Originally Posted by
thatauditech34
Ive seen kits out there for our B8s but I’ve never seen one actually work.
Audi’s Kessy and Access/Start Authorization system is very complicated and is just a headache to begin with. Most newer Audi’s (09-current) that have a remote start installed usually end up at the dealer because they never work.
I have a 2009 A4 with the push key fob start/stop. On a cold morning, if I start the car by putting the fob into the ignition and then take the physical key out of the fob and use that to lock the driver side door manually with it, would that cause any harm or damage?
Here is my workflow:
1. Start car with key fob inserted into ignition
2. While key is in ignition and car running/idling, remove the physical key from the fob
3. Get out of the car, shut the driver door, use physical key to lock driver doors which locks all doors
4. Go about my business inside
5. Come out, unlock the driver door with manual key, hop in car, reinsert the physical key into fob
6. Drive off.
