Results 1 to 7 of 7
    Sep 20 2018
    Los Angeles, CA
    Did I kill my traction control when adding coilovers?
    Hey everyone. New forum member and car noob here. Ever since adding H&R coilovers to my 2019 RS3 8V, the traction control/button doesn't seem to work. Every time I press the button, the light doesn't turn on and I see the traction control "Off" icon displayed for a split second before it disappears. Pretty sure this is also what's keeping me from doing launch control. Never been able to do it since the suspension install. Is this just a consequence of adding coilovers? Any help is much appreciated!
    Dec 13 2019
    Blah
    Did you also put on dcc delete units like the isweeps?
    Jun 07 2019
    2017 S6
    NC
    I have H&R coilovers + isweep (mrc delete) and my traction control button works normally. Have a dealership check it out.
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    If you do not have a cancelation module for the DCC (like the iSweep) it is very possible the car sees a suspension fault, which would prevent the vehicle from turning off traction control as a "safety" thing. Do you have a VAGCOM available to scan the car to see if there are any codes set? Typically they cause a light on the dash, but I guess you could see a soft code in some cases. If you don't have one send me a PM and we can get you setup!
    If you have a DCC cancellation module, my next question would be how much height did you shave off from stock height? 1/2", 1", more?
    Shed some light on the above and hopefully we can narrow in on what is giving the issue!
    Jan 12 2015
    Columbus/OH
    A VCDS will answer a lot of questions... See if you can get a hold of one and scan the car.
    '17 A3 Quattro: APR Stg 2+ ECU, APR TCU * NGK Racing Plugs * Bilstein B12 (Modified), APR sway bars, Whiteline control arms * APR Intake, Turbo inlet, turbo muffler delete, catch can, & Downpipe * Milltek catback * CTS Turbo DV * Mishimoto FMIC and pipes * DSG ICECAP w/ Mishimoto 19row cooler * STOPTECH ST40 332mm BBK * Advan Racing TC-4 18x8.5 wrapped w/ 245-40-r18 Bridgestone RE71R
    Sep 20 2018
    Los Angeles, CA
    Quote Originally Posted by audiAreSureNeat View Post
    Quote Originally Posted by P5stunna View Post
    Quote Originally Posted by XLR8 Craig View Post
    This is the first I'm hearing of a dcc delete module. Noob status confirmed.
    I'm guessing this is our guy? - https://www.ecstuning.com/b-isweep-p....dcc.s38v~isp/
    Thank you all for the quick replies!
    Jan 12 2015
    Columbus/OH
    Yes that would work
