Hello. I needed some help in where to start to fix the following fault codes in my 2010 Q5 3.2:
Engine Control Module
1.1 U100800 Diagnostic interface for data bus Active/static Read out DTC
1.2 P307A00 Intake system Passive/Sporadic Air flow too low
1.3 P006800 MAP/MAF - Throttle Position Passive/Sporadic
Transmission Control Module
2.1 P174000 Clutch temperature monitoring Passive/Sporadic
2.2 P17D800 Torque limitation due to clutch temperature Passive/Sporadic
Kessy
3.1 03285 Left front exterior door handle touch sensor-Short Passive/Sporadic
Air Conditioning
4.1 00713 Center left vent positioning motor -V110-Upper Active/static limit exceeded
4.2 01206 Signal for duration of -Ignition OFF--Implausible signal Passive/Sporadic
Gateway
5.1 02071 Local data bus-Electrical malfunction in circuit Active/static
5.2 02252 Generator-No signal/communication Active/static
5.3 00458 Battery monitoring control module -J367-No signal/ Active/static
I have just bought the car from an auction. And done this scan yesterday using a workshop scan tool myself. Would very much appreciate direction from anyone on the forum to help me fix the issues above. I have sinking feeling the transmission fault relates to mechatronics and valve body being replaced, however since the scan tool has mentioned “passive/sporadic” next to the fault found, I was hoping the fix would be a less lighter on my pocket, and this only involves replacing the circuit board in the transmission.
I’ve had the main car battery replaced a few days ago. The workshop that fitted the battery state they have programmed the car battery. I’m not sure why I would get a fault code that’s related to the battery.
Thank you in advance.
