Results 1 to 7 of 7
    Junior Member One Ring
    Apr 26 2015
    Northern California
    265/40/21 on 21"?
    Thinking about purchasing All Season tires in order to visit Lake Tahoe once or twice a year for skiing. 1 or 2 trips doesn't warrant dedicated snows, IMO. Stock setup is 255/40/21 summers, I've read in this thread All Seasons, but before buying wanted to see if anyone has successfully fitted 265/40/21 scorpion zero all season on their SQ5 without any spacers are modification?
    Jul 31 2016
    PA
    It should fit depending on offset. It is pretty much max you can go as far as tire height is concerned. It will sit just shy of a 1/4" closer to the suspension on the same wheel and will probably bulge a little on the wheel. Similar to another thread here max recommended for an 8.5" wheel is 255, but you could always check the manufacturer info directly because they can vary some.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Sep 28 2010
    NW NC / DE
    Fits 👍🏼
    Apr 26 2015
    Northern California
    Thanks for the input! Going the 265 route saves roughly $400 for anyone who might be faced with the same decision. I'll come back here and post some pictures once they're installed.
    Veteran Member Four Rings Rocs's Avatar
    May 25 2009
    Audis
    Conshohocken, PA
    I just put 265/40/21’s on and went with Atturo’s.
    2016 SQ5
    2012 A4 6mt
    2004 A4 Ultrasport
    Jul 03 2004
    SF Bay Area
    How many miles are people getting out of the Atturo's? The wear rating isn't the best at 320.
    2017 Audi Q5 3.0T P+ | Sepang Blue | Black Optics | Competition S-Line Plus | Tech | Black Nappa | Aluminum Satellite Inlays | 21" factory wheels
    2004 BMW M3 | Alpine White | Speed Cloth | 6MT
    Apr 29 2014
    2017GLS550 ST1
    Area with Bay people
    Quote Originally Posted by DannyB View Post
    At least pick your days and try to avoid snowstorms.
    265/40/21 fits, but if you're lowered you need spacers. I'm 15mm square, no rubbing. Without spacers it rubbed when turning wide.
    I took 7 with stock Pirelli Verdes A/S, and it was dangerous. Also, 7 is dropped on H&R springs.
    I took it then on Scorpion Winters, and got sidewinded on banks of snow, just driving around thru parking lots, during storms. Had to be towed. And yes, I bought a snowshovel..
    Merći, Candide Thovex!
    So be careful. Currently runnig Atturro AW730 M+S, great tire(for the purpose).
    Sent from my SM-N975U using Tapatalk
    For sale: SQ5 springs
    AKA BobSF
