Results 1 to 20 of 20
    Nov 03 2019
    Creaking noise in parking speed
    Today I noticed a creaking sound that looks is coming from the front in my 2016 S3 (13,800 miles).Looks like is from the suspension parts since the sound is when passing trough irregular surface or speed bumps.
    Does anyone knows if this is a common issue and possible solution?
    Highly appreciated
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    Is it a clicking or creaking sound when turning the steering wheel from lock to lock? Our 2016 A3 has the clicking sound but always had the creaking sound which has never been addressed by the dealer.
    For the clicking sound, the drivers side strut bearing was replaced. For some reason the strut bearings in these cars is a two piece solution whereas the other models is a one piece - as told by the Audi mechanic.
    Nov 03 2019
    Is a creaking sound but no necessary when turning. It sound when driving at low speed l, “ parking speed” above uneven ground.
    Jul 27 2015
    Ontario
    Quote Originally Posted by facasi View Post
    Our A3 also has a clunking sound over uneven roads as well which sounds like a broken or worn out end link. I had it checked with the control arm busing replaced and still clunks, sorry as this doesn’t help you much.
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Highly appreciated
    13,800 or 138,000? Mine's got 81 k and is creaky too. Just bushings, but annoying anyway. hard to track down the individual ones. Probably the front strut mounts. Expensive to have the dealer chase this stuff.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Nov 03 2019
    Mine is 13,800 miles
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Wow. that's like brand new. Surely still under warranty?
    Established Member Two Rings RyanE6's Avatar
    Sep 14 2018
    2019 Subaru Crosstrek Premium
    South Beloit, Illinois
    Highly appreciated
    Same issue, 2016 A3 S-Line with Sport Suspension 29,xxx miles
    There is a TSB for this issue. I just had the following parts replaced yesterday under warranty per the TSB.
    TSB: 204342419
    Installed G 000405A2 Grease Qty:1
    Installed N 10695901 Bolt Qty:4
    Installed WHT000785 Nut Qty:2
    They removed the lower control arm to lubricate bushings. Unfortunately this didn't solve my issue and they ordered a spring and shock absorber.
    Edit: Google search TSB 2043424. For some reason the last two digits change.
    Sent from my Pixel 2 XL using Audizine mobile app
    Nov 03 2019
    I was looking info about the TSB that you referred but I have found nothing in the web.
    Please send the link with the related info we’re they explain the problem l. I want to show it to my local dealer, thanks.
    Senior Member Two Rings sj9ninety's Avatar
    Nov 03 2018
    2022 M240i
    Northern Virginia
    I have the exact same issue. Creaking at low speeds over speed bumps or uneven surfaces. It seems to go away after the car is warmed up.
    34,000mi on my 16 S3 with Mag Ride
    Nov 03 2019
    Have you contacted the dealer ?
    Senior Member Two Rings billk1967's Avatar
    Nov 27 2018
    Vancouver
    Interesting, I too have the same issue. I thought it was more to do with the sunroof but never really looked any further into it. I will bring this up with my dealership the next time im in, thanks.
    2018 Panther Black TT RS
    Sep 14 2018
    https://www.truedelta.com/Audi-A3-tsbs-8,2016
    Search 2043424.
    Google search TSB 2043424, there are plenty of results. I will take a picture of my invoice from the dealer and upload it when I get home.
    Nov 03 2019
    Perfect, thanks.
    Will wait for the invoice
    Sep 14 2018
    Perfect, thanks.
    I removed all personal information from the invoice except for the SA just in case the SA at your dealer wants/needs to contact him.
    Nov 03 2019
    Thank you. This will help a lot.
    Nov 03 2019
    I found this just moment ago inspecting the car from the out side and pushing softly the right side of the front.
    See the link :
    https://drive.google.com/file/d/18KC...w?usp=drivesdk
    Nov 03 2018
    2022 M240i
    Northern Virginia
    See the link :
    Didn’t see that one coming lol. So it wasn’t any of the issues mentioned above?
    Nov 03 2019
    I noticed this yesterday night inspecting the car from the outside. I don’t know if the issues are related.
    Nov 03 2018
    2022 M240i
    Northern Virginia
    Quote Originally Posted by sj9ninety View Post
    Update: Audi was able to correct this under warranty. They removed two front bushings, greased, and reinstalled.
