Results 1 to 11 of 11
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    The Ultimate Ignition Coil Upgrade is Here! (APR Red Ignition Coils!)
    https://goapr.io/coils
    APR Ignition Coils are designed to be a direct plug-and-play upgrade to factory coils, and provide greater energy output, ensuring a stronger and more consistent spark. The commonplace replacement of factory ignition coils with those taken from higher output Audi RS models, such as the 2.5T, is popularly believed to provide greater energy output. However, testing proves that they are no more powerful than the factory coils that are found on 1.8T and 2.0T engines. APR Ignition Coils increase energy output by 10%. They are a direct upgrade or replacement, and come with the coveted red housing made popular by the Audi R8!
    Features:
    • 10% more energy output than stock
    • Red housing with APR Logo
    • True upgrade, not just aesthetic
    • Direct plug-and-play
    Application Guide
    3 - 1.0T EA211
    4 - 1.2T EA211
    4 - 1.4T EA211
    4 - 1.5T EA211
    4 - 1.5T EA211 EVO
    4 - 1.6L EA211
    4 - 1.8T EA888 Gen 3
    4 - 2.0T EA888 Gen 3
    4 - 2.0T EA888 Gen 3B
    5 - 2.5T EA855 EVO
    6 - 2.9T EA839
    6 - 3.0T EA839
    8 - 4.0T EA825
    Price
    $39.99 ($35.99 until 2020).
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Jul 21 2004
    South Florida
    Whay if any impact on performance did you all see at stage 1 levels on a s4/s5?
    2018 Audi S5
    Gone-
    Senior Member Three Rings mobE's Avatar
    Nov 26 2018
    '18 GMC Sierra Denali ultimate
    IL
    For us guy’s that already have stage two/three hardware if we grab your coil’s is there a benefit to going colder with the plugs?
    '18 s4, under construction!
    Senior Member Four Rings
    Apr 26 2019
    United Kingdom
    Quote Originally Posted by mobE View Post
    If there is, do you have any plug recommendations Arin?
    Aug 23 2008
    Auburn, AL
    Yes, they have higher energy output, so less chances of misfires, weak spark activity, blown out sparks, and the need to have tighter spark gap.
    I don't have a plug recommendation yet.
    Nov 26 2018
    IL
    Gotcha, definitely curious to see what you come up with 🤙🏻🤙🏻
    Apr 26 2019
    United Kingdom
    Quote Originally Posted by Arin@APR View Post
    Without plugs, I'm not really seeing the benefit in these coils to be honest. If anything, wouldn't they be detrimental right now as the cylinder would run at a higher temperature due to the increase in energy?
    Until we can actually benefit from this higher energy output, I can't see these being better to run than stock coils for the majority of people, even those running upgrades. Correct me if I'm wrong, but there isn't anybody running into those issues on this platform?
    Veteran Member Three Rings DreamTFK's Avatar
    Nov 01 2019
    Florida
    Anyone slapped these in yet? What plugs would be a good upgrade to go with these coils?
    2020 S4 P+ Quantum Gray BO
    ▪Wagner Competition FMIC w/Charge Pipes
    ▪ECS Carbon ECU Cover | ECS Diverter Valve
    ▪034 Trans Mount | Rear Sway Bar | Springs | 10/12mm Spacers
    ▪034 ECU/TCU Stage 2 93
    ▪Carbnlab Inlet + Airbox Mod/K&N 4" Filter
    ▪CTS Turbo Test Pipe
    Jul 19 2019
    midwest
    Quote Originally Posted by DreamTFK View Post
    Doesnt look like there are any options out there for us except for oem plugs for now. Im sure you could buy some and gap them to the specs of the oem plugs.
    2018S4 Glacier White / JB4 / AWE Switchpath / BBS CI-R
    2009 G37S
    2019 Escalade
    Veteran Member Three Rings S4_Pedro's Avatar
    Sep 17 2012
    Union
    Quote Originally Posted by Kondax View Post
    Yeah I don’t see any benefit. There was someone that ran it on their car with stock plugs and made no difference tbh. Other than it being red. And kind of point less when apr posts something but has no plug recommendation or anything else other than a picture of a graph. 🤷🏼*♂️
    Veteran Member Three Rings thermobryan's Avatar
    May 30 2018
    SoCAL
    2018 B9 S4 (TurboSystems Stage 2, 034 Stage 3 tune, APR HPFP, 034 Coil Packs, IE Intake and Turbo inlet, CarbnLabs Decat DP)
