Results 1 to 11 of 11
    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    Help with fault code: 00256 - A/C Pressure/Temperature Sensor (G395)
    Hi. Discovered this fault code today:
    08-Auto HVAC:
    004 - No Signal/Communication
    AC seems to work fine though. Anyone know the symptoms of this code? Anything I can check/test in VCDS? I mean before I've to take the bumper off to check the connector and sensor visually
    This showed up about a month ago along with:
    19-CAN Gateway:
    01044 - Control Module Incorrectly Coded
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Oct 10 2017
    Sweden
    I checked 08-Auto HVAC, MVB 54 in VCDS and all 4 blocks read 0. Which makes sense if there's no communication I guess. Why is there no signal though.
    Not my picture. Just to show the blocks
    Audi TT 1.8T -99
    Aug 24 2014
    Newport Beach, CA
    My first recommendation is to clear the codes and see if it comes back. Sometimes the car's computers will see something random that it doesn't like and create a code despite it being a one-off event. Now, if the code returns then you know there's something going on.
    2024 M3 Comp xDrive
    Oct 10 2017
    Sweden
    I've cleared it and it does come back. Fuse and relay is fine. Guess only option is to check the connector and sensor itself no?
    Audi TT 1.8T -99
    Aug 24 2014
    Newport Beach, CA
    In that case I'm not sure, wish I could be of more help. Did some searching and looks like an easy replacement as our C6's sensor is in the same place as the B8s and seems to have solved the codes by replacing that sensor.
    https://www.audizine.com/forum/showt...ioning-to-Work
    2024 M3 Comp xDrive
    Oct 10 2017
    Sweden
    Thanks. Yeah, looks like I'll try and replace it. Unfortunately, unless you've really tiny hands, I'll have to remove the bumper to replace it. Or at least put it in service position. It's on the side of the radiator
    Audi TT 1.8T -99
    Oct 10 2017
    Sweden
    Just replaced the sensor and the fault code cleared
    Audi TT 1.8T -99
    Junior Member Two Rings
    Sep 20 2010
    Virginia USA
    Quote Originally Posted by AudiNike12 View Post
    Thank you for the follow up post.
    Veteran Member Three Rings coop3422's Avatar
    Jan 11 2019
    Calgary
    Old thread, but did you have to remove the bumper or put in service position to replace the sensor? My AC didn't work when I bought my S4, and the dealership recharged the system but it still didn't work, and they couldn't find any other issues to told me to spend $4k replacing the AC unit. Couple months later I get an OBDeleven and have the 00256 code. I'm probably not lucky enough for just a sensor to fix the problem, but damn worth trying.
    2015 Audi S4 Sepang Pearl Blue | 6MT | Technik | Sport Diff | B&O | Black Optics | Hertz HCPD1 & JL 12W3V2 | AWE stage II Single Pulley | AWE S-Flo Intake | 034 RSB | CR15 | JXB Ultm Kit | BFI Heavyweight | 19" Rotors w/ MPSS | 18" Peelers w/ Blizzaks
    Junior Member One Ring
    Sep 29 2019
    detroit/michigan
    code 00256
    AC shut off within seconds.....no cool air.....
    Research showed G395...ran vcds....Module 08-Auto HVAC No faults
    Then found compressor no clutch type....solenoid valve goes faulty....compressor still good(most cases)replaced......
    still no cool......
    Reran VCDS....checked Module 09-Elect--00256 code!, but no code in 08-Auto HVAC
    Replaced G395...still no cool.....
    Check for power at G395...battery voltage.....
    Also....Measuring blocks show nothing....054 block shows nothing...no title, 0.0 (no Units)....
    So am guessing data not getting from G395 to wherever it goes, the J519 via LIN wire?
    Wire looks good......not sure what to do next....is there a way to rule out compressor.....
    have seen nothing on this...and it seems that might be easier than trying to track down electrical gremlins....
    system has 100psi static pressure now....almost 20 Oz 134a....still not turning on....
    Senior Member Three Rings MTL4's Avatar
    Aug 05 2021
    Maritimes
    Quote Originally Posted by metanosis View Post
    still no cool......
    00256 - AC Pressure/Temperature Sensor (G395) - No Signal/Communication
    What year/model was the vehicle? Was this an OEM Audi sensor you installed? What part number did you use?
    Here's why making sure you have the correct part number is important:
    https://forums.ross-tech.com/index.p...e-9#post-34614
    https://forums.ross-tech.com/index.p...e-9#post-91330
    2010 Audi A6 Avant 3.0T Prestige
