Results 1 to 21 of 21
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    The Ultimate Ignition Coil Upgrade is Here! (APR Red Ignition Coils!)
    https://goapr.io/coils
    APR Ignition Coils are designed to be a direct plug-and-play upgrade to factory coils, and provide greater energy output, ensuring a stronger and more consistent spark. The commonplace replacement of factory ignition coils with those taken from higher output Audi RS models, such as the 2.5T, is popularly believed to provide greater energy output. However, testing proves that they are no more powerful than the factory coils that are found on 1.8T and 2.0T engines. APR Ignition Coils increase energy output by 10%. They are a direct upgrade or replacement, and come with the coveted red housing made popular by the Audi R8!
    Features:
    • 10% more energy output than stock
    • Red housing with APR Logo
    • True upgrade, not just aesthetic
    • Direct plug-and-play
    Application Guide
    3 - 1.0T EA211
    4 - 1.2T EA211
    4 - 1.4T EA211
    4 - 1.5T EA211
    4 - 1.5T EA211 EVO
    4 - 1.6L EA211
    4 - 1.8T EA888 Gen 3
    4 - 2.0T EA888 Gen 3
    4 - 2.0T EA888 Gen 3B
    5 - 2.5T EA855 EVO
    6 - 2.9T EA839
    6 - 3.0T EA839
    8 - 4.0T EA825
    Price
    $39.99 ($35.99 until 2020).
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Aug 23 2008
    Auburn, AL
    Ours increases spark energy over stock. They are more than just red coils.
    Jul 24 2018
    Westlake Village, CA
    Quote Originally Posted by Arin@APR View Post
    Got it! Do you have white?
    Aug 23 2008
    Auburn, AL
    Red only
    Aug 22 2019
    DFW, Tx
    Stupid question time: what does +10% spark energy mean in layman terms? My spark plug is 10% more likely to fire?
    Stupid question follow up: does this benefit those of us that don’t have issues with spark being blown out (I don’t remember the technical term)
    Thanks,
    Austin
    2001.5 Audi S4 (2.7T/6MT)
    ETspec/Precision 6266/Weight Reduction/E85/WMI
    2012 Audi TTRS (2.5T/6MT)
    034MS St2+/Stock Turbo/FBO/Weight Reduction/100oct/WMI
    2019 Audi RS3 (2.5T/DSG) - RIP
    Unitronic St3/TTE700/FBO/Weight Reduction/E85/WMI
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by Painstain View Post
    The output energy is measured in millijoules vs dwell time. Ours will produce higher output, which will deliver a stronger spark. You'll have less chances of misfires from a wide gap, blowing out spark, etc. Coil packs (ignition coils) tend to fail, stock. They are a hot item to upgrade, but most no one actually offers an upgrade (except for a few companies that sell them for several hundred dollars a pop). But, there's no reason to be that expensive. *hence our pricing*
    Sep 13 2018
    Jerseylicious
    Are these rebranded MSD or are these all sourced from the same manufacturer? They appear to be twins MSD on top and APR bottom. Even if they are APR has got better pricing.
    Veteran Member Three Rings MichiganRS3's Avatar
    Apr 30 2015
    Michigan
    Quote Originally Posted by thejerseydon View Post
    APR and MSD are both Holley brands.
    https://www.holley.com/brands/
    `18 Mystic Blue Pearl Effect RS3
    10.6 @ 129mph / 2.82s - 0-60 - Stage 2 e85
    Sep 13 2018
    Jerseylicious
    Quote Originally Posted by MichiganRS3 View Post
    Question answered :)
    Aug 23 2008
    Auburn, AL
    I don't have any data on the MSD part, sorry!
    Junior Member One Ring
    Jan 23 2019
    Colorado Springs, Co
    Has any testing been done with the APR coil packs compared to a set of brand new OEM units running in an engine that shows the difference in terms that relate to engine performance? For example Hp/Tq, or mpg on new plugs and then the same on older worn plugs with a larger gap. So far I’ve only seen the chart that illustrates the electrical power of the coils. Even a graph of the engine idle Vibration frequency would help. Basically I want to know if there’s a reasonable expectation that the engine could even take advantage of 10% more power delivery. Now I’m not saying the OEM packs are great and can’t be improved upon but say the OEM units are Hypothetically designed to provide more than the spark needed for optimal detonation and have enough extra spark to keep things in the sweet spot as a plug wears and the gap grows, then what benefit would a coil with 10% more spark provide?
    Jun 26 2018
    Socal
    The way I understand it....
    More power means more boost and more boost creates higher cylinder pressures and temperatures. Heat increases the resistance within the spark plug and the pressure and heat expand the plug gap (which is why they say to tighten the gap). Heat and pressure weaken the spark and can cause misfires, where the spark plug was too weak to ignite the air/fuel mixture.
    A higher energy/power igniter can ensure a more reliable spark across the plug gap, withstanding more heat and pressure than oem.
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    Quote Originally Posted by Bowser330 View Post
    lol wut?
    May 21 2016
    these are never instock not sure whats going on with apr but.......you can get these bad boys MSD Ignition Coils Blaster Series 2013-2018 VW/Audi 4 Cylinder, Red, 4-pack
    THEY ARE SWEET because APR Was not instock and i did not want to wait 6 to 8 weeks i got the MSD Ignition Coils Blaster Series ! & wow!!! wHAT A DIFFERENCE BIG TIME
    https://www.holley.com/blog/post/msd..._applications/
    HERE ARE SOME SWEET IMAGES OF THE MSD Ignition Coils Blaster Series 2013-2018 VW/Audi 4 Cylinder, Red, 4-pack
    MSD Releases Blaster Coil Packs For VW/Audi,
    Holley is pleased to announce the release of a giant assortment of MSD ignition coils and coil packs for late-model VW/Audi, Toyota/Lexus, Honda/Acura, and GM applications. Equally effective as a direct bolt-in replacement for worn-out components or a performance upgrade from stock coils, MSD Blaster coils deliver the power, quality, and reliability MSD is famous for. They're available in your choice of black or red, offered individually and in packs of four, plug right in to factory wiring, and meet or exceed OE specs.
    See complete product details for Late Model MSD Blaster Coil Packs.
    4 PACK
    ACCEL IGNITION COIL - SUPERCOIL - VOLKSWAGEN / AUDI 1.8L - I4 - 4-PACK
    Direct OEM replacement
    PART# 140274-4
    Be the first to write a review
    $217.95 Suggested Retail
    $195.95 Your Price
    https://www.holley.com/products/igni...parts/140274-4
    99-01 Audi TT
    • 00-01 Audi TT Quattro
    • 97-00 Audi A4
    • 00 Audi A8
    • 00-02 Audi A8 Quattro
    • 00-04 Audi A6 Quattro
    • 01-03 Audi S8
    • 01-04 Audi S6
    • 03-04 Audi RS6
    • 99-00 VW Beetle
    • 00 VW Gold/Passat GLS
    • 00-01 VW Jetta
    • 02-07 VW Sharan
    MORE HERE
    https://www.holley.com/products/igni...lkswagen-audi/
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    The engine runs smoother, sounds smoother. It took me about 40 minutes to do the install although you can do it in significantly less time. It is a simple process. The APR coil packs seems to come with dielectric lime color grease already. I haven't had the time to go and test the car with draggy, I probably wouldn't be able to see an improvement because I went and I put the OEM wheels but like I said, the car runs smooth and sound better. I have 17000 miles on the car .
    in summary, I think that the APR coil packs are well price and they are a component considered part of a tune-up so I would recommend it.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    May 27 2019
    Orlando/fl/south east
    Thread bump. Any reviews on these for an upgrade?
    Veteran Member Three Rings 0000 RS5's Avatar
    Jul 13 2015
    Just installed mine. (I know, not super helpful to the update question)
    May 27 2019
    Haha. No worries. I’m sure you are excited. I hope they are worth it!! At the very least, they look good
    Jul 13 2015
    Quote Originally Posted by Pitbulldad520 View Post
    Exactly!
    Veteran Member Three Rings sleeperwagon's Avatar
    Nov 07 2007
    18 RS3, 22 AMG GLC43, 97 AA M3 Sedan, 03 Dinan M3 Convert, 88 E30 M3
    Northern Ohio
    I know this is an old post but for those reading this, or Arin, I installed mine asap Jan 2019 and have about 30K miles on them. How often is everyone changing out plugs and coil packs?
    Stage 2 E85 car stored for the winter with 93 oct in it (I run 93 in the early spring, late fall for many reasons living in Northern Ohio).
