A few month ago I bought a super cheap second hand OEM IHI JH5 turbo, Aka K03 ( I don't know why people continue calling it like that)
To study it and see if it was possible to get a hybride built out of it.
When opening it I saw that It got same old style cast compressor wheel as Golf MK6 GTI 40.2/52.5mm
But to my surprised the Turbine Was a very modern Mixed flow 52mm inducer and 44mm exducer with 7 blade and maximum open back to save weight. The Golf GTI Mk6 has 8 blade 45mm/41mm only
What a good surpise knowing that the K04-064 has got a turbine 51mm inducer 44.5mm Exducer with 12 blade and older radial flow shape.
So if I'm not wrong the fact that the JH5 turbine is mixed flow this shape of turbine is the most efficient at the moment and that it's also a bit bigger than the K04_064 turbine let me believe
that the Hot side of this JH5 has more potential than the K04-064 hot side.
So then I search what other compressor wheel are fitted to the JH5 on other platform.
Keep in mind that the K04-064 come with a 46.39mm inducer and 56.08mm exducer compressor wheel 6+6 blade forge CNC wheel
I found that the Audi S6/RS6 4.0TFSI use two JH5 turbo. those are fitted with a 44.2mm inducer and 58mm exducer.
then I found this 4.0TFSI Compressor wheel 44/58mm with 62.46mm extend Tip, narrow nose 6+6 blade Forge alloy cnc .
https://www.ebay.co.uk/itm/Kinugawa-...-/253175182607
I thought mixing this Modern JH5 B8 Mixed flow turbine with a modern 4.0TFSI 44/58mm extend tip could be a very great turbo, plug and play quite cheap.
So I got a company to rebuild that turbo with reinforced 360 bearing, 5 axe CNC ported Compressor housing to fit that 44/58mm compressor wheel.
Then very thing balanced to 250.000 rpm.
That hybrid turbo just arrived to me.
I will instal it in the coming month and get the car tuned for E85.
I will let you know what I put down.
Let's hope that my assumption on the turbine are right and that just did not spend 900 Euro for nothing.
