Results 1 to 29 of 29
    Senior Member Two Rings WmRS3's Avatar
    Dec 13 2019
    Audi RS3, Audi S8, Ford Raptor, Volvo S60R
    MA
    2020 order Mag ride or not?
    Hi guys new here I have tried to search and checked the internet a lot of mixed feeling about it. I opted for fixed suspension but can still change it. The car will not be my daily will be fun weekend/ track car. I plan to do full build and ims1000. What are you guys thoughts and feed back on the Audi mag ride? Thanks
    Oct 18 2017
    Michigan
    if not daily i would get fixed suspension.
    Insta: Mattyrs3
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I don't like the magnetic ride on the RS3. Is not my first magnetic ride on Audis , I had a few already on other platforms but I am not thrilled on the RS3. You can still feel the difference when you make the changes but I prefer the tradicional sport suspension. I have had sports cars with stock sports suspensions and it feels much better in every way. The only reason why I didn't pick the standard suspension on the RS3 is because I was forced to buy the dynamic plus package with the carbon fiber brakes, the TPMS and all of that.
    In my opinion the standard suspension should be just that!! Standard!!! and the magnetic should be extra (premium) but Audi marketing does things the other way around. Just like Audi Charges you $400 for red painted calipers on a S3 so find out that the paints peels off quickly. Go and ride a RS3 with and without mag ride if you can.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    May 08 2015
    uu
    no need, normal suspension, don't waste ur money
    Dec 13 2019
    MA
    I drove a 2019 with it. My current summer weekend car Volvo S60R had 4c factory 3 button adjustment it was crashy and all over the road. I ditched it for Kw V2's and never looked back. Figured Audi same idea behind the mag ride so went with fixed and just want to be sure I made the right choice. There is no price difference for with it or without on 2020. Thanks guys.
    Oct 02 2017
    If you really want to go coilover save your money on magride, if you think you may want to just lower your car a little, magride will do an excellent job with most lowering springs.
    Veteran Member Three Rings Jeff_Jeske's Avatar
    Nov 24 2018
    Madison WI
    I agree with OE2.... the magride system is worth every penny IF you do not intend on upgrading to coilovers. If you plan to go with coilovers then it simply adds another layer of complexity and expense you have to deal with.
    Senior Member Two Rings Potshot's Avatar
    Oct 18 2019
    New albany, in
    I love my fixed sport suspension. It is a little harsh on railroad tracks or potholes, but for the other 99% of the time, I have no complaints. My daily driver has the comfy suspension, my rs3 doesn't need it.
    2018 RS3 Black
    Junior Member Two Rings
    May 28 2018
    2022 RSQ8 and M2CS
    Houston, TX
    I bought mine with Mag ride because I loved it on my CTS-V; not so much on the RS3. Having Bilstein coil-overs installed as I type this and ditching the mag ride.
    Nov 15 2017
    FL
    Had an RS 3 with Mag ride and when I traded for the TT RS went fixed. I very rarely ever drove in comfort mode in the RS3. Happy with my choice.
    Jun 07 2019
    2017 S6
    NC
    If you're going to do a full build then the question of which suspension to get from the factory is irrelevant. Unless, you don't plan on touching the suspension then I wouldn't consider that a full build but that's just my idea of what a full build is. If the car will be a track car then you'll probably want an aftermarket suspension system to take full advantage of the additional horsepower.
    Veteran Member Three Rings RS3TP's Avatar
    Dec 22 2018
    Richmond Hill, Ontario
    Stay with the fixed ride suspension ... it's the better choice. I use mine daily, it took me a bit to get use to it (had a 2018 Golf R), but I would never swap it now for the Mag ride. it just feels more precise
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Quote Originally Posted by OE2 View Post
    Quote Originally Posted by Jeff_Jeske View Post
    QFT
    Feb 09 2019
    Sydney
    As above, if you’re going to hit the track then you will want better suspension than stock, either magride or fixed won’t do it.
    Magride is great for ironing out the small bumps.
    But with your power level goals and track use you will want coil overs. The big benefit of going fixed suspension is being able to replace it without the hassle of using mag ride deletes to fool the ecu. They are costly and troublesome.
    Jul 19 2008
    Earth
    Quote Originally Posted by WmRS3 View Post
    I have had both these cars with mag ride and the Audi is way better then the s60Rs (assuming you're talking about the mid 2000s s60Rs.) I actually owned 3 of those cars and loved them. That system was advanced for its time but nothing like the Audi's mag ride. I have mag ride and enjoy it and came from a fixed suspension S3.
    Dec 13 2019
    MA
    Quote Originally Posted by P5stunna View Post
    Full build is the plan I think fixed is the way to go. On the Volvo I had to cut up old shocks and plug the sensors in on the KW swap to avoid a cel.
    Dec 13 2019
    MA
    Quote Originally Posted by Dubfound View Post
    https://www.youtube.com/watch?v=glYdv1e77HY
    https://www.youtube.com/watch?v=KOXYEUGhrsY
    Mar 27 2019
    Michigan
    I guess it really depends on the roads you're going to be driving. Here in SE Michigan, we have SHIT roads. Areas where rebar is showing through, mag ride is a must have here. I daily my car and notice a huge difference if I drive around with suspension in dynamic vs comfort. There's no way I would of gotten fixed sport suspension in such a small wheelbase car, coupled with skinny sidewall tires for a daily.
    19' Ara Blue RS3, Milltek Mid pipes, XPEL front of car, ceramic coat on rest of car, 15% tint
    Dec 13 2019
    MA
    Quote Originally Posted by dvan5693 View Post
    Roads here suck but again the Raptor is my daily so I think I will stay with fixed because of the full build plan.
    Mar 27 2019
    Michigan
    That makes sense. Playing devils advocate. If you're gonna do a build(tune and or more?) why not just pick up a used one and save cash?
    Dec 13 2019
    MA
    I looked at used but don't want a car someone beat the piss out of and then got rid of. I take proper care of everything I own and no exception for the Audi. Xpel and ceramic is first on the list. I want to start fresh new and built to my specs. I plan to keep for long time. Going on 12 years on the Volvo build and plan to keep that as well.
    Sep 13 2019
    Based on your comments/discussion, I would go for fixed suspension. I got the mag ride due to the harsh comments about the fixed suspension. However, I regret it, and it will cost me an additional $400 for the DCC cancelers on top of the coilovers. To me, the RS3 drives like a boat.
    '18 RS3
    Senior Member Three Rings Phayl's Avatar
    Dec 12 2017
    Dallas, TX
    Why not pick up a new 19? Can get one for 50-51k fully loaded right now, then the extra $ you have towards mods & whatever financial investments you make.
    Dec 13 2019
    MA
    Quote Originally Posted by Phayl View Post
    Thought about it couldn't find exactly what I wanted the few times I looked and am really set on a 2020 now and already ordered it and gave deposit. Thanks for the suggestions everyone.
    May 28 2018
    2022 RSQ8 and M2CS
    Houston, TX
    Quote Originally Posted by arenared View Post
    I just had the Bilstein PSS10 coil-overs installed along with the DCC cancelers, plus 034 camber plates. It's early but this car now drives like a true performance/sports car should...THIS coming from a BMW M owner. Can't wait to get it on the track.
    Nov 23 2019
    earth
    Glad you were able to make up your mind, I have driven a friends 2018 with fixed and it was actually painful to drive after a few hours.. Haven't managed to borrow a 2019 Mag for more than 30 minutes.. so I'm really torn..Every 2019 with the options i want has the fixed suspension.. every one of the 177 left in Canada !
    I agree completely that I don't want someones bagged crap .. I showed for a private test drive with ODIS ...( It was only driven on weekends by a little old lady :-) wanted to check the launch counter ... ummh ah no..
    So planning to order a 2020 with ... Mag ride as it will be my Daily drive.. ( Mag ride is the default in Canada)
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Had mag ride in 2017 S3 and never used another mode, on my TTRS I got fixed suspension granted I live in FL but I don’t notice too much more harshness from mag ride in dynamic to fixed, its stiffer but the car can still take bumps without breaking you
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Jul 13 2018
    Winnipeg, MB, Canada
    Make your choices based on how you will drive the car 90-99% of the time, not that one weekend a year. This is single biggest mistake people make.
    Remember, you buying an Audi RS, which is a blend of performance and luxury, and they do a good job at balancing those. It is not a race car and isn't trying to be.
    I think being able to change the shock stiffness is an amazing feature that I appreciate everyday. There is a very noticeable difference between dynamic and comfort on less than perfect roads.
    Nov 26 2017
    2019 Audi SQ5
    Boise, ID
    Quote Originally Posted by S3DUDE View Post
    Think you might have some things backwards man...in 2018 the ONLY way to get fixed suspension was to get the Dynamic Plus package with carbon ceramic brakes, direct TPMS, etc. So if you have the Dynamic Plus you DO have fixed suspension, and if you have mag ride, then you do NOT have carbon ceramics, etc.
    Current:
    2019 RS3, Glacier White w/Black Ops, Uni 1+ e85, Iroz FMIC, AWE S-Flo 4.5" intake & midpipes, KW HAS, Malaka throttle body and IC hose and piping upgrade, Xpel PPF & Ceramic
    2019 RS3, Daytona Gray w/Black Ops, Uni S2e85 with Iroz parts (sold)
    2015 S4 6MT, GIAC Dual Pulley, AWE CAI Exhaust, Tampa Ported Blower, Ringer Stg 4 Clutch, too much other stuff to list (sold)
