Results 1 to 9 of 9
    Established Member Two Rings evilpulse8's Avatar
    Mar 10 2014
    B8 Avant Prestige A4, B7 A4 revo stg 2(sold), B5 S4 vast stage 2(sold) B8 A4 Avant Sline
    City of Industry
    Bad Throttle Pedal???
    Everytime I go WOT the car goes into limp mode. Scan seems to point directly to position B on throttle pedal. Ordered a gas pedal, was this the right choice? Checked my firewall and it was cluttered with leaves and cleaned them out along with opening and inspecting ecu and unplugging relays and harnesses. This has happened before after a car wash or heavy rain but now it's frequent everyday. Load test on gas pedal is 89% when all the way down to the floor testing through obdeleven. The fault sometimes went away after unplugging pedal or abs harness.
    OBDeleven data log
    Date: 2019-12-10 00:11
    VIN: WAU4FAFL2AA147257
    Car: Audi A4
    Year: 2010
    Body type: Avant
    Engine: CAEB 155 kW (211 HP) 2.0 l
    Mileage: 88320 KM
    01 Engine Control Module 1
    System description: 2.0l R4/4V TF
    Software number: 8K2907115AL
    Software version: 0003
    Hardware number: 8K2907115D
    Hardware version: H16
    ODX name: EV_ECM20TFS0118K2907115AL
    ODX version: 001003
    Long coding: 010C010A190F0160
    Trouble codes:
    U111300 - Function limitation due to received malfunction value
    static
    Date: 2019-12-09 23:50:59
    Mileage: 88308 km
    Priority: 6
    Malfunction frequency counter: 2
    Unlearning counter: 255
    Engine speed: 2242.50 1/min
    Normed load value: 41.6 %
    Vehicle speed: 60 km/h
    Coolant temperature: 89 °C
    Intake air temperature: 14 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 14.112 V
    Dynamic environmental data: 209628
    P022100 - Throttle/Pedal Position Sensor/Switch B Range/Performance
    static
    Mileage: 88308 km
    Priority: 2
    Malfunction frequency counter: 1
    Engine speed: 2418.00 1/min
    Normed load value: 52.9 %
    Vehicle speed: 59 km/h
    Intake air temperature: 15 °C
    Voltage terminal 30: 14.041 V
    02 Transmission Control Module
    System description: 0B6 20TFSIUSA
    Software number: 8K0927158J
    Software version: 0009
    Hardware number: 0B6927156
    Hardware version: H05
    ODX name: EV_TCMAL651
    ODX version: A01006
    Long coding: 001012
    Trouble codes:
    P263700 - Torque Management Feedback Signal "A"
    static
    Date: 2019-12-09 23:51:02
    Mileage: 88308 km
    Priority: 2
    Engine speed: 2204.00 1/min
    Transmission input speed: 1667 1/min
    Transmission output speed: 1923 1/min
    Engine torque: 192 Nm
    Transmission fluid temperature: 41 °C
    Accelerator position: 28.4 %
    Clutch status: 0
    03 Brakes 1
    System description: ESP8 quattro
    Software number: 8K0907379CA
    Software version: 0030
    Hardware number: 8K0907379CA
    Hardware version: H04
    Serial number: --------------
    Long coding: 150D18
    Trouble codes:
    01314 - Engine control module (ECM) Please read DTC
    static
    Priority: 6
    Frequency counter: 2
    Driving cycle: 180
    Mileage: 88308 km
    00473 - Electronic parking brake control module -J540 Please read DTC
    static
    Priority: 6
    Frequency counter: 1
    Driving cycle: 180
    Mileage: 88308 km
    Date: 2019-12-09 23:51:00
    04 Steering Angle Sender
    Trouble codes:
    No trouble codes found
    05 Kessy
    System description: BCM2 1.1
    Software number: 8K0907064DH
    Software version: 0326
    Hardware number: 8K0907064DH
    Hardware version: H02
    Long coding: 0D0200
    Subsystems:
    System description: J764 ELV MLB
    Software number: 8K0905852D
    Software version: 0042
    Hardware version: H37
    Serial number: 0210000022658009
    Trouble codes:
    08 Air Conditioning
    System description: KLIMA 3 ZONEN
    Software number: 8T1820043AQ
    Software version: 0171
    Hardware number: 8T1820043AQ
    Hardware version: H08
    Serial number: 01070320100372
    Long coding: 64102000
    Trouble codes:
    09 Central Electrics
    System description: BCM1 1.0
    Software number: 8K0907063P
    Software version: 0380
    Hardware number: 8K0907063P
    Hardware version: H25
    Serial number: 00000000483838
    Long coding: 26001091063CAF010000080300003D0D0F1C46080201016100 0000
    Subsystems:
    System description: WWS 050310
    Software number: 8K1955119A
    Software version: 0070
    Hardware version: H06
    Serial number: SWF10030050126
    Long coding: 00FD11
    System description: RLS
    Software number: 8K0955559
    Serial number: 10809128
    Long coding: 025028
    System description: E1 - LDS
    Software number: 8K0941531AL
    Software version: 0090
    Serial number: 00000000002202101216
    System description: HOMELINK
    Software number: 8K0907410C
    Software version: 0010
    Hardware version: H01
    Trouble codes:
    10 Parking Assistance 2
    System description: PARKHILFE 4K
    Software number: 8K0919475Q
    Hardware number: 8K0919475
    Serial number: 51241006901609
    Long coding: 200103
    Trouble codes:
    15 Airbag
    System description: AirbagVW-AU10
    Software number: 8K0959655K
    Software version: 0610
    Hardware number: 8K0959655K
    Hardware version: H41
    Serial number: 003GLD0D0VCN
    ODX name: EV_AirbaECUVWAUDI010
    ODX version: 003010
    Long coding: 303837354230303030304A55304C384B3053
    Subsystems:
    System description: BF-Gewichtss.
    Software number: 8K0959339B
    Serial number: 5810000R10000069TC
    Trouble codes:
    16 Steering Column Electronics
    System description: Lenks.Modul
    Software number: 8K0953568F
    Software version: 0014
    Hardware number: 8K0953568F
    Serial number: 90304JCA0006E
    Long coding: 000037
    Subsystems:
    System description: E221 - MFL
    Trouble codes:
    17 Dash Board
    System description: KOMBIINSTR.
    Software number: 8K0920980M
    Software version: 0255
    Hardware number: 8K0920980M
    Hardware version: H20
    Serial number: CIX27VU2A
    Long coding: 8B1711000300D705020000
    Trouble codes:
    19 Gateway
    System description: GW-BEM 5CAN-M
    Software number: 8T0907468AE
    Software version: 0116
    Hardware number: 8T0907468L
    Hardware version: H10
    Serial number: 5700F102130200
    Long coding: 00C303
    Subsystems:
    System description: J367-BDM
    Software number: 8K0915181E
    Software version: 0170
    Hardware version: H07
    Serial number: 1000A20A200210
    Trouble codes:
    36 Seat Adjustment Driver Side
    System description: MEM-FS
    Software number: 8K0959760D
    Software version: 0074
    Hardware number: 8K0959760D
    Serial number: 00001010091535
    Long coding: 00581B00000000000000
    Trouble codes:
    3C Lane Change Assistant
    System description: J0769_SWA_MasterH01
    Software number: 8K0907566H
    Hardware number: 4L0907566B
    Serial number: 6PZ 009 014-82
    Coding: 0000002
    Subsystems:
    System description: J0770_SWA_Slave_H01
    Software number: 8K0907568H
    Trouble codes:
    42 Door Electronics Driver Side
    System description: TSG FA
    Software number: 8K0959793H
    Software version: 0306
    Hardware number: 8K0959793D
    Hardware version: H11
    Serial number: 0000010232170
    Long coding: 011C13204E00410001
    Trouble codes:
    46 Central Module Comfort System
    Serial number: 0123048947
    Long coding: 0126063A203A741500B0023200000000
    Subsystems:
    System description: GTO BF
    Software number: 8K0959719
    Software version: 0050
    Serial number: 00000000000000227645
    System description: LIN BACKUP HO
    Software number: 1K0951605C
    Software version: 1501
    System description: J245 PS133
    Software number: 8K0959591A
    Software version: 0041
    System description: J394 PS229
    Trouble codes:
    47 Sound System
    System description: DSP Prem
    Software number: 8T0035223AN
    Software version: 0190
    Hardware number: 8T0035223AK
    Serial number: 34882001626201
    Trouble codes:
    52 Door Electronics Passenger Side
    System description: TSG BF
    Software number: 8K0959792H
    Hardware number: 8K0959792D
    Serial number: 0000010241745
    Trouble codes:
    53 Parking Brake
    System description: EPB Audi B8
    Software number: 8K0907801H
    Software version: 0100
    Hardware number: 8K0907801H
    Hardware version: H09
    Serial number: 00000000588159
    Trouble codes:
    static
    Priority: 4
    Driving cycle: 180
    Mileage: 88308 km
    55 Headlight Regulation
    System description: Dynamische LWR H01
    Software number: 8K5907357
    Coding: 0000004
    Trouble codes:
    56 Radio
    System description: Radio U SIRIU
    Software number: 4F0035082A
    Software version: 0021
    Hardware number: 4F0035082
    Hardware version: H45
    Serial number: 335CX0A7557370
    Long coding: 020000010000000001
    Trouble codes:
    5F Information Control Unit 1
    System description: H-BN-NA
    Software number: 8T1035664B
    Hardware number: 8T1035664B
    Hardware version: H47
    Serial number: 490CZ0A7552780
    Long coding: 010200010306A1EF51000B0E000000030000
    Subsystems:
    System description: NAR 2009/2010
    Software number: 8R0060884F
    Software version: 5304
    System description: DU7 High
    Software number: 4F0919604
    Hardware version: H43
    Serial number: 9356CJ0A1212308
    System description: E0380 Bedient
    Software number: 8T0919609G
    Serial number: 00000000485106
    System description: CD-Database
    Software number: 8R0906961A
    Software version: 1293
    Trouble codes:
    62 Door Electronics Rear Left
    System description: TSG HL
    Software number: 8K0959795C
    Hardware number: 8K0959795C
    Serial number: 0000103071891
    Long coding: 010C13204000210001
    Trouble codes:
    6C Camera System Rear View
    System description: J772__Rearview
    Software number: 8T0907441C
    Software version: 0040
    Hardware number: 4L0907441B
    Serial number: 525PA8-J0290XO
    Coding: 1000007
    Trouble codes:
    6D Deck Lid Control Unit
    System description: J605 Master
    Software number: 8K9827851A
    Software version: 0300
    Hardware number: 8K9827851A
    Hardware version: H27
    Serial number: 8K9827851A
    Subsystems:
    System description: J756 Slave
    Software number: 8K9827852A
    Serial number: 8K9827852A
    Trouble codes:
    72 Door Electronics Rear Right
    System description: TSG HR
    Serial number: 0000103071899
    Trouble codes:
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    I would assume either the pedal or the throttle body itself but it doesnt seem to have any of the codes I would expect if it was the throttle body. So think you made a good choice in terms of the parts cannon.
    Mar 10 2014
    City of Industry
    Well now this time my car won't start and I finally have a throttle valve position fault so I'm gonna have to pull out the TB. Probably plastic gears sheared off.
    Nov 20 2016
    Quote Originally Posted by evilpulse8 View Post
    well there ya go ;)
    Jul 16 2018
    Atlanta
    The original error implies a problem with the accelerator pedal position sender 2, G185.
    When you look at the measuring values for IDE00086 (position sender G79) and IDE01880 (position sender G185), do they make sense and is one exactly half of the other? (I think this was the one where one was one half the other, could have been something else)
    100% = 5volts, the supply voltage to the senders. G185 is half the other because of an inline resister.
    Interesting, SSP seems to imply that failure of one of the senders will result in disabling of the cruise control system.
    As for the throttle valve, position (IDE00083, angle sender G187) and position 2 (IDE01650, angle sender G188) should match, and position normed (IDE00349) should track position specified (IDE00583).
    But I'd log the data and go to where the bad data lies.
    Mar 10 2014
    City of Industry
    Quote Originally Posted by Smac770 View Post
    I checked the pedal throttle positions and they were all 89-90% I don't recall seeing one at 50% value. Also took apart TB and found no broken gears.
    Jul 16 2018
    Atlanta
    My bad. I was remembering this video (youtu.be/fdLA5pXUkk4?t=280). But looking at the actual values on our ECU, the ECU normalizes both sensors to 15-95% range. Still curious why have 15-95%, but then have ENG105194 on a full 0-100% range. You can see the actual voltage values, 2 is roughly half of 1 (IDE00392 and IDE00393), as expected.
    I was looking for the Audi specific message in the DTC, but I don't see it. I see this is OBD11 instead of VCDS; maybe OBD11 can't read that. Something along the lines of http://wiki.ross-tech.com/wiki/index...5/P0221/000545 where P0221 is the generic code like we see for you, something like the rest of the text is the Audi specific message that actually points to the real problem, which you don't have.
    Try clearing all and see if it comes back. Maybe it was just a hiccup.
    From the Audi 2009-2010 A4 quick reference specification book:
    P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
    • TPS 1 - TPS 2 > 6.30%
    and
    • Actual TPS 2 calculated value > actual TPS 1 calculated value
    or
    • TPS 2 calculated value > 9.00%
    It seems from all this stuff that your DTC is likely talking about the throttle plate angle sensors rather than the accelerator pedal position sensors. I don't know what to make of that trigger specification. I'm guessing:
    (|IDE00083 - IDE01650| > 6.3%) and (IDE01650 > IDE00083 or IDE01650 > 9%) ?
    IDE00349 (normed), IDE00583 (specified), and ENG109415 (feedback) all seem based around the normalized value
    There's a TSB for earlier transverse TSI throttle body plug wiring (2018652), but not sure if it would be relevant to your car.
    Mar 10 2014
    City of Industry
    and
    or
    I'll charge my laptop tonight to run vcds in the morning. There's not TSB on my car when looking up the vin just the tensioner which was already done during piston replacement at 33k miles
    Mar 10 2014
    City of Industry
    Replaced pedal, still no dice. Wiring is going to be faulty somewhere. Going to put it on jacks, last things I did was unplug diverter and also did my rear brakes and put a HFC.
