There is a new formulation out for this oil in 2019 that has SN-PLUS certification for LSPI prevention, in addition to VW502 approval.
This is the first VW502 oil I've found that is also SN-PLUS certified. Pennzoil Platinum Euro 5W-40. You can get it at NAPA and other places.
Why would anyone care about SN-PLUS?
This is a recent specification that is specifically designed to mitigate LSPI events in the engine.
I had this oil tested and it has 1300ppm of Calcium which is a pretty good value for prevening LSPI, see below.
There is a thread here about LSPI with some background - the 2.0 TFSI is certainly an at-risk engine and perhaps more so if you're tuned.
https://www.audizine.com/forum/showt...ection-Engines
The upshot is you should avoid high load (boost) at low RPM (that is, downshift before strong acceleration if you're in a mid to high gear).
It has been found that the motor oil you use actually has an impact on the probability of an LSPI event.
See: https://www.infineuminsight.com/en-g...-pre-ignition/
You want Calcium levels as close to 0.10% (1000 ppm) as possible - typical oils have values of 2000 or even 3500ppm which are bad for LSPI.
I will also be posting a used oil analysis of Mobil1 0w40 but I expect the calcium levels to be >3000ppm
