First, in the main menu, go to the second page of ‘installed’ modules and find the BA motor mounts button:
Once you’re on the motor mounts menu, go to output tests:
In output tests, you can select either the left (driver’s side) or right (passenger side) mounts as the top 2 options on the following screen:
Once you select one of the tests and press START, you should hear a fairly loud and fast vibratory noise. Press stop and then run the test for the other side. Both sounds should be equally obnoxious.
It helps to run this test in ACC mode and with your windows down. There is definitely no mistaking the noise. In general, if the fluid has leaked out of the mount, even if you aren’t getting a DTC error code, the affected mount(s) won’t make anywhere near the noise that they should.
