Results 1 to 24 of 24
    Senior Member Two Rings Serpex13's Avatar
    Jul 18 2019
    2011 GS Corvette
    Illinois
    Audi RS7 Rotor and brake pad thickness
    I cant find it anywhere. Does someone mind telling me what these numbers are for the front and rear?? Thanks
    2016 Audi RS7 - | DS1 with custom SRT ECU Tune | Carbon Optics Package | Alcantara Headliner | TawCustoms Carbon Fiber/Alcantara Steering Wheel | Miltek Non-Res Exhaust + 3 inch Catless DPs | 20’ HRE P44SC Bronze Chrome Matte | 285/30/20 Michelin PS4 | Neidfaktor Carbon Fiber Mirror Caps
    IG: glacier_rs7
    2011 Corvette GS H/C/I
    Senior Member Two Rings rabbitdog's Avatar
    Aug 03 2018
    Ontario
    This thread has the details:-
    Rs7 brake rotors and pads need replacement at 33k
    https://www.audizine.com/forum/showthread.php?t=778392
    Jul 18 2019
    2011 GS Corvette
    Illinois
    Quote Originally Posted by rabbitdog View Post
    Found that thread for the rotor thickness thanks! It doesnt say about the brake pad thickness
    IG: glacier_rs7
    Junior Member Two Rings
    Sep 24 2019
    Virginia
    Quote Originally Posted by Serpex13 View Post
    Deleted my previous post to specify...
    Assuming these are for iron discs - brembo specs the backing plate + pad material as 16.8mm
    Jul 18 2019
    2011 GS Corvette
    Illinois
    Quote Originally Posted by need2blower View Post
    Ok thanks. I just now need to figure out what the backing plate thickness is haha. And these are for Brembo specs
    Sep 24 2019
    Virginia
    If their drawing is to scale, which it should be - The backing plate is 6.10mm and the friction material is 10.7mm. This is just for the front by the way, rear drawings show...
    Total thickness = 17.4mm, backing plate = 5.4mm, friction material = 12mm.
    Jul 18 2019
    2011 GS Corvette
    Illinois
    Cools thanks for the info! One last question. Does it say what thickness is considered time to change? I’m buying a car with 7mm thickness all around and will clarify as I assumed they just measured the friction material
    Sep 24 2019
    Virginia
    It doesn't give that info - the hole for the wear sensor is not even drawn on the friction material so I cant even use my imaging software to estimate. If you'd like to get the service tag from the trunk of the vehicle (near the spare) and PM a picture of it to me, that's likely something I can look up in the factory service manual.
    The rotor thickness is what I would be worried about as they are big money, pads are cheap...
    Jul 18 2019
    2011 GS Corvette
    Illinois
    I will shoot you a pm when I get the car! The rotor thickness is 35.7 on both fronts and 21.7 on both rears so I am good there.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    A quick Google check said that states with vehicle inspection requirements showed the min thickness is 2/32nds of an inch which is roughly 1.6mm. I think the Audi wear sensor will be wiped out before that amount. I want to say they trigger at about 3mm.
    Jul 18 2019
    2011 GS Corvette
    Illinois
    Quote Originally Posted by Valpo A7 View Post
    Mar 12 2018
    Toronto, ON, Canada
    What rotor thickness is considered time to change?
    I'm typical dealer fashion, I brought my RS7 in for warranty work (fuel door actuator died) and they happened to tell me my rear pads were 4mm and rotors had grooves. No sensor has gone off at 4mm (assuming I believe those scoundrels) and so maybe 3mm is correct for pad wear sensor.
    But I'm thinking if the rotor thickness is adequate, that I can machine them true again prior to replacing the pads. A cheaper process. I am aware that machining removes material as well, but if still within the limit of safe and practical, I dont mind doing that as an intermediate step.
    Thanks
    Sent from my SM-G960W using Tapatalk
    2017 RS7 Nardo grey w/ Black Optics | Carbon | Miltek Non-res Catback | SRM intake (long) | Lowering Links + VAGCOM | Flush fit ECS Spacers | Blacked Out Heads/Tails/emblems/roof wrap
    Prior:
    2014 nicely built S5 Technik
    Jul 18 2019
    2011 GS Corvette
    Illinois
    Quote Originally Posted by blackout85 View Post
    Thanks
    Front rotors come 36mm new and you should discard them at 34.4.
    Rear rotors come 21.9 new and discord at 20.4.
    Still haven’t fully discovered what the pad thicknesses are yet
    Mar 12 2018
    Toronto, ON, Canada
    Thank you good sir. Where did you find that info? For future reference.
    Prior:
    Jul 18 2019
    2011 GS Corvette
    Illinois
    In the 2nd post of this thread, there is a link to another audizine thread that has come good info. Side question: how do you like you exhuast? I’m debating akkrapovic or milltek
    Mar 12 2018
    Toronto, ON, Canada
    Thanks. I was driving when I went through the thread this morning so didn't have time to spend looking at that link. It's on the to do list tho. Thanks...
    As for miltek, can't say enough good about it. I was in that same dilemma. I have had akra in the past and love them. You won't beat the quality of the titanium but from a pure sound perspective, I'm extremely happy with the miltek and so is everyone that has heard it. It rreeeally wakes it up. The akra would as well no doubt. But at the time I didn't justify the extra cost when for the difference I did the ecu/TCU tune, some SRM parts and had a bunch of cosmetic stuff done.
    You won't be disappointed either way. If budget allows the akra is a better quality exhaust, but doesn't sound twice as good to justify the price difference of roughly that.
    Lemme know what you do!
    Prior:
    Jul 18 2019
    2011 GS Corvette
    Illinois
    Just got my rs7 and had an akra on my s6. Tough choices!!
    Mar 12 2018
    Toronto, ON, Canada
    Hahaha these are good problems to have my friend! Go with your gut lol. You know the power of Akra!
    I'm also thinking of Akra for my other toy. I bought it with an exhaust that I know I can do better with. And akra always comes to mind... So I still find myself with the same tough choices haha
    Prior:
    Sep 24 2019
    Virginia
    Managed to find the model code off of a 16' rs7...here's some numbers straight from the workshop manual - the rotors you're looking at are the "wave design" in the charts. I'll included the carbon discs in another post for future reference.
    Mar 12 2018
    Toronto, ON, Canada
    Amazing... But I can't see the charts. Not sure if it's just me/my phone. Tried the AZ app and tapatalk tho.
    Prior:
    Sep 24 2019
    Virginia
    It's not you, it wont let me link from imgur. Fixing the post now :-)
    Jul 18 2019
    2011 GS Corvette
    Illinois
    Thanks! Makes me feel better about my pads being 7mm all around
    Mar 12 2018
    Toronto, ON, Canada
    Great thank you!
    Prior:
    Sep 24 2019
    Virginia
    Pads are the same spec for carbon rotors but there are a few different ways to check the rotors. Looks like you can even weigh them There is a special note to clean the carbon rotors before measuring them.
    The manual does not specifically state the limits for the rear as it does for the front. It specifies to use the first flow chart I posted and the min thickness and weight should be stamped onto the brake hub.
