Results 1 to 13 of 13
    Aug 30 2018
    2017-2018 Q5 2.0T reliability?
    Plan is to sell our Jeep Wrangler as our baby on the way needs something with more safety features.
    We are considering either a CPO RX350 or a CPO Q5.
    Can’t find many 3.0t Q5’s...how’s the 2.0T gen 3 doing so far? Oil burning or timing chain issues?
    The RX350 is tempting because well it’s likely boring and nothing will ever go wrong, but the Q5 is little bigger and I like the styling.
    Any thoughts?
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Plenty of 3.0's out there if you're willing to travel to get it or ship it to you.
    2011 A4 Avant Prestige S-Line
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    The RX350 is boring as hell, but in terms of reliability Toyota products are some of the highest out there.
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    Aug 30 2018
    Quote Originally Posted by Novarider View Post
    Right - but what about the 2.0T gen 3? Is anyone seeing timing chain or oil burning issues? Any other new issues?
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Up to 2017, the 2.0T in the Q5 is a Gen-2. These engines have all the internal upgrades and improvements, and should be good for reliability. The new Q5, 2018 and onwards, uses the Gen-3 2.0T engine.
    From what I see, the new Q5 (2018 onwards) has more problems overall than the prior generation (2011 to 2017), but I would not recommend a Q5 older than a 2016.
    Mar 12 2017
    N.C. USA
    Quote Originally Posted by S4'ed View Post
    Have 2 2016 Q5 2.0 with 30k mi on both. No problems with either one.
    2020 Q5 prem plus Matador red/Beige
    Aug 30 2018
    More problems like what? Engine? Transmission ? Chassis?
    This is what I’m trying to figure out.
    Jan 01 2018
    Idaho Panhandle
    Quote Originally Posted by ps2cho View Post
    I'm pretty active on Audiworld where I believe you'll find a good cross-section of the problems.
    Common Problems / Complaints
    Most of the issues are One Offs but I put together a list of common issues and their solutions for repeating stuff. Many of the issues have been handled via software updates. but these are the main current ones:
    • Front Window Controllers (controllers replaced and/or fixed via software update)
    • Presense False Activation (especially in reverse)
    • Rattling Sunroof
    • Two recalls for Wheel Arch Trim
    • Jerky transmission stumble when coming to a stop.
    Major Failures
    After 2 years there haven't been a lot of major failures, but these are the ones I remember
    My SQ5 hasn't had any issues beyond the Window Controller issue which is resolved. If you're considering a 2018 - besides the engine being different, the transmission is different as well. The Q5 has the new quattro "ultra" 7-speed S tronic (on demand) versus the SQ5 8-speed Tiptronic (full-time). This is one of the bigger differences that you should be aware of.
    2018 SQ5 Prestige, S-Sport, Dynamic Steering, APR 91 Stage 1 Tune
    Aug 30 2018
    Quote Originally Posted by spindlewood View Post
    • Rattling Sunroof
    Major Failures
    Thanks, will go check it out.
    We are most interested in likely a 2019 CPO upon looking at the differences. Is the 7-speed DCT brand new, or has it been used in other models before?
    2019 Audi Q5 - 28k; Arctic White; Black Optic
    2003 Mercedes ML350 - 166k; Gray
    Sep 24 2014
    Central NJ
    Be carefull, I see a lot of lemon-lawed 2018+ Q5s on the used market.
    Aug 30 2018
    Sticking with CPO from an Audi dealer only
    Jan 01 2018
    Idaho Panhandle
    The Quattro Ulta version of the 7-speed DCT is new. It debuted with the 2017 A4 Allroad and then the 2018 Q5 and now is in the 2019 A6 and probablyh others. It's on these Q5s that a few experience (not many) the jerky transmission stumble when downshifting 2=>1, coming to a stop. The SQ5 does not have this.
    The Quattro Ulta saves gas because it is FWD until it detects a need for AWD and engages on demand - supposedly so seemlessly that you can't tell the difference. When I've driven a loaner 2019 A6, I couldn't tell the difference with normal driving conditions. I haven't heard any complaints (from actual owners) online about the Ultra except the stumble noted above. You can read a couple of complaints about it
    in this post
    and here.
    All the responses from other owners basically say they don't have the issue, so while it happens to some, it's seemingly not often.
    Good luck with your search. A 2019 CPO sounds like a good choice. Because it's new, there's not a lot of reliability history on the engine and transmission. We're 2 years into the model and (to me) it looks good - unless you're one of the very few whose engines blew up (under warranty), which is true for any model.
    Aug 30 2018
    in this post
    and here.
    Agreed. I think that if the Gen 3 engine had serious problems, there would be known info on it since it’s been in the A3 for 4+ years now.
    I think if I grab a CPO 2019 that means I’ll have B2B warranty through 2024 which puts my mind at good ease just in case...if all of a sudden people are experiencing blown transmissions at 100k then will just get rid of it before then.
