Results 1 to 10 of 10
    Established Member Two Rings Hayk's Avatar
    Jul 24 2019
    Boston, MA
    SQ5 Badge for RS Honeycomb Grille
    I recently swapped my SQ5's grill for the RS honeycomb grill and the included badges for the new grill look cheap/cheesy. I'm wondering if anyone has had success mounting an SQ5 badge (either from the replaced grill or bought) on their RS grill. The black badge from tagmotorsports looks nice but not sure if it will mount properly on the honeycombs.
    Minor issue I know, but any help would be much appreciated!
    Sent from my SM-G973U1 using Tapatalk
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    Took some a bunch of custom work, but it came out pretty good.
    Removed the old badge, cut off the plastic that protrudes out the back, modified the holder that came with the RS grille, and joined the two together. Measured and mounted it as close as possible to where it was on the stock grille.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Jul 31 2016
    PA
    Looks good, what grill did you end up buying? Trying to find one with the Quattro logo but without spots for a front license plate mount since they make it look a little off.
    Quote Originally Posted by BG SQ5 View Post
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Same question, Berk. There are scores of these type grills on eBay and it’s hard to sort through them.
    My car is Brilliant Black. A pure black grill would be invisible. Yours has the bright border and the Quattro logo to provide some contrast. It looks fantastic. Was it true plug-and-play, or was some trimming needed?
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Feb 21 2016
    '07 CBR1000RR
    PA
    It’s just an eBay one, and I spent hours modifying it. After taping off and using a dremel to remove the main blanks, I hand filed all 5 openings to perfection with needle files. Then, I re-taped them and touched them up with a gloss black enamel.
    Of course, then there’s a bunch of modifying of the lower mounting area as well to get it to fit on a B8.5.
    Instagram: @bg.sq5
    Jul 31 2016
    PA
    Cool, thanks for the info, really did a nice job.
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    Thanks for giving me the idea to tape everything off I hope to get some time this weekend to install mine.
    Sent from my Note9 using Tapatalk
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
    Feb 14 2017
    Gulfport, MS
    Thanks! This information is very helpful.
    Jul 24 2019
    Boston, MA
    Is that a US license plate holder? My quattro grill came with the euro license plate but I'd like to have it just in case a cop forces me to run a plate (in MA).
    May 06 2007
    2020 Q3 P+
    It's not a US plate holder, we have the same law in CT, I'm banking on not getting stopped for it, but you could always zip tie the plate on somewhere or use the tow holder. My grille came with the Euro plate holder too.
