Results 1 to 33 of 33
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    APR Stage 3 Now Available - Up to 740 HP.
    APR Stage 3 ECU Upgrades are now available for the 2017-2018 2.5 TFSI EVO as found in the RS3 and TTRS. MY2019 ECUs to follow.
    This stage is available for multiple setups, and are all designed around using a drop-in turbocharger upgrade. Stage 3 has specific software for the TTE700 and GTX3582 drop-in turbo upgrades. Both require a APR TCU Upgrade, race DP exhaust system, midpipes, 980cc port injectors, turbocharger inlet system, intercooler, and NGK heat range 9 (NGK-R7437-9) spark plugs gapped to 0.024" ±0.002" or 0.6mm ±0.05mm with a change interval of 10-15,000 mi or 16-24,000 km. The TTE700 requires the included wastegate actuator. The GTX3582 requires the included turbosmart wastegate actuator and MAC 3-port solenoid. A proper 500 LPH+ @ 6 bar LPPF is required to run E85, but the stock LPFP is ok for all other fuels.
    The TTE700 produces 576-713 HP with 523-536 FT-LBS of torque. the GTX3582 produces 581-740 HP with 511-555 FT-LBS of torque. RHD vehicles without the turbo inlet will experience reduced output. In all cases, torque is kept flat to aid in component longevity.
    This stage has a optional high and low grip modes designed to reduce wheel spin and aid in 60 FT and 0-60 times depending on surface prep. Additionally this stage is available with optional exhaust crackle modes. The more aggressive modes increase the length, duration, intensity, and operating modes of the exhaust crackle. Aggressive modes are only recommended with testpipes.
    APR Stage 3 is available for 91 AKI, 93 AKI, 100 AKI, 104 AKI and E60-E85 Ethanol in North America, and 95 RON, 98 RON, 102 AKI, 104 AKI, 108 AKI and E60-E85 Ethanol in the Rest of the World.
    Dynos
    ALL OTHER DYNOS FOR ALL OTHER OCTANES AT THE WHEELS, CRANK, AND GAIN OVER STOCK HERE
    Applications
    • 2017-2018 RS3 / TTRS
    Engines
    • 2.5 TFSI EVO (DAZA)
    Transmissions
    • S Tronic
    Octanes
    • 91 AKI / 95 RON
    • 93 AKI / 98 RON
    • 100 AKI / 104 RON
    • 104 AKI / 108 RON
    • 102 RON
    • E60-E85
    Requirements:
    • TTE Software - TTE700 Turbo with included wastegate and stock solenoid
    • GTX Software - SRM GTX3582 with included turbosmart wastegate and MAC 3Port
    • Full APR Intake/inlet System w/ correct adapter (Stock turbo inlet with reduced power)
    • APR Intercooler
    • APR Race DP / Race MP
    • 980cc Bosch port injectors
    • A Proper LPFP supporting 500+ LPH @ 6 Bar is required to run Ethanol, but the stock pump can be used on other fuels.
    • NGK heat range 9 (NGK-R7437-9) spark plugs gapped to 0.024" ±0.002" or 0.6mm ±0.05mm with a change interval of 10-15,000 mi or 16-24,000 km.
    MAP / Sale (until 2020)
    • $1,999.99 / $1,799.99 - Stock to Stage 3
    • $999.99 / $899.99 - Plus, Stage 1, or Stage 1+ to Stage 3
    • $749.99 / $674.99 - Stage 2 to Stage 3
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Senior Member Two Rings whitewaterguy87's Avatar
    Dec 12 2018
    A badass Scooter! I've had an 05, STI & 1998, 3000GT VR-4
    Northwest
    Hell ya Goapr! Are you planning on doing a build motor file?
    Aug 23 2008
    Auburn, AL
    We're playing around with some stuff. ;)
    Jul 10 2018
    Stamford
    Awesome stuff! What’s LPFP do you guys recommend? I thought I remember you guys holding back because there wasn’t the best fueling options out. I could be mistaken.
    May 08 2015
    uu
    Quote Originally Posted by Arin@APR View Post
    rolling anti lag?
    May 08 2015
    uu
    we need a file for rebuild engine, to maximize the gtx35, too much room left on that turbo
    Dec 12 2018
    Northwest
    I don't see any of the stage 3 requirement on you site? Are you guys planning on selling everything for stage 3 on your website individually or as a package? Or even at all?
    Jun 01 2007
    NOVA
    I am honestly surprised to see this released. It seems like there are a lot of unknowns prescribed...like the "proper" LPFP? Do you guys sell the actual turbochargers you offered this tune for? Again, it just seems like there are a lot of open ends, particularly when compared to my memories of APR Stage 3 covering all the bases on a complete kit, not just a tune.
    I've purchased APR products because I am left with no questions as to what I'll get. I would consider myself fairly well versed on APR's offerings for our platform, and don't see any reason why one would trust this tune on a hybrid turbo set up when it isn't completely set in stone for each set up. At that point, Uni/CC is obvious, unless APR is going to offer the same logging feedback they do.
    Just thoughts.
    Sold // 2018 RS3 - Unitronic TTE700 / BoostLogic / 034 everything / BBS RI-A / etc
    2023 SQ5 - stock + BBS CI-R
    2024 Wrangler 392 - BC Forged LE81 + 37" KO2
    2009 Corvette Z06 - HCI / BC Forged MLE215
    Stage 2 Banner Advertiser Four Rings Kai@EliteMS's Avatar
    Mar 22 2011
    Lindenhurst NY - Long Island
    Quote Originally Posted by whitewaterguy87 View Post
    We have a turn key package utilizing this tune let us know. Have ran it for over 10K miles 100% Thanks!
    ELITE MOTORSPORTS
    21 W. SUNRISE HIGHWAY LINDENHURST NY 11757
    www.elitemotorsport.net - www.elitemotorgroupny.com
    P: 631.775.6634
    Follow Us On Facebook
    Follow Us On Instagram #elitemotorsports
    Follow Us On Twitter
    Veteran Member Three Rings Flom Motorsports's Avatar
    Sep 18 2019
    Northern VA, USA
    following
    2018 RS3 - Too many mods to list them all
    2015 Q7 TDI - Daily and tow rig
    www.flommotorsports.com
    Apr 22 2012
    Norway
    I heard some rumors about a TUV approved stage 3 tune that uses the stock cat. Is this something that APR have in their pipeline?
    Sent from my iPhone
    Aug 23 2008
    Auburn, AL
    Turbo / LPFP - No plans.
    Injectors - Eventually.
    Everything else - yes!
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by context.eax View Post
    Sent from my iPhone
    Yes. On the OPF cars we offer TUV approved setups. Same hardware requirements for the TTE700 only - except stock OPF installed.
    Established Member Two Rings Audi TTRS's Avatar
    Jan 17 2019
    I'm SRM with 1300cc injectors. Is there a downside to running larger than required. We put them on because we plan grow later. Built motor.
    2018 TTRS, APR intake/inlet, IE catted DP, APR intercooler. E85
    Jan 17 2019
    I have the SRM also. I feel there's lots of room in the midrange for sure.
    Quote Originally Posted by s316 View Post
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by Audi TTRS View Post
    We have an SRM tune with 1300cc injectors. No difference (just different injectors). Not advertised because there's no point in the confusion at the moment.
    Jan 17 2019
    Perfect! Thank you.
    Aug 23 2008
    Auburn, AL
    Customer results:
    https://www.instagram.com/p/B6M7tiVnOsR/
    540 AWHP / 480 AWTFLBS - Mustang Dyno - 92 Octane.
    May 08 2015
    uu
    Customer results:
    the gtx35 turbo? any plans to release the rolling antilag feature for stg3 tune?
    Dec 05 2019
    MONTREAL
    its amazing how this lil car respond to mods and get crazy fast!! I mean, its not much and low 10's!!! Question is, how long the motor will last!!!
    Aug 23 2008
    Auburn, AL
    GTX. We have brake boosting on all files.
    May 08 2015
    uu
    can we run the oem boost file on the stg3 tune? map switch
    Aug 23 2008
    Auburn, AL
    On turbo upgrades, “stock” targets stock load levels, so yes. It’s not a stock file in that scenario, or it wouldn’t work.
    Aug 23 2008
    Auburn, AL
    More great results:
    https://www.instagram.com/p/B6RtDBhj...=1rtmoi2t8stfz
    653 awhp on e70
    539 awhp on 92
    May 08 2015
    uu
    More great results:
    653 awhp on e70
    539 awhp on 92
    impressive..
    APR inlet for oem turbo will fit? or need a part to order?
    any instructions on how to install the MAC solenoid for the gtx turbo, where to locate it..?
    can u provide pics by mail?
    Aug 23 2008
    Auburn, AL
    Yes. You just use the correct adapter. We have one that fits the stock turbo, the TTE626 v1, 626v2, 700, 777, and SRM kit.
    MAC - SRM should have all those details with their kit.
    Established Member Two Rings Acerxz's Avatar
    Oct 19 2009
    Is there a tune for the 777?
    Aug 23 2008
    Auburn, AL
    I'm sorry, there isn't.
    May 08 2015
    uu
    Arin, is the development stops on stg3 APR? no plans for built engine file? or bigger turbo?
    Aug 23 2008
    Auburn, AL
    This is what we plan to offer for now. I can't comment on the future.
    Jun 01 2007
    NOVA
    these tunes still avail after all the epa stage 2 removal shenanigans?
    Aug 23 2008
    Auburn, AL
    These tunes are still available.
    Feb 13 2021
    UK
    Arin: how’s the wastegate rattle with this tune? Any plans to eliminate it? Do you offer stage 3 for DNWA engines?
