Hey chaps
Greetings from down under.
Just having a few issues with re-installation of my injectors as now twice the car has run nice but a bad fuel smell has been found that upon re-installation I'm rupturing the top O ring. I smear it with some engine oil to help it feed in, but on both occasions I've inserted the injectors in the head first then guided the manifold on them. Should I consider inserting them in the manifold first then walking them down with slow cross tightening of the bolts. Also im considering replacing all the O rings on each injector. Car has done 100000km (approx 60000miles).
Something else I thought of is perhaps torquing them down to a lower setting then letting it sit overnight, then retorquing back to spec? What do you chaps think?
One good thing is I fixed the coolant leak, it pressure tested great holding 15psi nicely, which is great, and I have the forum to thank for all the help. Probaby a 4k + job to do here in a workshop, and even worse with original head gasget diagnosis.
Sorry for the extra questions, but as there is a little bit of green paste in the oil, my plan is to once commissioned back to life, is to run the car to warm then change the oil, then run for another 500km and change the oil and filter again.
