Results 1 to 13 of 13
    Nov 30 2019
    Texas
    Manually closing intake valves (carbon cleaning)
    Walnut blasting my 2015 S3 intake valves this weekend. Curious what method you guys have used to open and close the valves.
    Seems like my options are manually turning the crank or using a remote starter switch. I’d like to go option two, but wondering how to best access the starter for this method. Is it at the back of the engine, under the turbo? Lastly, does the battery need to be unplugged when doing this? Last time I took off the manifold, I had the battery unplugged throughout the process.
    Veteran Member Three Rings S3_Miles's Avatar
    Jun 13 2018
    Paso Robles CA
    Quote Originally Posted by Brandon.august View Post
    Curious - How many miles are on yours? My 2015 S3 has 40k. Wondering if I should proactively do this? Car seems to be running fine..and I always use the best gas I can find but still
    Nov 30 2019
    Texas
    Quote Originally Posted by S3_Miles View Post
    75k. When I was in there last weekend, it was a mess. I would suggest doing it proactively, and apparently using the best gas/fuel additives won’t prevent the problem.
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Type of gas is irrelevant as the gas never even passes through the intake. Its oil blow-by the accumulates on the valves. I probably need to do this too as I'm at 81K and doubt its ever been done. Personally, I'll just turn the crank to close the valves. Do you use a regular sand blaster and a vacuum cleaner to keep the stuff from getting all over or?
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Jul 20 2019
    Yep, no way around it since its from oily crankcase gasses and combustion byproducts during valve overlap during certain operating conditions.
    I've seen this done with walnut blasting or with bronze brushes by hand or hooked up to a drill etc.
    I've seen B-12 chem tool work well to softening the carbon... seafoam also works pretty well. Might be some better products now.
    Walnut blasting seems to depend on how good of a setup you can rig up. I've seen some neat 3d printed adapters made on some other platforms to make it easy.
    I've always just turned the crank by hand. Easy to do with the plugs out and gives you a lot of control to make sure valves are sealed up on the cylinder you're working on.
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Quote Originally Posted by aaronc7 View Post
    Well, port injection
    Senior Member Two Rings soulflyer's Avatar
    Apr 06 2015
    Ottawa, Canada
    Had it done by my Audi Dealer in 2016 after 50k miles on my 2015 S3.
    Before
    after
    Unfortunately I don't know how they operated the crank...
    2018 S3 Technik, Ara blue
    SOLD 2015 S3 Technik, Sepang blue
    I have VCDS, will do scans and coding for beer in the Ottawa ON, area. PM me.
    Nov 30 2019
    Texas
    Do you need to remove the tire to get access to the crank, or can you do it from the top? Any specific tool? I read somewhere that someone just pulled the alternator belt to turn it but I'm not sure how possible that is.
    Jul 20 2019
    I haven't done it on this car so I can't say for certain, you may need to pull the passenger tire off and maybe pull back the liner a bit.
    On my other car you can actually turn over the engine just fine using the alternator bolt (with the spark plugs removed of course)..Worth a shot and go for whatever is easiest for you.
    Junior Member Two Rings
    Apr 20 2019
    San Antonio, Texas
    Hello Brandon. Did you do the cleaning yet? BTW, were you able to view the valves before any cleaning? I have a one of those endoscopic mini cameras and was wondering if it's possible to snake it and view the valves. I just don't know where to start.
    Oct 01 2015
    Karachi, PK
    Quote Originally Posted by gman1275 View Post
    i think to view the valves is from removing spark plugs and see thru the holes by those endospic camera.
    2015 A3 1.8TFSI 7speed S-tronic (FWD)
    Engine mod BMS JB4/ Revo catless DP/aFe dryflo drop-in/stock intake mod/Revo MQB Intercooler/Revo muffler delete/CTS TIP/GFB DV+/034 dog-mount ......VCDS mod visual parking aid, needle sweep & oil temp on DIS
    Aug 02 2019
    Midwest
    Mine was also in need of cleaning @ 68k. Not pretty! No real solution aside from adding port injection, right? I was told catch cans don't work on this platform. Is that true?
    Open to solutions that would slow down the buildup. On B7 RS4's, one loses ~25whp.
    Dirty:
    Clean:
    B7 RS4
    B6 S4
