Originally Posted by
OnyxCobra
lol exactly, for these engines that's pretty much not using oil. It's normal for turbo engines to use small amounts of oil, a quart every 5000 miles is basically nothing. I'd probably just change my oil every 5k and be done with it.
IDK if I would say it is "normal" in that there is no reason for them to burn significant amounts of oil. My 2011 A4 2.0t burns no measurable amount of oil on the MMI even after 10,000 miles between oil changes (pistons/rings done at 65,000 and now has 100,000 miles). My 2005 Saabaru with a 2.0 turbo even with 150,000 miles burnt about 0.2-0.3 quarts every 7,500 miles. When new it may have been closer to 0.1-0.2 but it was hard to tell the difference really.
While it is not unusual to burn a quart every 5,000 miles it would seem to me that it shouldn't be the "norm" as some of us with the revised piston rings burn virtually nothing. To me this suggests that a properly built Audi 2.0T engine should burn virtually no oil.
Audi, being the dirty company they are, likes to list it is "normal" to burn up to a quart every 1,000 miles but there is nothing "normal" about that other than the fact they build defective engines and don't want to have to fix them and bank on the fact many will not exceed that rate until they are past 60,000 miles and then the owner has to deal with it (unless a class action lawsuit helps them out with marginally better coverage).
