Hello I have a issue with my a4. I think the timing chain skipped a few teeth. I did not know this was a common problem or I would have updated the parts. The car was not running just cranked and the starter jams. Loud click motor does not turn.
Obviously checked battery first. My last thought was timing chain. But I tried turning the motor by hand and the motor does not turn, its locked up. Im assuming the valves are hitting the pistons. It rotates counter clock wise a little bit but then clockwise locks back up.
Seems like oil is full(checked with wire). The car only has 100k miles on it. My last lexus had 300k and my toyota has 260k. I was really hoping this would last 200k without too many major issues.
What would be advised. A new lower mileage motor or just take the head off and get new valves and update all the other part. I know the bottom end is likely good, but until I take the head off I wont know for sure. I also searched and If im not mistaken vw uses the same engine in their vehicles. This might make it easier to source a cylinder head if I end up going that route
I also need to know the tools required for the job. I know I need the crank tool and cam holder. Is there anything i should know before hand. I have never owned a euro car before and already realize they are much different than my hondas and Toyota I work on.
I plan on removing the front clip, then removing the front covers, putting the car back in time and then seeing the leak down numbers and at the same time check the tensioner for failure. If the leak down numbers are good I will put new chain and new gaskets and new tensioner on and run the car. IF the leak down numbers are not up to spec then I will remove the head and likely replcace the head or get it rebuilt with new valves. I will update the process
