button (button on the bottom of the liftgate) wouldn't function - When the a4 bcm2 was put in car it would work, but car would not start.
    Audi finished here. I SHOULD HAVE WALKED AWAY RIGHT HERE.
    Instead we tried to reflash/reprogram a4 BCM2 to work in s4. I don 't know exactly what was done here as I had to wait in the service lounge
    Given car back, said couldn't get it to work
    Advised there were some codes but car was derivable. Said maybe I needed to recode some modules
    Went to car and saw it was in safe mode on cluster
    Immediately ran VCDS in parking lot and every single error relates to component protection (or is in error state because another component is in error state due to cp).
    Went back to Audi and advised cant code cp errors as odis only
    long discussion ensued, no clear path to resolution.
    Can bring back to Audi to look at but at 171/hr and no idea how long they will need to resolve I'm looking at all options available to resolve.
    A4 bcm - 8K0 907 064 CH
    s4 bcm - 8K0 907 064 CF - cant recode this one as it is physically missing pins compared to the a4 module
    Oct 20 2015
    So from what I know, CP is a mixture of VIN, serial number, and key fob code.
    Sounds like they have squirted one of the A4 codes into the entire system, so when the car runs it’s SVM check against the Audi server - ODIS thinks your car is an A4 when all the S4 modules are installed.
    Mar 17 2008
    In theory the BCM module from A4 should work. (Re-soldering that 8pin eeprom would probably work for you)
    Post the logs and we may be able to find out what Audi did with the car.
    Also, what problems were you having with your 5054 ?
    Feb 07 2018
    PDX ish
    5054 - car refused to connect. Tried a new usb cable and no luck. Tried for about an hour but he was never able to get car to respond.
    forgot about the CAN gateway - never figured that one out but wasen't presenting any obvious issue so it was low priority
    - - - Updated - - -
    Code from before Audi
    Code:
    Wednesday,01,January,2020,11:46:29:42404
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    Data version: 20190930 DS308.0
    www.Ross-Tech.com
    VIN: WAUBGAFL4BA085768   License Plate: S4 5
    Mileage: 180420km-112107mi   Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 36 42 46 47 52 53 55 56
              5F 62 6C 6D 72
    VIN: WAUBGAFL4BA085768   Mileage: 180420km-112107miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: Not registered 0011
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CCBA)       Labels:| 06E-907-551-CAK.clb
       Part No SW: 8K0 907 551 B    HW: 8K0 907 551 A
       Component: 3.0T SIMOS84  H07 0002
       Revision: --------
       Coding: 0104000A240F0128
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30TFS0218K0907551B 001002
       ROD: EV_ECM30TFS0218K0907551B.rod
       VCID: 303A19A42AA909C7797-8064
    No fault code found.
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels:| 0B5-927-156.clb
       Part No SW: 8K1 927 156 K    HW: 0B5 927 156 F
       Component: 0B5 30TFSINAR H05 0008
       Revision: --H05---    Serial number: 0000001212
       Coding: 000001
       ASAM Dataset: EV_TCMDL501 A02087
       ROD: EV_TCMDL501.rod
       VCID: 3D243090EDFBF4AFE21-8068
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
       Component: ESP8 quattro  H04 0060
       Revision: --------    Serial number: --------------
       Coding: 290D1A
       VCID: 025E836CD4054B57DF3-8056
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
       Component: BCM2 2.0      H05 0434
       Revision: 00002001
       Coding: 090100
       VCID: 76B6EFBC88CD67F7E3B-8022
       Subsystem 1 - Part No SW: 8K0 959 754 BB    HW: 8K0 959 754 BB
       Component: FBSAUDIB8 IDG  H71 0083
       Serial number: 0513000088231012
       Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: J764 ELV MLB  H37 0042
       Serial number: 2310000060735006
    Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01221120101243
       Coding: 66102000
       VCID: 005A8964DA095947C97-8054
    Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000000862308
       Coding: 26001091063CAF212700080300003D0D0F9CD24802010161000000
       Shop #: WSC 57623 000 1048576
       VCID: 3C223D94F661FDA7D5F-8068
       Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 261110  H06 0070
       Serial number: SWF10110260084
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 11169252
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000001911100996
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
    Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
       Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0070
       Revision: 11001001    Serial number: 51201031900783
       Coding: 20010D
       VCID: 47C85278BFA7AE7F48D-8012
    Address 15: Airbags (J234)       Labels:* 8K0-959-655.clb
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GLD0GVDYI
       Coding: 303837354230303030304A55304C384B3053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003010
       ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
       VCID: 45D45870852BBC6FBA1-8010
       Seat occupied recognition:
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Component: BF-Gewichtss.  H02 0040
       Serial number: 5810000R1000001Q1H
       Crash sensor for side airbag: driver side:
       Serial number: 6334MSME5A21503CB
       Crash sensor for side airbag: front passenger side:
       Serial number: 6344MSME3D5331046
       Crash sensor for side airbag: rear: driver side:
       Serial number: 6352QSME257A5736M
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 6362QSME01761F1AJ
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME31774C20Z
       Crash sensor for front airbag: front passenger side:
       Serial number: 63832SME32772208V
    1 Fault Found:
    9445973 - Seat occupied recognition control module
              B1022 55 [137] - Not configured
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Mileage: 180424 km
                        Date: 2020.01.01
                        Time: 11:42:17
    Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372JKF000TJ
       Coding: 000036
       VCID: 3E26379CE07DEFB7FBB-806A
       Component: E221 - MFL  H03 0003
    Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 981 Q    HW: 8K0 920 981 Q
       Component: KOMBIINSTR.   H08 0258
       Revision: 00000000    Serial number: EJG45P8CA
       Coding: 8B1709008300D705020000
       VCID: 41DC4C609183904F869-8014
    Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E10B0382DA
       Coding: 00C303
       VCID: 03508668CB1F425FD45-8056
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 1000952C221110
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 180424 km
                        Time Indication: 0
                        Date: 2020.01.01
                        Time: 11:42:16
                 Freeze Frame:
                        Bin. Bits:    10111
                        Voltage: 11.60 V
                        Count: 6
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H10 0025
       Serial number: 000311100001115
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
       ROD: EV_AllWheelDiffeQSPCAN.rod
       VCID: 2E0607DC309D1F376BB-807A
    Address 36: Seat Mem. Drvr (J136)       Labels:. 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00001002211822
       Coding: 00581B00000000000000
       Shop #: WSC 06335 000 00000
       VCID: 3B203E88F36FFA9FDC5-806E
    1 Fault Found:
    02095 - Component Protection Active
                000 - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 180424 km
                        Time Indication: 0
                        Date: 2020.01.01
                        Time: 11:42:11
    Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000110728933
       Coding: 011C13204E00410001
       VCID: 4ACE6B4CACB55317573-801E
    Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0138804594
       Coding: 0106023A10FA540480B0023200000000
       Shop #: WSC 57623 123 104857
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000329732
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS133  H07 0041
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOM.clb
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34804001627401
       VCID: 7AAEFB8CBCD50397873-802E
    Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000110630894
       VCID: 49CC5440A9B3580F5E9-801C
    Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
       Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
       Component: EPB Audi B8   H09 0100
       Revision: 00000003    Serial number: 10000000664976
       Shop #: WSC 00000 000 00000
       VCID: 343215B4DE3135E71DF-8060
    1 Fault Found:
    01321 - Control Module for Airbags (J234)
                013 - Check DTC Memory - MIL ON
                 Freeze Frame:
                        Fault Status: 11101101
                        Fault Priority: 4
                        Fault Frequency: 2
                        Reset counter: 230
                        Mileage: 180424 km
                        Time Indication: 0
                        Date: 2020.01.01
                        Time: 11:42:11
                 Freeze Frame:
                        Voltage: 11.70 V
                        Count: 80
                        Speed: 0.0 km/h
                        Hex Value: 0x0270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    Address 55: Headlight Range        Labels: 8K0-907-357.clb
       Part No: 8K5 907 357 B
       Component: Dynamische LWR  H02 0010
       Revision: 00000001    Serial number:
       Coding: 0000004
       VCID: 392C2480F553C88FCE9-806C
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4G0 035 082     HW: 4G0 035 082
       Component: Radio U SIRIU H51 0052
       Revision: AB001007    Serial number: 471KZ0A7544331
       Coding: 020007010000000001
       VCID: 5DE490100D3BD4AF821-8008
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
       Component: H-BN-NA       H49 0116
       Revision: --------    Serial number: 490K40A7592177
       Coding: 010200000206A1EF05000B0E000000030000
       VCID: 382A2184C259D187317-806C
       Subsystem 1 - Part No: 8R0 060 884 P
       Component: NAR 2010  0407
       Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
       Component: DU7 High  H43 0084
       Serial number: 9466K.0A0263329
       Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000690385
       Subsystem 4 - Part No: 8R0 060 961
       Component: CD-Database  1886
    Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000110640554
       Coding: 010C13204000210001
       VCID: 45D4587085ABBC6FBA1-8010
    Address 6C: Back-up Cam.        Labels: 8T0-907-441.clb
       Part No SW: 8T0 907 441 C    HW: 4L0 907 441 B
       Component: J772__Rearview      0040
       Revision: --H04---    Serial number: 525PA8-J0991OS
       Coding: 1000006
       VCID: 382A2184CE59D187317-806C
    Address 6D: Trunk Elect. (J605)       Labels: Redir Fail!
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Component: J605  Master  H50 0330
       Revision: --------    Serial number: 8K9827851A
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Component: J756  Slave  H50 0330
       Serial number: 8K9827852A
    Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-795.clb
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000110640568
    End----(Elapsed Time: 01:53, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
    Gateway Installation List:  8T0 907 468 AD
    Address 17,8K0 920 981 Q,recoded (Long Coding),from,8B1709008300D705020000,to,8B1711008300D705020000,(57623/000/1048576),
    Address 01,8K0 907 551 B,recoded (Long Coding),from,0104000A240F0128,to,010C000A240F0128,(06325/000/00000),
    Address 05,8K0 907 064 CF,recoded (Long Coding),from,090100,to,090900,(06325/000/00000),
    Address 46,8K0 907 064 CF,recoded (Long Coding),from,0106023A10FA540480B0023200000000,to,0106023A08FA540480B0023200000000,(57623/123/104857),
    Address 55,8K5 907 357 B,recoded (Short coding),from,0000004,to,0000004,(06335/000/00000),
    Address 5F,8T1 035 664 C,recoded (Long Coding),from,010200000206A1EF05000B0E000000030000,to,010200010206A1EF05000B0E000000030000,(57623/000/1048576),
    Address 6C,8T0 907 441 C,recoded (Short coding),from,1000006,to,1000006,(06325/000/00000),
    Address 6C,8T0 907 441 C,recoded (Short coding),from,1000006,to,1000006,(06325/000/07),
    Address 55: DTCs cleared
    08-Auto HVAC -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    Feb 07 2018
    PDX ish
    Scan from right after Audi
    Code:
    Tuesday,07,January,2020,19:53:45:42404
    www.Ross-Tech.com
    VIN:    License Plate: S4 POST 1
    Mileage: 180940km-112430mi   Repair Order:
              5F 62 6C 6D 72
    VIN: WAUBGAFL4BA085768   Mileage: 180940km-112430miles
    03-ABS Brakes -- Status: Malfunction 0010 ********************************************* Due to SRS error (CP)
    05-Acc/Start Auth. -- Status: Malfunction 0010 **************************************** CP
    08-Auto HVAC -- Status: Malfunction 0010 ********************************************** CP
    09-Cent. Elect. -- Status: Malfunction 0010 ******************************************* CP
    15-Airbags -- Status: Malfunction 0010 ************************************************ CP
    17-Instruments -- Status: Malfunction 0010 ******************************************** CP
    19-CAN Gateway -- Status: Malfunction 0010 ******************************************** CP
    36-Seat Mem. Drvr -- Status: Not registered 0011  ************************************* CP
    46-Central Conv. -- Status: Malfunction 0010 ****************************************** Error due to Access and Auth error (CP)
    47-Sound System -- Status: Malfunction 0010  ****************************************** CP
    53-Parking Brake -- Status: Malfunction 0010 ****************************************** Due to Air Bag error (CP)
    56-Radio -- Status: Malfunction 0010  ************************************************* CP
    5F-Information Electr. -- Status: Malfunction 0010 ************************************ CP
    6D-Trunk Elect. -- Status: Not registered 0001
       Revision: --------
       Shop #: WSC 48207 003 1048576
       Coding: 000001
       Coding: 290D1A
    1 Fault Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:08:46
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0032
                        Hex Value: 0x029A
                        Hex Value: 0x00FF
       Revision: 00002001
       Coding: 090100
    1 Fault Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:04:26
       Coding: 66102000
    2 Faults Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 2
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:39
    01206 - Signal for Duration of Ignition Off Time
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 34
                        Mileage: 180946 km
                        Time Indication: 0
                        Date: 2010.01.22
                        Time: 00:01:12
       Coding: 00FD11
       Coding: 025028
    1 Fault Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 2
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:00
       Coding: 20010D
    1 Fault Found:
    13697280 - Component Protection
              U1101 00 [137] - Active
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 5
                        Mileage: 180947 km
                        Date: 2020.01.07
                        Time: 15:03:41
       Coding: 000036
    2 Faults Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 2
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:40
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 33
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:40
       Coding: 00C303
    3 Faults Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:44
                 Freeze Frame:
                        Bin. Bits:    10111
                        Voltage: 12.20 V
                        Count: 6
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:04:28
                 Freeze Frame:
                        Bin. Bits:    10111
                        Voltage: 12.30 V
                        Count: 6
                        Text: FF70746F00820100
                        Angle: -1.972°
                        Raw, Form. N/A: 000 130 001
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:04:31
                 Freeze Frame:
                        Bin. Bits:    10111
                        Voltage: 12.30 V
                        Count: 6
                        Angle: -1.972°
    1 Fault Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:39
       Coding: 0106023A00FA540480B0023200000000
    1 Fault Found:
    03219 - Access and Start Authorization
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:04:26
    1 Fault Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 2
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:40
                 Freeze Frame:
                        Voltage: 12.20 V
                        Temperature: 37.0°C
                        Temperature: 41.0°C
                        Bin. Bits: 00000100
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 2
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:39
                 Freeze Frame:
                        Voltage: 12.30 V
                        Count: 80
                        Speed: 0.0 km/h
                        Hex Value: 0x0270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Coding: 0000004
    1 Fault Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:40
       Coding: 010200010206A1EF05000B0E000000030000
    2 Faults Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 249
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:42
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 34
                        Mileage: 180947 km
                        Time Indication: 0
                        Date: 2020.01.07
                        Time: 15:03:42
       Coding: 1000006
       Shop #: WSC 06325 000 00007
    End----------(Elapsed Time: 02:00, VBatt start/end: 12.2V/12.0V)-----------
    Oct 21 2012
    Earth...
    Yes, thats correct, as kessy was retrofit for s4 vin(and no svm code for this retrofit), but they used automatic svm procedure and this fucked all car. Jack should be able to remove cp now one by one after that by "manual mode" adapting a4 bcm2 and keys(i hope).
    Feb 07 2018
    PDX ish
    Can you link me to any good info on the svm process. I'd like to understand this better.
    Mar 17 2008
    Your logs of before and after show the same SW and HW for the BCM.
    The A4 BCM is CH.
    Either way, the setup you have should work you just need to find someone competent with connection to ODIS online to help you out.
    Also, keep in mind that once you remove component protection the coding of the modules will go to default. You will have to change the coding as needed.
    Feb 07 2018
    PDX ish
    The A4 BCM is CH.
    Yeah they couldn't get car to run with a4 BCM so they put S4 back in. Really not sure why it has CP issues as everything is s4.
    Thanks for taking the time to look it over.
    Mar 17 2008
    I think as stated before, Audi probably used an automatic update process while the A4 module was in.
    I guess get your 5054 replaced and get in touch with Jack. He should be able to correct this.
    Mar 17 2008
    Here is some detail on SVM:
    http://wiki.ross-tech.com/wiki/index.php/Retrofitting
    Also, if BCM is the only module with different part number in your car you could source another BCM module with exactly same part number and have the dealer perform CP removal and automatic SVM. They may be more comfortable with that procedure than what they did with the A4 module.
    Oct 20 2015
    So SVM - is Software Version Management
    When the car goes to Audi it is plugged into their server - this then dials the motherland and checks all the systems against the software installed - if they have software that differs to the build of the car, it tries to update the equipment back to factory spec. So this appears to have tried to change your S4 modules back to A4 modules and its gone mental. After Jack has done his work the SVM checks will pass as he makes the ODIS system see the new modules are original
    In NZ, for navigation retrofits, we expressly tell people to tell Audi never to run an SVM check on the car, else it'll flash the software for Japanese navigation onto an EU unit and it'll crap out.
    Feb 07 2018
    PDX ish
    Ok. Yes this is what they did as best they could explain is that it was an automatic system so they couldnt simply recode vin on a4 BCM. Great knowledge for future reference.
