I will be installing a set of Bilstein PSS10s on my 2016 6MT S4 soon, but I do have a few questions prior to install.
Anyone know where I could find torque specs for the bolts/nuts?
Otherwise, I’ll be using hand tools but believe I have everything needed. Strut separator tool is in the mail, spring compressors I’ll end up renting from Autozone.
I am not sure if getting a set of new pinch bolts/nuts is necessary, or if I could just remove the two upper control arms from the top(?).. would seem easier to me than messing with the ball joint side(?). I am fairly new to Audi and haven’t done this before but seen some videos which seem like that end would also work.
Additionally, would counting a certain amount threads be best way to lower, or is there a specific height recommended from fender down? (Not looking for slam it of coarse) Please note, I am using the stock black optics wheels (“flower wheels”) and looking for a fairly flush drop. That being said, I would like to run some spacers to make everything look ideal and flush.
As far as spacers go, I was told that a set of ECS 8mm front and 12.5mm rear with the drop should work, avoiding any rubbing if height is adjusted accordingly. Does anyone know anything about that specific setup... I’d assume longer bolts from ECS with the spacers would be necessary for a proper install.
Any and all suggestions would be greatly appreciated. Trying to make this process go as smoothly as possibly. Will be doing this without air tools in my garage and without any additional help at hand. Thanks in advance!
