Results 1 to 10 of 10
    Oct 20 2018
    Orlando FL
    How to Dyno B8.5 S4 with DSG
    Hey guys, for the last few hours I have been searching through google and here in the forums and can’t find an answer. I have a 2015 S4 with DSG and I went to get the car dynoed to get a baseline number before going IE Stage 2 dual pulley. We loaded the car on there and first tried a 4th gear pull at 3k rpm on a Mustang Dyno. As soon as we started the car downshifted to 3rd. So we attempted again but in 3rd fear this time. The car seemed to have gone into limp mode and only reads 200hp. What are we doing wrong? I even took the car off the Dyno to drive it down the street and back to get the car back to normal in order to take off the traction control.
    Veteran Member Three Rings fstr n u's Avatar
    Jan 20 2015
    Maybe a stupid response....was your traction control fully disengaged? If all 4 wheels are moving at the same rate of speed on a dyno, i'm not sure why it would kick out. Wait for others to chime in.
    2019 Audi SQ5 Navarro Blue Technik w Black Optics Pkg - stock for now
    2015 Audi S4 6MT Glacier White w Black Int (IE Stg 2, Merc Hx, CTS Turbo CAI & CTS S/C Pulley) - my DD
    2006 Subaru STI Hawkeye Murdered Out - larger turbo 400hp - son's car
    1998 Chev Camaro 6MT, LS2 Rear mount Turbo (710+rwhp/710+rwtq @ 14# boost wheels) - summer hooligan
    http://www.youtube.com/@musclecarfan1
    https://www.instagram.com/ryan_baliski/
    https://www.tiktok.com/@winewithryan
    Account Terminated Two Rings celticsevad's Avatar
    Jan 23 2019
    Montreal.Canada
    you just wanna put the gaz pedal 1'' from the end of it, i mean, you have a ''switch'' at the end of the pedal, it engage the kickdown, just put your foot on the pedal with the car OFF you will sens it ! enjoy!
    Mar 28 2016
    Quote Originally Posted by celticsevad View Post
    Does it kick down when in manual? I have not experienced that happening.
    Jan 23 2019
    Montreal.Canada
    Yes it does
    Quote Originally Posted by hilmar2k View Post
    Sent from my CLT-L04 using Audizine mobile app
    Mar 28 2016
    Yes it does
    Apparently I'm not pushing down hard enough with my right foot.
    Oct 20 2018
    Orlando FL
    Yes, I pushed and held the button so it was completely off. When it goes into limp mode, it seems to re-engage. I either have to wait a while or drive the car off the Dyno in order for everything to clear. Then I can take traction control off again.
    Oct 20 2018
    Orlando FL
    Are you referring to trying to Dyno it in 4th gear? If so, I didn’t know that switch would activate the downshift to optimal gear. I will try it.
    Either way, I still need to understand why it keeps going into limp mode mid Dyno run. The parking brake light malfunction light comes on, ECS malfunction comes on and I think there was something else that displayed on the cluster.
    Oct 20 2018
    Orlando FL
    I called integrated engineering and the sales guy asked a tech. They suggested disconnecting one of the ABS sensors, sounds kind of weird.
    Oct 20 2018
    Orlando FL
    Today on the highway I tried out the pedal switch. I always knew there was a switch but didn’t understand what it was for. It is correct, I was able to stay in 4th gear until I hit the switch. Once I hit the switch it would down shift.
    I will try that when I go in to try to Dyno the car again.
    I’m still trying to figure out if there is some sort of Dyno mode that prevents the car from going into limp mode.
