Results 1 to 27 of 27
    Established Member Two Rings DejanSerb's Avatar
    Jul 08 2016
    $3k Transmission repair?!?!?
    Hey guys, I’ve been looking seriously into purchasing a B8.5 S4, after doing a little studying online I heard these engine’s are pretty darn good (reliability wise) if you take care of them and do the proper services. That being said, I came across this one in my area and he states in the ad that he did the “typically needed $3k transmission repair” (highlighted in yellow). Is this as common as he says it is? What could it possibly be? Thanks I’m advance! IMG_5152.jpg
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    The DSG transmission does have its expensive problems.....2013 and newer are somewhat better...
    Veteran Member Four Rings 2by2handsofblue's Avatar
    Jun 02 2019
    RIP my 98 saturn sc1 5sp that had 294k miles on it.
    serenity valley
    That means hes been driving it pretty hard.
    Hence he doesnt want to deal with the repair. That's why hes selling. If ur going g to buy it, have it inspected and have him knock off 3k assuming there is no other problems.
    Sent from my SM-G965U1 using Tapatalk
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    There’s a drive range sensor buried inside that trans, easily will cost you 3k to replace. And yeah, newer are better only because they have lower miles. Parts diagrams do indicate that sensor is the same pn in newer cars as they came from the factory, and now there have been 2 revisions of it already
    Jul 08 2016
    Quote Originally Posted by S4'ed View Post
    Yeah from what I heard the pre-facelifts have some problems here and there, that’s why I was a bit confused since this one is the facelift.
    Jul 08 2016
    Quote Originally Posted by 2by2handsofblue View Post
    He already did the repair, but yeah if he’s driving it hard then it could only means more problems in the near future..
    Jul 08 2016
    Quote Originally Posted by fastboatster View Post
    Is this a common issue? I would assume that if I was a problem on the B8 s4’s that they would fix it on these b8.5’s
    Jun 02 2019
    serenity valley
    Quote Originally Posted by DejanSerb View Post
    Where did he get the repair done and when.
    Established Member Two Rings JeffSQuattro's Avatar
    Nov 28 2016
    In MY13, some had the Gen 1.5 and at some point there was a transition to the Gen 2 transmission. The Gen 2 is fairly reliable compared to Gen 1 and 1.5 . Gen 1 and 1.5 had mechatronics issues as well as the mentioned above drive sensor. Pretty sure the issues appear regardless of driving habits, I may be incorrect with this. OP should read through the DL501 thread. You can use vcds to find out which transmission code is tied to the vehicle to determine if it’s Gen 1.5 or 2.
    Jul 08 2016
    He got it done at the local Audi dealership, it says recently done.
    Jul 08 2016
    Quote Originally Posted by JeffSQuattro View Post
    I was going to say if there was anyway to see if it’s a gen 1.5 or 2 but you stayed a trend. Do you have a link to the trend? I’ll try searching for it now!
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    B8.5s have significantly better DSG reliability but nothing is 100% failure-free. $3k is a clutch job on a 6MT S4, I wouldn't let it scare you too much.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Mar 05 2016
    The best way is to scan the transmission serial code, it will tell you the tranny generation. If you don’t have access to a scanner, you can look at the driver door panel sticker, if the build date is 05/2012 and up it’s gen 2.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Apr 23 2019
    CA
    There was a tsb for this sensor for both b8 and b8.5. Ask the owner what was done. Better yet, get a 6mt for this kind of money, you’ll thank yourself later when it’s time to resell the car. No matter what they say, dsg can have problems and these can be frustrating and expensive to fix. B8.5 are still too new to tell if things are improved a lot, we’ll find out in a couple of years.
    Jul 08 2016
    Quote Originally Posted by LINDW4LL View Post
    Very true, and the fact that he already had it replaced is a good sign
    Jul 08 2016
    Quote Originally Posted by TC_S4 View Post
    The best way is to scan the transmission serial code, if will tell you the tranny generation. If you don’t have access to a scanner, you can look at the driver door panel sticker, if the build date is 05/2012 and up it’s gen 2.
    Good to know, thanks!!
    Jul 08 2016
    6mt would be ideal, this deal just came out so I thought I’d take it into consideration since a dsg would be nice for driving in rush hour traffic everyday haha
    Mar 05 2016
    I am very curious, let say if the car is early 2013 and have transmission gen 1.5. What happens, the tranny fails and the dealer is replacing under warranty, will they put the same transmission 1.5 or the gen2🤔
    Jun 15 2019
    Earth
    ^^ They usually put the latest revision of the same part. Usually.
    Established Member Two Rings mdwalsh20's Avatar
    Mar 05 2017
    Colorado Springs/CO
    Just had the drive position sensor done a few months ago and bill was 5k done at dealer since I had extended warranty thank god. I never buy them but did after researching the possible dsg issues and figured it was worth the reassurance and it paid for itself. Never launched and never had mech issues or any warnings it just happened after a highway commute in stop and go traffic so it doesn’t mean he was beating on it although I don’t know who buys these cars and doesn’t at some point or another. Seems more related to heat from what my SA said he’s seen and heard but who knows.
    Junior Member Two Rings
    Aug 29 2019
    White lake, MI
    Who do you all use for extended warranties? Dont mean to hijack the thread....
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    One of the reasons the B9 S4s have a Tiptronic rather than S tronic auto trans. You could always go with a manual transmission,if you can find one. Then you only need to worry about a $3k clutch assembly replacement
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by FrankyH View Post
    Troy at Nashua Audi in New Hampshire used to sell Fidelity warranty at a discount. Same as Audi dealers sell.Not sure he is still at that dealership.Perhaps someone has more knowledge on this?
    Jul 08 2016
    Quote Originally Posted by mdwalsh20 View Post
    What year is your S4?
    Jul 08 2016
    Quote Originally Posted by Dr GP View Post
    True, luckily I’m not in a rush to buy one as I have a perfectly fine daily driver right now, so I can play the waiting game.
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    My 6MT rebuilt was 6k when I smoked the input shaft with upgraded synchro's but didn't include a new clutch and other misc. parts.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Apr 23 2019
    CA
    Nice, what did you do to it? Did it just fail when driving normally?
