Results 1 to 14 of 14
    Junior Member Two Rings
    Apr 05 2011
    Which ceramic brakes fit our cars?
    In the market for new brakes and would like to buy ceramics. I'm wondering which brakes (if any) would fit our cars.
    Audi S8
    Audi RS3
    Audi R8
    Lamborghini Gallardo (same as R8)
    Alternatively, I am considering Stoptech, Brembo and MOVIT if I cannot source ceramics. I've seen a couple variations of BBK's installed from a while back but haven't seen any updated threads. Post your setup!
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    S8 is likely too large. S8/RS7 ceramics are 400mm or so. You need much larger wheels.
    Earlier R8 might fit, as might RS3 (370mm). The issues are: 1. Will calipers bolt on? 2. Is the center bore different such that the rotor won't fit?
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    The car came originaly with a carbon-ceramic brake option. So the OE brakes will fit best me thinks.
    https://www.audizine.com/forum/showt...ceramic-brakes
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Apr 05 2011
    Quote Originally Posted by ven0m View Post
    OEM B7 RS4 ceramics are unfortunately hard to source as opposed to some of the other options and extremely expensive new. I would also like matching ceramic rears (like in S8 and R8). OEM B7 ceramics were only front.
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    That was a once in a lifetime deal I feel like. Could always pay the $17k
    https://europrice.us/ceramic-brake-package-rs4#
    Apr 05 2011
    Definitely not interested in paying $17k for ceramics! Anyone else fit bigger brakes on an RS?
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Quote Originally Posted by RS4.2 View Post
    Not ceramic but I have the ST60 380mm kit on the front of my car, ST40 355mm in the rear also
    Apr 05 2011
    Any photos? Mind sharing which vendor you sourced them from? Is the braking power considerably better than stock?
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    Are you having an issue with the stock brakes?
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by mtwallace85 View Post
    I have talked to my local dealer and they could get me new complete ceramic RS4 front brakes (rotors, pads, calipers, lines, and wear sensors) for like $10K plus tax. Thus I will stick to steel brakes forever!
    Highly doubt that steel brakes even on a supercharged or turbocharged S4/RS4 wouldn't be enough.
    Jun 11 2012
    Corona, CA
    Yeah, even at $10k it’s a bit ridiculous. Ceramics are certainly overkill, but at the same time, I wouldn’t mind a set on the car.
    Feb 06 2015
    I think it all depends on purpose. The stock brakes are quite good. With good pads and fluid, it would likely fit 99.5% of needs of owners.
    However, some people like the aesthetics of either a big brake kit, different rear caliper, ceramics, etc. In that case it all depends on their wallet.
    Apr 05 2011
    Quote Originally Posted by MugelloB7RS4 View Post
    Rear brakes are gone and don't want to invest in rotors and pads when I can do a rear BBK for not much more. However, I'd rather do front and rear rather than rear alone while I am at it.
    Aug 02 2015
    Corning NY
    Rear brakes are gone and don't want to invest in rotors and pads when I can do a rear BBK kit for not much more. However, I'd rather do front and rear rather than rear alone while I am at it.
    My 0.02$
    My car is the craziest braking car I’ve driven lol.
    A 6 pot front setup with SS lines perform better because 2 less pistons to push. Also pads for the ST60 are cheaper then RS
    And I’d say do Bosh mods rear
