Originally Posted by
hilmar2k
There's no way a 12v battery is ever at 19v.
Thinking about it, you're probably right. I'll double check.
hilmar2k
Exactly this. I can't understand replacing it as "preventative maintenance". You aren't preventing anything. You're not just going to get stranded, there will signs that it's on its last legs before it dies. That's when you replace it.
My reason being was that I went to a drive-in movie theater, after 2 showings, it wasn't turning over anymore so I had to get a jump. Thinking back, I should've turned on my car at the end of the first airing to charge the battery and shut off right when the second movie started, but I didn't think accessory usage would've killed it that much.
