It's a piece of cake to install, call Christian at Enfig and he'll sort you out with all the adapters etc. needed for the basic install. With all that it is virtually plug and play, no soldering, nothing, just plug in the harness and done.
Routing the microphone is easy, most people mount them in the factory location up by the sunroof controls. Going by memory here, but pry off the light cover and you should see 2 screws, undo those and pull the unit down, from there poke your microphone wire carefully above the headliner towards the windshield. Pull down the headliner carefully until you can pull the wire through, then feed it along the headliner and down the A-pillar (you can remove the A-pillar if you want, but not 100% required). Pop off the cover at the side of the glovebox and feed the wire across the top of the glovebox towards the back of the head unit. Here's a video:
https://youtu.be/SK1itSwt4NA
Where do you want to route the iPhone cable? I have a Kenwood with 2 x USB outputs, I routed one to the glovebox, very simple to do, remove the 12-15 screws, 2 are underneath, 6 or so along the front lip and 4 in the rear, I think, from the glovebox (this may also make installing the microphone cable a little easier) and remove the glovebox. Route the iPhone cable through one of the cut outs at the back of the glovebox and re-install it, with it down would be a good time to zip tie up the microphone cable.
My 2nd USB output I installed in the front ashtray, makes it easy to plug my phone in while it sits in the cupholder. To do that with the head unit removed, slide out and unplug the climate control unit, remove the ashtray and cut a slot for the USB to go through. Feed the USB cable into there and then re-install the ashtray, climate control and head unit.
I definitely would not pay a shop to do the install, none of it is hard. The toughest piece will be getting the A-pillar back on if you decide to remove it, can be a pain to line up the clips as you can't see them.
