I need some advice to figure out why after everything gets back together I loosen the bleed valve on the slave cylinder to bleed the system and the pump keeps pulling bubbles continuously. The clutch was operating fine up until this point, all I did was take out the old line and put in the new one. The clutch pedal will stay up or down and has no pressure, the reservoir is topped off and I don't see or hear any leaks.
The series of events:
- Driving when clutch started sticking to the floor (if depressed for longer then 10 sec will stay down)
- Located a leak in the rubber line attached to the slave cylinder
- Replaced the line
- Attempted to bleed the clutch
- Bubbles will not stop coming out of the bleeder
Any Advice or links to posts would be much appreciated
