Results 1 to 4 of 4
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    CFSA RS5 cylinder order
    Just a quick FYI for future reference. The "4.2L" cylinder order is published all the time but I found confirmation in the Audi service manual for the RS5's CFSA engine. Same as the S5's 4.2L.
    Bank 1 Bank 2
    4 8
    3 7
    2 6
    1 5
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Jun 30 2013
    San Jose, CA
    Thanks for posting. Curious, where do you source your documentation? I find it really difficult to locate RS5 specific. A5 and S5 much easier but trying to compile a complete library of RS5 factory manuals has proved very frustrating.
    Jun 24 2017
    San Antonio, TX
    Directly from the factory shop manual for the RS5. They list each coil by name in the diagram above but it's not in a friendly copy/paste format unfortunately.
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    Same firing order for all 4.2's. My RS6 and wifes A8 included. Hence Bank 1 on the right, Bank 2 on the left. A lot of misinformation on this out there.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
