Results 1 to 10 of 10
    Established Member Two Rings kambouris's Avatar
    Apr 29 2019
    Ontario
    Xtrons head unit still doesn’t fit
    A while ago I posted a topic about my xtrons head unit not fitting and I jammed it into place and it worked for a bit, now it doesn’t fit. I feel like I have to trim the top down a little. Has anyone else had this issue?
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    Trim it. That’s what. Xtrons support suggested in my case.
    Go back to them if still under warranty and get some partial refund, these are supposed to be direct fit.
    Apr 29 2019
    Ontario
    Quote Originally Posted by Dondbg View Post
    Okay thank you how much did you trim?
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Sent from my LM-Q720 using Audizine mobile app
    Ivan
    Nov 03 2011
    All Over!
    Quote Originally Posted by dalmation53 View Post
    Yeah, yours fits fine.
    The point is Kambouri’s doesn’t.
    1986 Type 85 Audi 90 quattro
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    so its not a B7 xtrons model. A lot of member got those units, I believe there's 3 models. (rsne look like, mk6 look and full screen). None of those 3 got fitment problem.
    Its a tight fit in deed, but not impossible fit.
    Aug 19 2013
    Miami
    That's what she said....
    Quote Originally Posted by oVeRdOsE View Post
    Ivan
    Apr 29 2019
    Ontario
    Measure it from top to bottom and send a pic
    Aug 19 2013
    Miami
    You sound to demanding
    Ivan
    Apr 29 2019
    Ontario
    Please?🥰
