Results 1 to 11 of 11
    Active Member Two Rings nstueve's Avatar
    Feb 15 2019
    Indianola IA
    A4 B6 1-2 lift kit??? Not air!
    Ok Ive been looking and there seems to be varying information on this topic. Im new to the Audi platforms so I dont know all the interchangeable parts like some.
    I only drive my A4-B6 in the winter for awd. Im on 4miles of country gravel roads (not particularly well cared for either). So Im looking for and extra 1-2 lift to get my belly off the uneven gravel ground and for snow clearance. Dont want air!!! Just a coil over or spacer mount kit. Dont want steering geometry or linkage issues. A fairly simple bolt on kit followed by an alignment is all...
    Feb 15 2019
    Indianola IA
    In truth I probably need an outback or forester that have 8.7 clearance currently.
    My 2002 b6 avant is at 4.2 via Edmonds online.
    She lives in the mud and snow. Would love 2 lift if feasable without heavy modification. Ive seen 20mm kits but thats only .75!!! 45-50mm would be awesome!
    Jul 21 2013
    B6
    spaccer.com has these ring things that stack. You can get 4 of them for each corner and bump it up about 2"
    for $1500
    at that price you can probably find a passable subaru but an avant battle wagon would be sick
    2004 A4 USP 3.0 6MT | 2002 Allroad 2.7t | 2018 A3 daily
    @b6_ultrasport
    Feb 15 2019
    Indianola IA
    Quote Originally Posted by Tahoe3.0 View Post
    for $1500
    Yea if its just stacked plates Ill get a friend to cut some on his CNC for $100... the question remains how high can I go before I start causing myself other problems and its not a bolt on anymore?
    I just found this and have to think an A4 has same mounts as the Allroad... right??
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Quote Originally Posted by nstueve View Post
    Front suspension is similar, the rear is different afaik.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Feb 15 2019
    Indianola IA
    Quote Originally Posted by fR3ZNO View Post
    Mounts are different? Both would be AWD...
    Feb 09 2013
    WNY
    Yes... but theyre different platforms. Many Audis are AWD but the suspensions are different and therefore parts arent interchangeable.
    Feb 15 2019
    Indianola IA
    Allroad based on a A6?
    Aug 19 2005
    07 A4 Avant S-line 6MT
    CNY
    Correct, the pre 05 allroad is an a6, c chassis not the b chassis our a4 is built from.
    '21 SQ5 Ultra Blue
    past: B7 Avant 2.0t S-line Manual [CTS K04, 034 K04 Tune, Golf R intake cam, CTS HFC, Stasis Exhaust, BFI Snub, 034 Street Mounts, Apikol Race Diff Mount, Hotchkis 29mm RSB]
    Feb 09 2013
    WNY
    Just as an example here are the rear shock mounts from a B6 and a C5.
    B6
    https://www.ecstuning.com/b-genuine-...ch/4f0513353d/
    C5
    https://www.ecstuning.com/b-febi-par...e0512121e~feb/
    Feb 15 2019
    Indianola IA
    So what if I got some 1 thick aluminum stock and just cut some spacers to put in between the mounts and body and maybe tube spacers up front? Would I still have enough adjustability to get suspension lined up?
    I read some extra threads about this and was reading that the best way was by installing spacers between body and frame. So now Im wondering if one could do a combination of 3/4-1 body lift and 3/4-1 suspension lift? Wondering if thats possible without causing a huge amount of accessory issues to correct.
