Results 1 to 4 of 4
    Senior Member Three Rings vpls4's Avatar
    Feb 17 2017
    Tempe, Arizona
    How do you get a #'s Keypad to display when using Sirius XM?
    How do you get a #'s Keypad to display when using Siriusxm?
    Like if I want to enter channel 715 without having to scroll thru hundreds of stations
    Can't find it anywhere. (2015 S4 P+ MMI pkg)
    '15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake | AMS Alpha Cooler | 034 Street Density Eng Mounts
    EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, Pilot SS | Bilstein PSS10's | RSE Test Pipes | AWE Touring /Res DPs
    Oct 21 2012
    Earth...
    Probably not possible, tiny alternative "save" common channels.
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Oct 23 2014
    Buffalo, NY
    Presets will only last until Sirius/Xm updates something; and that’s a near daily occurrence. I’ve been on the fence for canceling the whole thing, mostly due to the sheer dumbfoundment of the fact that they still won’t give you all the channels on the receiver in the car. I get that it’s related to the original agreement between the mfg and their selected provider, Sirius or XM, but c’mon the fuck on, it’s been 11 years since they merged.
    EDIT: to answer OP’s question, I think you can only scroll fast to make the MMI move to an approximate channel near what you’re after, and then it goes back to its normal one-by-one channel scroll. I’ve never seen a keypad that I can recall related to the satellite radio UI.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    May 25 2016
    albany, ny
    Tip: 715 won't be a channel on the MMI, but if you get the streaming app, you can listen to channels over Bluetooth.
