Originally Posted by
97B518TQM
Saying that with only $3k you end up with something very similar to the S6 is laughable, to say the least. $3k will get you an ECU and TCU tune, a couple of pulleys, and a heat exchanger, at most. And that's assuming you do your own installation of the heat exchanger. The hpfp will be close to maxed out so you have to spend a few hundred bucks for that upgrade as well. And then you may or may not have an A6 that will keep up with a bone stock S6.. maybe 20-70mph. You still won't have over 400ftlbs of torque as early as 2k rpm, you still won't have 6 piston brembo calipers with 400mm rotors, you won't have adjustable air suspension, you won't have sport dif, you won't have the engine sound, you won't have the adaptive steering, you won't have the cylinder deactivation for longer trips at cruising speeds, and most importantly where the 3.0T in the A6 starts to run out of possibilities for more power that's where the S6 is just getting started from with just a tune....So while they look similar, the A6 and S6 are not that much alike, despite what people who can't afford an S6 try to convince themselves. I speak from experience. I was a 3.0T fanboy with what I thought was a super fast S4.
An A6 with the mods you stated will be faster than a stock S6. You do realize there are tons of A6's in the 11's on here and the community, right? Then there are some in the 10's. I do wish I had the V8 sound and the air suspension. Everything else you said I could care less. They are attributes for someone trying to be douchey, bragging that they spent the money. I can easily afford an RS7 if I wanted. However, spending that much money on a car in my opinion, unless very wealthy, is stupid. But to each their own.
Regarding your bragging elements:
-We don't need cylinder deactivation. We get over 30 mpg on the highway as it is.
-I could care less about the Brembo brakes. Do you have any actual data that shows the time shaven off from the A6 brakes? Or do you just like saying you have Brembo brakes? I'm sure there is a performance benefit. But by how much? Does the extra thousands of dollars in the purchase price and lifespan really justify the performance? Would I like to have them, yes. Would they be nice, yes. Value is subjective. In my opinion, for the amount I am actually taking the car at speeds where these brakes would be beneficial are so low, it makes no sense having them.
Don't S6/S7's start getting transmission issues after stage 1? I see a lot of mid-11 stage 1 S6's in the spreadsheet that TypingAllDay posted. Getting to a mid-11 is very achievable with an A6. So while you say the A6 is running out of power and the S6's are just getting started. Can you explain? The top four posted times on the spreadsheet from Stage three S6's are 10.554, 10.697, 10.746, 10.847. The fastest posted time, at least that I know about, for an A6 is 10.8. How much extra money is needed to go from stage 1 to stage 3? I don't even want to guess, but I bet it is hell of a lot more than it takes to get an A6 into the 10's. Not even to mention the cost of the car, insurance, gas, etc.
I don't understand how you think a mid-11 A6. (with fuel mods would run this) is so much different than a Stage 2 S6 running an 11.3.
If I wanted a platform based on performance alone, it definitely wouldn't be an Audi A6/S6. It is nice to spend a little money on them and have a decently fast car.
